0.7.3 does not install [message #31884] |
Thu, 14 August 2008 09:37  |
Originally posted by: gregor.rosenauer.itsv.at
I have successfully (well, with some hickups when renaming files, but else
ok) used Subversive 0.7.1/Ganymede.
Now for some reason SVN-connectors disappeared and I cannot get them back
(I believe the problems started after installing the SQLExplorer-Plugin,
which I now uninstalled without effect).
I have read through the list and changed the URLs accordingly, but always
get errors that either some dependencies cannot be resolved, or the view
cannot be initialized.
When trying to update via the update sites, I get this:
Cannot complete the request. See the details.
Unsatisfied dependency:
[org.polarion.eclipse.team.svn.connector.svnkit.feature.grou p
2.0.3.I20080814-1500] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.team.svn.feature.group /[0.7.2.I20080801-1500,1.0.0)
[org.polarion.eclipse.team.svn.connector.javahl.feature.grou p
[org.polarion.eclipse.team.svn.connector.feature.group
Unsatisfied dependency: [org.maven.ide.eclipse.feature.feature.group
0.9.5.20080717-1821] requiredCapability:
org.eclipse.equinox.p2.iu/org.maven.ide.components.maven_mod el_edit/[1.0.0.20080717-1819,1.0.0.20080717-1819]
org.eclipse.equinox.p2.iu/org.polarion.eclipse.team.svn.conn ector.feature.group/0.0.0
[org.polarion.eclipse.team.svn.connector.javahl.win32.featur e.group
From the archived site I get this, after the install runs through:
An error occurred during provisioning.
Failed to prepare partial IU: [R]org.eclipse.team.svn.core
0.7.3.I20080814-1500.
Please help, or else I have to go back to Subversive...,-)
Re: 0.7.3 does not install [message #33933 is a reply to message #32374] |
Tue, 23 September 2008 10:53   |
Hello micky,
You should install connectors from
http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/,
because connectors from
http://www.polarion.org/projects/subversive/download/eclipse /2.0/ganymede-site/
are not compatible with SVN Team Provider 0.7.3.
For more details, please, see
http://www.eclipse.org/newsportal/article.php?id=701&gro up=eclipse.technology.subversive#701
"micky" <micky_lee@cyberpowersystems.com.tw> ???????/???????? ? ????????
?????????: news:8ae2a75caa9947fff998fd319935bdbd$1@www.eclipse.org...
> me too, I download all files and installed well, but when I create a new
> SVN repository, it told me the following...
> SVN: '0x00400006: Validate Repository Location' operation finished with
> error: Selected SVN connector library is not available or cannot be
> loaded.
> If you selected native JavaHL connector, please check if binaries are
> available or install and select pure Java Subversion connector from the
> plug-in connectors update site.
> If connectors already installed then you can change the selected one at:
> Window->Preferences->Team->SVN->SVN Client.
> Selected SVN connector library is not available or cannot be loaded.
> but I download all native JavaHL 1.4.5 and 1.5 include others in
> after all updated, the SVN connector still can't use....
> I am very sad...
FUDForum. Page generated in 0.06396 seconds
