Home » Archived » BIRT » Adding my own templates to the report template wizard, no extension point?
Adding my own templates to the report template wizard, no extension point? [message #34269] Wed, 04 May 2005 16:37 Go to next message
hello,
Trying to figure out how to add my own templates to the report template
wizard. and searching I found the class
WizardTemplateChoicePage
and the canned template choices seem to be hard coded into the wizard.
Seems a better way would be to have a template extension point, to allow
others to add to this wizard? or am I missing something?
Re: Adding my own templates to the report template wizard, no extension point? [message #34611 is a reply to message #34269] Thu, 05 May 2005 05:56 Go to previous messageGo to next message
Originally posted by: none.none.com
Hi Mike,
The templates are indeed hardcoded in the report wizard. We have been
looking at different ways to support user-defined templates, and the
extension point is definetely a good candidate. I will propose an
enhancement for that and let you know on the status.
Thank you,
David
"Mike Boyersmith" <mjboyers@us.ibm.com> wrote in message
news:d5bc4v$8p1$1@news.eclipse.org...
> hello,
Re: Adding my own templates to the report template wizard, no extension point? [message #34644 is a reply to message #34611] Thu, 05 May 2005 11:51 Go to previous messageGo to next message
Ok sounds good!
Can you post the defect or RFE number when you have it. I searched Birt
Bug List but don't see it yet. If you want I can file it.
Just need this for tracking features that were considering using in our
product at some point :D
David Michonneau wrote:
> Hi Mike,
> Thank you,
> David
>>hello,
Re: Adding my own templates to the report template wizard, no extension point? [message #34678 is a reply to message #34644] Thu, 05 May 2005 12:04 Go to previous messageGo to next message
Definately extensibility is a good thing here. I see two extension
possibilities right off that would be nice to have:
1) An extension point that allows a company to add to a tree view that
categorizes templates something like
company X feature
temp1
temp2
temp3
Company Y feature
tempa
tempb
tempc
company z
sub category a
temp1
temp2
temp3
sub category b
temp 1
temp 2
temp 3
- OR -
2) Add extension support for adding kinds of templates to the wizard and
allow the extension implementor to provide additional pages for that new
kind of template on the template kind selection and Next button press.
so
wizard page 1 mighe be
Select Kind of Report Templates you wish to work with
Basic
Company X
Company Y
if I select Company X and hit <next>
I get the Company X list of templates to select from.
anyway....
>> Hi Mike,
>> Thank you,
>> David
>>> hello,
>>> template wizard. and searching I found the class
Re: Adding my own templates to the report template wizard, no extension point? [message #35086 is a reply to message #34644] Fri, 06 May 2005 13:15 Go to previous message
Mike,
Please go ahead and file the enhancement under Bugzilla.
Thank you,
David
news:d5dfpt$dsi$1@news.eclipse.org...
> Ok sounds good!
>> Hi Mike,
>> Thank you,
>> David
>>>hello,
Previous Topic:ANT disappeared from the launch toolbar after installing birt
Next Topic:Chart - Marker color
Current Time: Mon Sep 22 15:34:27 EDT 2025
Powered by FUDForum. Page generated in 0.04276 seconds
