Home » Eclipse Projects » Mylyn » Aren't my editors supposed to auto-close?
| Aren't my editors supposed to auto-close? [message #34216] |
Fri, 26 October 2007 11:22  |
I've been using Mylyn for a bit now, and I think something's not going
right. I'm finding myself with a build-up of over 50 open editors, about
70% of which are .class files from libraries. I thought editors were
supposed to close themselves as Mylyn deems them less interesting.
Mylyn is remembering the files for the context, so they all close when I
close the context, and they all come back when I re-open, but I don't
think I've ever noticed an editor close itself while working.
Items are appearing and disappearing from the Package view as I'd
expect, so the activity monitoring is working to an extent.
When should Mylyn be closing editors? Could it just be that the 50 open
editors are what it deems interesting? Am I confusing it by frequently
looking at library source?
Mylyn > "Manage open editors to match task context" is on
Mylyn > "Remove file from context when editor is closed" is on
Editors > "Close editors automatically" is off (I've read that this
should be off for Mylyn's handling to take over).
I'm on Eclipe 3.3.1 and Mylyn 2.1.
Any ideas?
Kevin
| Re: Aren't my editors supposed to auto-close? [message #34317 is a reply to message #34216] |
Tue, 30 October 2007 04:08   |
Hi Kevin,
"Close Editors Automatically" seems to be the feature you're looking for...
I've found the following phrase in Mylar 0.4 New & Noteworthy:
> "It is recommended that you either turn off the "Close Editors
> Automatically" workbench setting, or set a high number to leave open."
So looks like an good option.
Alexey
On Fri, 26 Oct 2007 16:22:33 +0100, Kevin Bracey <kbracey@broadcom.com>
> Any ideas?
> Kevin
| Re: Aren't my editors supposed to auto-close? [message #34384 is a reply to message #34350] |
Tue, 30 October 2007 15:19   |
Kevin Bracey wrote:
> Well, that's it - I'm sure it's not on purpose. Mik's articles about
> Mylyn specifically talk about the auto-closing of editors. Here's a
> quote from part 2 of his IBM DeveloperWorks article:
> "Mylyn also uses the task context to manage actively the number of
> open editors related to a task. When the elements in a file decay
> beyond your interest, that editor automatically closes. When you
> deactivate a task, all of its editors close and then reopen upon task
> activation. Reducing an element's interest closes its editor and,
> conversely, closing a file reduces its interest."
> But it seems that something on my system and yours is stopping this
> working fully. All I'm getting is the opening and closing on task
> activation, and closing a file reducing its interest.
Kevin, there been changes in this functionality in the last release,
because some users find interest decay on editor closing is too
confusing. You may want to check the preferences at Window /
Preferences... / Mylyn / Context / Editors.
regards,
Eugene
| Re: Aren't my editors supposed to auto-close? [message #34587 is a reply to message #34418] |
Wed, 31 October 2007 12:01   |
> As I said in my original post, both options in that group are enabled:
> The latter is happening, the former isn't.
> Maybe it's time for me to actually do some debug investigation. I'll
> start digging around in Mylyn today.
Okay, I'm seeing two things here. Firstly, it seems to me that Mylyn
appears pretty reluctant to actually remove documents from interest
automatically, but it will do it. But I suspect this may be partly due
to my artificial testing not matching real usage patterns.
Anyway, the main problem occurs in JavaUiBridge.close(). It loops over
getActivePage().getEditorReferences() trying to locate an editor for the
node being closed.
The stumbling block appears to be that the method it uses,
EditorReference.getEditor(false), only actually returns an editor if the
editor is active. If it's one of the ones buried at the back of the
stack, it returns null.
So the auto-close will only ever work if the document that's become
uninteresting is one of the ones you're working on! Very unlikely,
unless you've manually selected "remove from context".
I'm going to submit a bug report.
Kevin
| Re: Aren't my editors supposed to auto-close? [message #35091 is a reply to message #34587] |
Fri, 02 November 2007 22:19  |
Originally posted by: beatmik.acm.org
Great diagnosis Kevin, this is indeed intended to work as you expect.
There is some trickiness to this policy and when it's OK to auto-close
without incurring performance overhead (e.g. if an editor has not
materialized yet), but thanks to your patch we'll prioritize improving
this for an upcoming weekly build. For others interested the bug is:
208265: [patch] [context] Mylyn is not auto-closing editors
https://bugs.eclipse.org/bugs/show_bug.cgi?id=208265
We also have a related usability issue. Task editors do not auto close
because they do not participate in the task context. While restoring
them takes almost no resources because they don't materialize until
activated, if you browse a bunch of tasks while you have another task
active you'll get this bloat. I've wondered whether we should change
our restore policy to only restore the editor for the task that's being
activated.
Mik
> node being closed.
> Kevin
| Re: Aren't my editors supposed to auto-close? [message #583883 is a reply to message #34216] |
Mon, 29 October 2007 05:24  |
Kevin Bracey ha scritto:
> Any ideas?
Hi Kevin,
I noticed the same thing, so I think it is on purpose...
I agree with you that it would be more useful if Mylyn closed the
editors of those files that exit from the context... I also find myself
with tens of open editors and this IMHO makes Mylyn context-driven
approach less effective...
Mauro.
| Re: Aren't my editors supposed to auto-close? [message #583897 is a reply to message #34252] |
Mon, 29 October 2007 10:43  |
>> Any ideas?
> Hi Kevin,
Not to mention keeping extra editors open when they no longer fall into
the context is a waste of system resources as well.
| Re: Aren't my editors supposed to auto-close? [message #583907 is a reply to message #34216] |
Hi Kevin,
Alexey
> Any ideas?
> Kevin
| Re: Aren't my editors supposed to auto-close? [message #583916 is a reply to message #34252] |
Tue, 30 October 2007 14:43  |
>> Any ideas?
"Mylyn also uses the task context to manage actively the number of open
editors related to a task. When the elements in a file decay beyond your
interest, that editor automatically closes. When you deactivate a task,
all of its editors close and then reopen upon task activation. Reducing
an element's interest closes its editor and, conversely, closing a file
Kevin
| Re: Aren't my editors supposed to auto-close? [message #583926 is a reply to message #34350] |
regards,
Eugene
| Re: Aren't my editors supposed to auto-close? [message #583938 is a reply to message #34384] |
Wed, 31 October 2007 07:40  |
Kevin
| Re: Aren't my editors supposed to auto-close? [message #583979 is a reply to message #34350] |
Wed, 31 October 2007 09:16  |
I'm glad to know that it should work as we expect... maybe it's the case
to open a new bug report?
Mauro.
| Re: Aren't my editors supposed to auto-close? [message #583993 is a reply to message #34384] |
Wed, 31 October 2007 09:20  |
Hi Eugene,
the problem that Kevin is reporting was also present (for me) when Mylyn
was still Mylar... Editors are never closed automatically, except when I
deactivate a task and/or switch to another one.
I thought it was on purpose, even if I didn't agree with that, so I
never tried to discuss this issue here, but now Kevin highlighted that
editors really should be closed when files exit from the context...
Mauro.
| Re: Aren't my editors supposed to auto-close? [message #584021 is a reply to message #34418] |
node being closed.
Kevin
| Re: Aren't my editors supposed to auto-close? [message #584264 is a reply to message #34587] |
activated.
Mik
> node being closed.
> Kevin
Current Time: Sun Nov 09 00:28:52 EST 2025
Powered by FUDForum. Page generated in 0.10190 seconds
