Home » Eclipse Projects » Equinox » What happened to Export-Package, etc.?
What happened to Export-Package, etc.? [message #33440] |
Wed, 14 January 2004 20:42  |
The MANIFEST.MF generated by PDE includes "Require-Bundle" and
"Provides-Packages" headers in place of the OSGi "Import/Export-Package"
and "Import/Export-Service" headers. I understand the need to add extra
headers to augment the functionality provided by OSGi, but why did you
choose to remove the OSGi headers. It looks like they can co-exist.
The effect of excluding the OSGi headers is:
1) You cannot use the generated MANIFEST.MF if you want to deploy to other
OSGi implementations.
2) You lose the ability to dynamically swap different implementations of
services that are packaged in different bundles since you are bound by the
actual bundles instead of the service interfaces they export. The
workaround is to package the service definitions in a separate bundle so
that client bundles are dependent on the definition bundle rather than the
implemenation bundle(s). However, that can quickly become cumbersome. In
fact, the OSGi FAQs suggest avoiding this approach. Instead, they suggest
including the service definition (and resulting dependency graph) in
whatever bundles require. Does Eclipse have a tool for exporting a set of
classes and the result dependency graph? If so, one could define a common
base project (not plug-in) and export subsets of it to jars to be included
in dependent bundles. This would alleviate the need for hardcoding of
bundle dependencies. If mapping bundle dependencies is a requirement,
maybe it could be moved to the encompasing feature project so that the
dependencies are kept external to the bundle definitions.
Stephen
Re: What happened to Export-Package, etc.? [message #33780 is a reply to message #33440] |
Fri, 16 January 2004 00:05   |
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
These are great questions. See my comments...
"Stephen Goldbaum" <stephen.goldbaum@lehman.com> wrote in message
news:bu4r67$7lq$1@eclipse.org...
They can and do co-exist. The manifest generator happens to generate
manifests using Require/Provide since those semantics most closely match
what we see in Eclipse. There are instances of Import/Export (and both) in
some of the manifests in Eclipse (see runtime or update.configurator).
True today but we are working with the OSGi community to add new dependency
expressions to the spec. OSGi 4.0 may well include support for this style
of bundle dependencies.
The standard OSGi Import/Export Package and services mechanism are very
useful/powerful. But it turns out that in many of our (and others)
usecases, you actually don't want to get implementations from others and/or
use services. For example, product guys are absolutely freaked out by the
idea that they could not control the exact implementation constraints. My
sense (no validation) is that OSGi's traditional audience (gateway providers
etc) had much more control over the OSGi installation/configuration than we
see with Eclipse scenarios. Thus, specifying a dependency on a package X
and relying on a system integrator to only make available reasonable
implementations of X makes sense. In Eclipse scenarios the system
integrator is more often than not, the end user. They neither have the
knowledge or interest to deal with this level of detail.
The other thing to note its that not all Eclipse plugins/bundles contain
code. Doc plugins for example supply content to the help system. How can I
express a dependency that particular doc be installed?
> The
May have gotten you wrong but my understanding of OSGi common practice is
that the service APIs are in a bundle by themselves and the implementations
are in other bundles. If you lump the API and the implementation together
then the effects of configuration changes (e.g., updating a bundle) will
propagate much further causing more of the system to shutdown and restart.
I do not know of such a tool.
Features are not part of the runtime. Of couse, we could make them be but
it is unclear how this would help. If the classloaders look at and follow
the dependencies expressed by the features (as well as the Import/Export
dependencies), you get the same net effect.
Jeff
Re: What happened to Export-Package, etc.? [message #33977 is a reply to message #33780] |
Fri, 16 January 2004 11:39   |
Hey Jeff,
Thanks for all of the answers.
Concerning including the service APIs in the implementation bundle, you
got me right. It's just easier to include the shared interfaces in all of
the bundles that use them than to require a central service definition
bundle (see http://161.58.208.149/devzone/members/faq/index.php#sharing
under the tech faqs on the OSGi DevZone). At least, that's true in highly
dynamic environments where service definitions may come and go. This may
not be true of general RCP usecases.
As far as explicitly placing bundle dependencies in the bundles, keeping
dependency info external to the bundles would allow for more extensible
deployment scenarios. For instance, my project (AppPlugin) uses different
implementations of a certain service for external and internal
deployments. So now I have to create two AppPlugin projects to account
for the different bundle dependencies. If this information were kept
external to the AppPlugin bundle, say in a Deployment project, I could
create keep a single AppPlugin project (since it's a lot of code) and
create two Deployment projects instead.
-Stephen
> > The
> Jeff
Re: What happened to Export-Package, etc.? [message #34053 is a reply to message #33977] |
Fri, 16 January 2004 14:18   |
I dont think that "required-bundle" tag is needed during runtime.
If you define Import-Package in your AppPlugin (and Export-Package in your
service) it should work.
Cheers
Sten
news:bu944p$542$1@eclipse.org...
> Hey Jeff,
> -Stephen
extra
in
other
dependency
style
of
the
and/or
the
My
providers
we
X
can I
> > > The
so
the
In
suggest
is
implementations
together
restart.
common
included
but
follow
> > Jeff
Re: What happened to Export-Package, etc.? [message #34084 is a reply to message #34053] |
Fri, 16 January 2004 15:36   |
That might be true, but I think the required bundle concept is a good
feature and I'd like to use it. It just seems that if the bundle
dependencies were described externally, it would facilitate more flexible
deployment scenarios. I'm not very familiar with Ecplipse Plugins, but I
thought that's what Features were for.
Of course, you could achieve the same effect in OSGi by placing the bundle
location in the properties of every service registered by that bundle.
Dependent bundles could then filter for services based on this value.
This would be pretty laborious and better left to the build environment.
Sten Ernerot wrote:
> Hi
> Cheers
> Sten
> > Hey Jeff,
> > -Stephen
> extra
> in
> other
> dependency
> style
> of
> the
> and/or
> the
> My
> providers
> we
> X
> can I
> > > > The
> so
> the
> In
> suggest
> is
> implementations
> together
> restart.
> common
> included
> but
> follow
> > > Jeff
Re: What happened to Export-Package, etc.? [message #34184 is a reply to message #34084] |
Sat, 17 January 2004 13:05   |
I agree with all that is being said here. I see it as a producer/consumer
problem. As the producer of a plugin I want to be able to specify what I
depend on. In OSGi today I can spec the packages I need but not the
implementation. The proposal is to extend that and allow me to spec the
actual bundle (id and version) I require. This allows me to clearly set
expectations and define tested configurations etc.
As a plugin consumer I may well have scenarios in which the producers
assumptions/assertions are invalid. If I am willing to take on the testing
and support load, I should be free to effectively override the declarations
that the producer made.
Our overall direction is to accomodate both of these views. To date we have
only proposed/implemented the producer's point of view. This has been done
by extending the notion of Bundle to include explicit interbundle
dependencies (Require-Bundle).
In the framework spec currently there is no place for one to define the
consumer's point of view. Personally I don't think that the framework
should define another runtime entity for this informaton. Rather, it should
expose API on PackageAdmin (or some such) where someone with a consumer's
viewpoint can specify overrides or additional dependencies. This is input
to the runtime (e.g., package/bundle resolution) but we need not spec how
this information is managed.
OSGi RFP44 contains the notion of "bundle suites". While they have not
really been defined as yet, they appear to be somewhat akin to Eclipse
features. Note that Eclipse featuers are NOT a runtime entity. They are a
delivery mechanism and they do not have the ability to specify or override
interplugin dependencies. It would be interesting to add these abilities to
features/suites but that does not seem like the end of the story. Features
are just another level of component and so again suffer from the
producer/consumer view point problems. So, while it is intresting to spec
dependencies/overrides in features, there is still a need to have global
"configuration" level control.
So rather there creating explicit support for each of these parties at the
core level of the framework, I would prefer to see a general mechanism which
simply takes a set of overrides/dependencies and uses them during
resolution. It would then be up to a configuraiton agent to observe the
data in the features, suites, config data, then prioritize and apply. We
are headed that way with our PlatformAdmin service. It is unclear how far
we will get for 3.0.
Wow, I had a lot to say!
Jeff
, it would be reasonable to add this information. In fact they are defined
by the install/update component for managing collections of plugins/bundles.
I personally very much like this characteristic.
news:bu9hvs$mpe$1@eclipse.org...
> Sten Ernerot wrote:
> > Hi
your
> > Cheers
> > Sten
> > > Hey Jeff,
you
all of
> > > bundle (see
highly
may
keeping
extensible
different
account
> > > -Stephen
> > extra
you
co-exist.
generate
match
both)
> > in
to
> > other
> > dependency
> > style
implementations
> > of
bound by
> > the
very
> > and/or
by
> > the
constraints.
> > My
> > providers
than
> > we
package
> > X
the
contain
How
> > can I
> > > > > The
bundle
> > so
than
> > the
cumbersome.
> > In
> > suggest
in
practice
> > is
> > implementations
> > together
will
> > restart.
a
> > common
> > included
hardcoding of
the
be
> > but
> > follow
Import/Export
> > > > Jeff
Re: What happened to Export-Package, etc.? [message #34322 is a reply to message #34184] |
Wed, 21 January 2004 14:41   |
That sounds reasonable. Looking forward to using it :)
> Jeff
> > Sten Ernerot wrote:
> > > Hi
> your
> > > Cheers
> > > Sten
> > > > Hey Jeff,
> you
> all of
> > > > bundle (see
> highly
> may
> keeping
> extensible
> different
> account
> > > > -Stephen
> > > extra
> you
> co-exist.
> generate
> match
> both)
> > > in
> to
> > > other
> > > dependency
> > > style
> implementations
> > > of
> bound by
> > > the
> very
> > > and/or
> by
> > > the
> constraints.
> > > My
> > > providers
> than
> > > we
> package
> > > X
> the
> contain
> How
> > > can I
> > > > > > The
> bundle
> > > so
> than
> > > the
> cumbersome.
> > > In
> > > suggest
> in
> practice
> > > is
> > > implementations
> > > together
> will
> > > restart.
> a
> > > common
> > > included
> hardcoding of
> the
> be
> > > but
> > > follow
> Import/Export
> > > > > Jeff
Re: What happened to Export-Package, etc.? [message #34943 is a reply to message #34524] |
Tue, 10 February 2004 09:27  |
Stephen,
Service binder is definitely interesting but is still orthogonal to the
explicit interbundle dependencies we propose/have. In short, all of these
are good ideas but do not completely cover each other.
Jeff
news:busi11$g3j$1@eclipse.org...
> On second thought... If you have a service managing bundle
> dependencies/overrides, then why would you put dependency information in
> the bundle manifest at all? That would be redundent, since this
> PlatformAdmin service (or whatever OSGi comes up with) has to manage all
> of this anyway. Which brings us back to storing this info externally.
> Maybe in this new Bundle Suite descriptor... Or was that what you were
> getting at?
> While we're at it, another useful service would be a Service Dependency
> Service that manages service registrations based on the status of other
> services. The authors of Oscar provide something akin to this with their
> ServiceBinder bundle
> (http://gravity.sourceforge.net/servicebinder/download.html). It's very
> useful except the dependencies are limited to design time. Any
> configuration changes require repackaging. Seems like the same solution
> you mention for managing bundle dependencies could apply to this as well
> (with the extra complication of ServiceRegistration management, of
course).
> -Stephen
Current Time: Sat Jul 19 01:18:53 EDT 2025
Powered by FUDForum. Page generated in 0.06904 seconds
