| CDateTime uses a lot of Windows handles [message #33381] |
Thu, 26 April 2007 15:07  |
Originally posted by: nicolas.bihan.free.fr
I appreciate the CDateTime widget and decided to use in my RCP application.
But I noticed that a single CDateTime with the CDT.Dropdown style use
about 400 handles in my Windows XP Pro 32 bits.
So, if I add 10 CDateTime in an Editor they use about 4000 handles !
A Windows application is limited to 10 000 handles.
If I open more than 2 editors my app freeze.
I tried with the snippets and the same...
Did you ever notice that before ?
Nicolas Bihan
| Re: CDateTime uses a lot of Windows handles [message #581372 is a reply to message #33381] |
Fri, 27 April 2007 08:31  |
interesting... :)
has anyone seen this sort of issue on GTK or Carbon? (is this an issue
on those platforms?)
Nicolas Bihan wrote:
> Nicolas Bihan
| Re: CDateTime uses a lot of Windows handles [message #581392 is a reply to message #33563] |
Fri, 27 April 2007 08:32  |
What do you mean:
a) That the widget uses that much handles
b) The limitation of handles / process
Tom
Jeremy Dowdall schrieb:
> interesting... :)
>> Hi,
>> application.
>> Nicolas Bihan
| Re: CDateTime uses a lot of Windows handles [message #581406 is a reply to message #33597] |
Fri, 27 April 2007 09:45  |
b - the limitations
Tom Schindl wrote:
> What do you mean:
> Tom
>> interesting... :)
>>> Hi,
>>> application.
>>> Nicolas Bihan
| Re: CDateTime uses a lot of Windows handles [message #581413 is a reply to message #33630] |
Fri, 27 April 2007 11:04  |
You mean it is normal that a widget uses 400 Handles? Are you leaking or
allocating so many handles? I have never looked at the code but I'd
say using so many handles is always a problem.
Tom
> b - the limitations
> Tom Schindl wrote:
>> Hi,
>> What do you mean:
>> Tom
>>> interesting... :)
>>> issue on those platforms?)
>>>> Hi,
>>>> application.
>>>> use about 400 handles in my Windows XP Pro 32 bits.
>>>> Nicolas Bihan
| Re: CDateTime uses a lot of Windows handles [message #581467 is a reply to message #33381] |
Fri, 27 April 2007 12:43  |
Originally posted by: pawwal.invalid.xx
--------------050100070801060200030500
Nicolas Bihan napisał(a):
I think I encountered similar issue. My rcp app seems to run correctly
on most of the machines. Unfortunately on some it doesn't - it throws
the "no more handles" SWTError.
I attached the log file with the stack trace - maybe it will be helpful.
For me it looks like the widget falls - in some conditions - into the
"endless" recursion witch finally ends with the error.
- pw
Content-Type: application/x-zip-compressed;
name="log.zip"
Content-Disposition: inline;
filename="log.zip"
UEsDBBQAAgAIAGt1lDYP2LVYigcAALfXAAAEAAAALmxvZ+2dS2/bOBSF1xMg /0EtslCBRtDL
smxMBnDTdGpMXoiTBrMqaIlxNJFJQw+7+fdDiZIj2XIkt+nudJFaNO8h7xX5 iXaAnHeTs8lk
fHWpmLreP9btY1NXDHtom0OzpxlmTzne79/hAfXCYBFTbZoGoT/2T1L2xPiK HR78R5ZEW9Io
Djg7MTRH07/rxrqZ+Tw6maRMuQi8iMfPcULnsTJmnnZ48Inz5JwTn0aKx1mc EJbEQ+VqcrIK
mGV+VEY3p19PfrjOR+V+3XZ5frIIv1+fHx6c8vmcMP84DBhVSDRL5zSPV455 rOS9lePV+hWJ
vEdFaB0eHB68O7u8vflX4dFMK7NKA23Fo6cpZaKbrZibdbOGpqHZri2CL0Rl R3+fKdcRn4ZZ
Mtzz0iiivrJ6pEwJ2JI/BWwmUvKp8hDxubII09lxwIbK+11DvhfVeDe5HZ3+ o+hF6ULCZtoo
isjzmPn0x1WaXD184inz47MfHl0kotrDrPMfJKllEq8SbRX4M5rE2i0RM9TE ywkNqZeFqLIp
G2Fo6o77YVvgvwfiUW0Z0JW4p1LiW35RE/oiErvPh1GrXXLh3qBdd5JEqZek omwN4urWu7nu
wDEbdEUdA5bQiJFQG03jJCLei9KERsvA26jBzl6yLKbeMkosu8faaXbfWUWH p5FHxcJYBmJR
i1tBFueBWPFMZKy2dM7HNmzjjcYmnugUH+ndhrXeaNgjQ6w9seVXI/HmkiTU 7zR+z24Z/r7c
KEeuFqVMXV/LeEd3GgQ8HtGsdxLMqTYhD/QmZeJO5AKVy1zB6nedgfYQRPR+ I8mt+XROSCod
9bX4kYZhg6LsUCxNx7U+tGz55wX1y0WnPQpAhvRMYFhs09o78r47dotcHiqZ EQuWS6VKo0zX
aVGRoKgoFA1yV5vuL4X3zF8Kt9oq+pmKhUSypSukLr6PTm/H30a3Z2q1XVaz 128rxCS7yTUV
2SLj+0bb7TjlLIl4WGwysYk8tWySy9i07T3Sqcg0ZGMNOmVTEakm41itMwni RUiea7MomnIJ
Wzd7OyTW+yh/umtXE21Cky/cS2P1UiSxpMoFTR6537GcD1wgSYbXytm3eh0V 4nL4WrxpGU0C
jE7TkKw1PF/s+BxS5YNJHG2mPNO8WtCXx5VslcB0rH10Tz+LV7fZq1LzpSXX cy3n5+cpzm5J
Rvjs5ucbLG6asmPrPzflBvmN2du68dOzP7JqkGyYuGkMAMk3hKTrApKAJCAJ SAKSgCQgCUgC
koAkIAlIApKAJCAJSAKSgCQgCUgCkoAkIAlIApKAJCAJSAKSgCQgCUgCkoAk IAlIApKAJCAJ
SAKSgCQgCUgCkoAkIAlIApKAJCAJSAKSgCQgCUgCkoAkIAlIApKAJCAJSAKS gCQgCUgCkoAk
IAlIApKAJCAJSAKSgCQgCUgCkoAkINkFko98Jf8+9V6YrKYtAPItiAOxrBuq YTndqlERqVbD
do3fREsDtAQtQUvQch9aXlP6dEHjmMzofSdeviqhisviUOgOOqYRUeKPmJ9d ksR7rOdiDhoP
gc0mCFHK8oV6zvli0/3AGBj2PkJ34y0Ft+92VvBEVgkVad2kbN26qWg3YkQI XockEcf1+d14
h1ClQ/FUKZUWoaDjXJunYRI88fkiFVPTgphOtdFiEQZevlRzt4nqdZHgLr+K dYKlcUU5fmEN
wTOPjUxzq734iOG2OWGsRyA+WWRxZ7KXmOQ5SUXK0iKjMme1oUfBxbcYLE5I lOwcw2lNaEN6
kskVNh8bTcWe1d9Y0eiX7iFxKm44fcisTjS5w+UGH+VuLDwaz8WiyR2CqN6I gD0E1DvpwKRI
R5UGgc80pDMhwmZ7irwYEJVSUuDVoK1qhuV9vCABK0K/RGROM9sjNW+UTwTL 6SYxJXHgic1Z
iTVdvVtsVAsb9PvdwubiRzUuf5LvcJBS7Mw5qsE3qqfrFd+oOyaPPL5CM4Iq oUCoQktPp9fU
9Q7ql1yZizQUOUZctZXafDpM7m/PoohHw+2gpoeJ6K7RrL+avZJ3rnkv7ept Dvr79HY6Hrpk
YPXEZHf+nkUy/2ued/2c0tPdVo35gsdBQjdVyubi8dzb47hTU9o68HT9PFRT qZx4uuRUrUth
8FWvi9l2Gp14onOYn71rMpX2V1ynXq9MIbVdmX6/U2X+DFiQ/FWtSTNBukRa vf5OmzN5YNQK
8yY59zxUrfo52a65l0I9uPHoKYP9gIR8lh38sv/L6OJKFt8w7Y5j8+wja3Xk vts+cnFKLYbM
JHLWqPX2YqfvrkKaBOHauytfOsXnxZKXau3Nwn1rDzOwXXLdjx9tzmIDOIvh YzucxfCbIPwm
CN9t4rtNfLcJSAKSgCQgCUgCkoAkIAlIApKAJCAJSAKSgCQgCUgCkoAkIAlI ApKAJCAJSAKS
gCQgCUgCkoAkIAlIApKAJCAJSAKSgCQgCUgCkoAkIAlIApKAJCAJSAKSgCQg CUgCkoAkIAlI
ApKAJCAJSAKSgCQgCUgCkoAkIAlIApKAJCAJSAKSgCQgCUgCkoAkIAlIApJw FoOzGGgJWoKW
cBaDsxicxeAsBmcxOIv9dmex/wFQSwECFAAUAAIACABrdZQ2D9i1WIoHAAC3 1wAABAAAAAAA
AAABACAAAAAAAAAALmxvZ1BLBQYAAAAAAQABADIAAACsBwAAAAA=
--------------050100070801060200030500--
FUDForum. Page generated in 0.05429 seconds
