Home » Eclipse Projects » Eclipse Platform » How to register form section toolbar?
How to register form section toolbar? [message #336974] Fri, 17 July 2009 13:09 Go to next message
I attached a toolbar to a section in a form like so:
SectionPart part = ...
ToolBarManager manager = new ToolBarManager(SWT.FLAT);
ToolBar toolbar = manager.createControl(part.getSection());
manager.update(true);
part.getSection().setTextClient(toolbar);
Now is there a way to register this toolbar so items can be contributed
via the plugin.xml (perhaps similar to the way context menus can be
registered)?
Re: How to register form section toolbar? [message #336979 is a reply to message #336974] Fri, 17 July 2009 17:39 Go to previous messageGo to next message
> registered)?
You have to do that yourself using the MenuManager.populate* method.
Don't forget to unpopulate and dispose your toolbar manager.
I use the menuContributions URI: section:id, where id is an id that your
section represents.
Phil
Re: How to register form section toolbar? [message #336980 is a reply to message #336979] Fri, 17 July 2009 20:32 Go to previous messageGo to next message
Thanks; but where do I get the MenuManager from (I'm in an EditPart)?
Re: How to register form section toolbar? [message #336983 is a reply to message #336980] Sat, 18 July 2009 06:35 Go to previous messageGo to next message
you can call getSite().getService(IMenuManager.class);
Re: How to register form section toolbar? [message #337005 is a reply to message #336983] Mon, 20 July 2009 15:01 Go to previous messageGo to next message
Still having some trouble: The IMenuManager (from
org.eclipse.jface.action.*) doesn't have a "populate" method. There is a
"fill" method, but then how is the ID specified? Also, the code above is
returning null (this is in an RCP application)...
Re: How to register form section toolbar? [message #337009 is a reply to message #337005] Mon, 20 July 2009 19:22 Go to previous messageGo to next message
For the record:
IMenuService service = (IMenuService)
getSite().getService(IMenuService.class);
service.populateContributionManager(toolbarManager, "section:foo");
Re: How to register form section toolbar? [message #337013 is a reply to message #337009] Tue, 21 July 2009 02:14 Go to previous message
Eric Jain wrote:
> For the record:
Thats the one :) Good luck!
Previous Topic:Which setting files should/must/shouldn't be under version control?
Next Topic:JFace 3.3 TableViewer, DialogCellEditor, Tabhandling
Current Time: Thu Oct 23 01:49:12 EDT 2025
Powered by FUDForum. Page generated in 0.04615 seconds
