| Home » Archived » EPF » Re-use Rich Text Editor component on Mac?
 Goto Forum:|
| Re-use Rich Text Editor component on Mac? [message #33670] | Fri, 22 June 2007 13:08  |  |
| Eclipse User  |  |  |  |  | Hi,  I've just discovered the EPF project and the Composer tool.  Nice job!  I also found the handy Rich Text Editor plug-in component which I
 managed to link to and re-use in my RCP application on Windows.  Can
 this Rich Text Editor plugin be used on a Mac or is it OS dependent?  If
 not, what needs to be done to get it to work on Mac OS X?  If feasible I
 might help.
 PB
| Re: Re-use Rich Text Editor component on Mac? [message #42996 is a reply to message #42965] | Mon, 08 October 2007 16:53   |  |
| Eclipse User  |  |  |  |  | Eric Rizzo wrote: > Phillip Beauvoir wrote:
 >> I've extrapolated the following bundles that are needed for the RTE
 >> (version 1.2) to work in a RCP application:
 >> org.eclipse.epf.common
 >> org.eclipse.epf.richtext
 >> org.eclipse.epf.ui
 >> I have a RichTextEditor class instantiated in an Editor View together
 >> with a populated RichTextToolBar.  This all works fine on Windows XP
 >> and Ubuntu 7 (apart from a bug I noticed on the Toolbar layout).
 > Can you share the details of how you implemented RichTextEditor in a
 > non-EPF application? I'm in the process of doing so and would like to
 > hear any lessons that were learned by someone who has already been down
 > this path.
 > Eric
 Hi, yes:
 For a start it only works on Windows and Linux, the Mac is going to need
 some Safari-specific voodoo added to the rte.js and rendering files in
 the rte folder.
 The plug-in I put together is here in CVS:
 Host:       tencompetence.cvs.sourceforge.net
 Path:       /cvsroot/tencompetence
 Module:	    rte/org.eclipse.epf.richtext
 I then instantiate a RTE control thus:
 class RTE
 extends RichTextEditor
 public RTE(Composite parent, int style, IEditorSite editorSite,
 String basePath) {
 super(parent, style, editorSite, basePath);
 public RTE(Composite parent, int style, IEditorSite editorSite) {
 super(parent, style, editorSite);
 public void fillToolBar(IRichTextToolBar toolBar) {
 toolBar.addAction(new FontStyleAction(this));
 toolBar.addAction(new FontNameAction(this));
 toolBar.addAction(new FontSizeAction(this));
 toolBar.addSeparator();
 toolBar.addAction(new CutAction(this));
 toolBar.addAction(new CopyAction(this));
 toolBar.addAction(new PasteAction(this));
 toolBar.addAction(new ClearContentAction(this));
 toolBar.addAction(new BoldAction(this));
 toolBar.addAction(new ItalicAction(this));
 toolBar.addAction(new UnderlineAction(this));
 toolBar.addAction(new SubscriptAction(this));
 toolBar.addAction(new SuperscriptAction(this));
 toolBar.addAction(new TidyActionGroup(this));
 toolBar.addAction(new AddOrderedListAction(this));
 toolBar.addAction(new AddUnorderedListAction(this));
 toolBar.addAction(new OutdentAction(this));
 toolBar.addAction(new IndentAction(this));
 toolBar.addAction(new FindReplaceAction(this) {
 public void execute(IRichText richText) {
 richText.getFindReplaceAction().execute(richText);
 toolBar.addAction(new AddLinkAction(this));
 toolBar.addAction(new AddImageAction(this));
 toolBar.addAction(new AddTableAction(this));
 And then add it to an EditorPart.
 PB
| Re: Re-use Rich Text Editor component on Mac? [message #46307 is a reply to message #42996] | Wed, 05 December 2007 04:00   |  |
| Eclipse User  |  |  |  |  | Originally posted by: yannick.lizzi.silogic.fr
 >>> org.eclipse.epf.ui
 >> down this path.
 >> Thanks,
 >> Eric
 > Hi, yes:
 > the rte folder.
 > class RTE
 > String basePath) {
 >     @Override
 >             @Override
 > PB
 Hi all,
 You may be interested to know that the RichTextEditor seems to work now
 with the  new the version of Safari (3.0).
 I'm also doing an RCP application that reuses the RichTextEditor. The
 buttons now works in the wysiwyg tab.
 Best regards
 Yannick
| Re: Re-use Rich Text Editor component on Mac? [message #47888 is a reply to message #46307] | Sat, 09 February 2008 20:04  |  |
| Eclipse User  |  |  |  |  | Buttons work but the editor section fail to refresh its contents.
 Also, save and close key binding doesn't work in the editor.
 (Of cource, it works fine on Windows)
 There can be alternative approach. Use firefox instead of Safari.
 Rich text editor uses platform specific web browser instance.
 new Borwser(parent, SWT.NONE)
 now eclipse 3.3 support firefox everywhere.
 new Browser(parent, SWT.MOZILLA)
 Unfortunately, when I change its style, my eclipse app. crashes caused by
 jni call (3.4M4) or unknow problem (3.3.1.1). SWT mozilla example works
 fine ... If SWT fix this unstable behavior, we can use rich text without
 pain.
 Yes, that is only my hope. But, there is an alternative approach.
 1) Support safari on mac
 2) Or, support mozilla everywhere
| Re: Re-use Rich Text Editor component on Mac? [message #579345 is a reply to message #33670] | Tue, 26 June 2007 10:10  |  |
| Eclipse User  |  |  |  |  | Phillip Beauvoir wrote: > Hi,  I've just discovered the EPF project and the Composer tool.  Nice
 > might help.
 > PB
 I tried it on a Mac.  It doesn't barf or crash, but formatting does not
 work.
 PB
| Re: Re-use Rich Text Editor component on Mac? [message #579702 is a reply to message #33891] | Fri, 06 July 2007 16:50  |  |
| Eclipse User  |  |  |  |  | Mac? Isn't that a telephone? :-)
 Sorry, we currently do not support Macs and have not tested it in that
 environment, yet.
 Peter.
 "Phillip Beauvoir" <p.beauvoir@dadabeatnik.com> wrote in message
 news:f5r6oe$efr$1@build.eclipse.org...
 >> managed to link to and re-use in my RCP application on Windows.  Can this
 >> Rich Text Editor plugin be used on a Mac or is it OS dependent?  If not,
 >> what needs to be done to get it to work on Mac OS X?  If feasible I might
 >> help.
 >> PB
 > work.
 > PB
| Re: Re-use Rich Text Editor component on Mac? [message #579788 is a reply to message #34378] | Sat, 07 July 2007 08:57  |  |
| Eclipse User  |  |  |  |  | Peter Haumer wrote: > Mac? Isn't that a telephone? :-)
 > environment, yet.
 > Peter.
 I realise that.  I'm trying to get it to work on a Mac.  What I need is
 a better understanding of how this Rich Text Editor is working.  Looks
 like some JavaScript calls to the Browser component, Safari on a Mac, I
 reckon.  I'm trying to figure out why these calls don't do anything on a
 Mac.  I reckon I'll get there in the end, but it would be quicker with
 some help and advice.
| Re: Re-use Rich Text Editor component on Mac? [message #579859 is a reply to message #34512] | Sun, 08 July 2007 17:14  |  |
| Eclipse User  |  |  |  |  | I see. I just wanted to say that most likely no one in our team has tried this yet. So the question needs to be answered by the rest of the community.
 As you might have see already, the rte.js file is the collection of scripts
 realizing the editor against the IE control.
 Peter.
 news:f6o2jc$nc0$1@build.eclipse.org...
 >> environment, yet.
 >> Peter.
 > I realise that.  I'm trying to get it to work on a Mac.  What I need is a
 > better understanding of how this Rich Text Editor is working.  Looks like
 > some JavaScript calls to the Browser component, Safari on a Mac, I reckon.
 > I'm trying to figure out why these calls don't do anything on a Mac.  I
 > reckon I'll get there in the end, but it would be quicker with some help
 > and advice.
| Re: Re-use Rich Text Editor component on Mac? [message #579874 is a reply to message #34512] | Mon, 09 July 2007 01:30  |  |
| Eclipse User  |  |  |  |  | >> Sorry, we currently do not support Macs and have not tested it in that >> environment, yet.
 You may want to check out the following rich text editor which is
 supposed to work in all browser versions:
 http://koivi.com/WYSIWYG-Editor/
 It might help give you some guidance on why the EPF rich text editor
 isn't working on Safari.
 Dave
| Re: Re-use Rich Text Editor component on Mac? [message #579888 is a reply to message #34645] | Mon, 09 July 2007 10:27  |  |
| Eclipse User  |  |  |  |  | David Carver wrote: >>> Sorry, we currently do not support Macs and have not tested it in
 >>> that environment, yet.
 >> is a better understanding of how this Rich Text Editor is working.
 >> Looks like some JavaScript calls to the Browser component, Safari on a
 >> Mac, I reckon.  I'm trying to figure out why these calls don't do
 >> anything on a Mac.  I reckon I'll get there in the end, but it would
 >> be quicker with some help and advice.
 > Dave
 That's a great link.  Many thanks.
| Re: Re-use Rich Text Editor component on Mac? [message #579907 is a reply to message #34612] | Mon, 09 July 2007 10:46  |  |
| Eclipse User  |  |  |  |  | Peter Haumer wrote: > I see. I just wanted to say that most likely no one in our team has tried
 > Peter.
 >>> environment, yet.
 >>> Peter.
 >> and advice.
 Thanks for the info.  I'll carry on working on it.  This is what I've
 got so far:
 org.eclipse.epf.ui
 with a populated RichTextToolBar.  This all works fine on Windows XP and
 On a Mac you can type plain text into the wysiwyg tab but the toolbar
 buttons/commands do nothing.  You can type raw HTML code into the HTML
 window and it is rendered properly when switched to the other tab.
 So it seems that it all kind of works on a Mac, if we could iron out a
 few wrinkles.
| Re: Re-use Rich Text Editor component on Mac? [message #580130 is a reply to message #34645] | Fri, 13 July 2007 15:05  |  |
 > Dave
| Re: Re-use Rich Text Editor component on Mac? [message #584361 is a reply to message #34713] | Mon, 08 October 2007 16:37  |  |
| Eclipse User  |  |  |  |  | Phillip Beauvoir wrote: > I've extrapolated the following bundles that are needed for the RTE
 > org.eclipse.epf.ui
 this path.
 Eric
| Re: Re-use Rich Text Editor component on Mac? [message #584376 is a reply to message #34713] | Mon, 08 October 2007 16:37  |  |
 > org.eclipse.epf.ui
 this path.
 Eric
| Re: Re-use Rich Text Editor component on Mac? [message #584387 is a reply to message #42965] | Mon, 08 October 2007 16:53  |  |
 >> org.eclipse.epf.ui
 > this path.
 > Eric
 Hi, yes:
 the rte folder.
 class RTE
 String basePath) {
 PB
| Re: Re-use Rich Text Editor component on Mac? [message #585832 is a reply to message #42996] | Wed, 05 December 2007 04:00  |  |
 >>> org.eclipse.epf.ui
 >> down this path.
 >> Thanks,
 >> Eric
 > Hi, yes:
 > the rte folder.
 > class RTE
 > String basePath) {
 >     @Override
 >             @Override
 > PB
 Hi all,
 Best regards
 Yannick
| Re: Re-use Rich Text Editor component on Mac? [message #588395 is a reply to message #46307] | Sat, 09 February 2008 20:04  |  |
 pain.
 Current Time: Fri Oct 31 16:13:59 EDT 2025
 Powered by FUDForum . Page generated in 0.10332 seconds |
