Home » Eclipse Projects » Eclipse Platform » Enable/Disable plugin.xml generated menus
Enable/Disable plugin.xml generated menus [message #336638] Thu, 25 June 2009 12:32 Go to next message
Hi!
This is my first email to this list.
I'm working on qbzr-eclipse, a plugin to integrate qbzr [
http://bazaar-vcs.org/QBzr ] with eclipse.
Right now I'm working on refectoring the main qbzr-eclipse menu, which
used to be just a long plain menu. Now it's divided in submenus.
What I need to do now is to enable/disable some menuitems according to one
simple variable: the selected project is versioned in bazaar [
http://bazaar-vcs.org/ ] or not.
I've tried like 20 ways of doing this...but I can't find a way to actually
access the menuitem from inside the plugin's code. None of the examples I
found on the web helped me =(
ANY input on how to do this would be great, I have no problem on
refactoring the code I've already written.
Thanks!
Re: Enable/Disable plugin.xml generated menus [message #336640 is a reply to message #336638] Thu, 25 June 2009 14:27 Go to previous messageGo to next message
Originally posted by: christopher.oezbek.fu-berlin.de
Hi Javier,
> one simple variable: the selected project is versioned in bazaar [
> actually access the menuitem from inside the plugin's code.
How about doing it the other way around: In the associated action of the
menuitem you set the action to enabled/disabled.
For instance we have a action directly in the popup menu for IResources
<extension
point="org.eclipse.ui.popupMenus">
<objectContribution
adaptable="true"
id="de.fu_berlin.inf.dpp.ui.popupmenu"
objectClass="org.eclipse.core.resources.IResource">
<action
class="de.fu_berlin.inf.dpp.ui.actions.NewSessionAction"
icon="icons/transmit.png"
id="Saros.action1"
label="Share project...">
</action>
In the NewSessionAction, we then enable/disable based on the selection:
public class NewSessionAction implements IObjectActionDelegate {
public void selectionChanged(IAction action, ISelection selection) {
// Set to enabled if not already in a session
action.setEnabled(getProject(selection) == null);
Hope this helps,
Christopher
Re: Enable/Disable plugin.xml generated menus [message #336643 is a reply to message #336640] Thu, 25 June 2009 15:57 Go to previous messageGo to next message
> Hi Javier,
Hi!
> <extension
> <objectContribution
> adaptable="true"
> <action
> id="Saros.action1"
> </action>
> Hope this helps,
> Christopher
That sounds like a very simple solution.
My "problem" is that i'm actually using commands and handlers, not actions.
IE:
<handler
class="org.bazaar_vcs.qbzr_eclipse.handlers.InitCommandHandler "
commandId="qbzr_eclipse.commands.initCommand">
</handler>
is the handler
and then
<command
icon="icons/init.png"
id="qbzr_eclipse.menus.initCommand"
mnemonic="I"
Is the command.
Any Idea how to move forward from here?
Re: Enable/Disable plugin.xml generated menus [message #336648 is a reply to message #336643] Fri, 26 June 2009 01:08 Go to previous messageGo to next message
Good, then you can use the activeWhen of the handlers. When there are
no active handlers, then the command will be disabled.
See: http://wiki.eclipse.org/Platform_Command_Framework
- Prakash
http://blog.eclipse-tips.com
Re: Enable/Disable plugin.xml generated menus [message #336669 is a reply to message #336638] Fri, 26 June 2009 11:24 Go to previous message
When your project is versioned under qbzr, you should set a property on
the project.
Then you can use your visibleWhen to test that property. There is an
objectContribution example at
http://wiki.eclipse.org/Menu_Contributions/IFile_objectContr ibution
http://wiki.eclipse.org/Command_Core_Expressions#Property_Te sters has a
list of property tester, including one that can work on a persistent
property on a project.
PW
Paul Webster
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Previous Topic:Eclipse 3.5M6 Update behind proxy not working anymore
Next Topic:WHere to download releng basebuilder for 3.4.2
Current Time: Wed Oct 29 03:38:33 EDT 2025
Powered by FUDForum. Page generated in 0.03387 seconds
