[ATL] ATL transform performance problems [message #33656] |
Tue, 24 April 2007 05:29  |
Originally posted by: paul.gribben.gmail.com
I've written an ATL transform that creates a weave model (AMW) from 2
input UML2 model files. For small UML files it all works well, however for
large files (15MB+) the transform runs very, very slowly. I've added trace
output so I know it is processing the transform, however it got less than
half way after about 1 hour. I wrote the same transform in Java and it
took less than 2 minutes to complete.
There are 2 questions:
1. Is ATL expected to scale to files of this size without this sort of
performance degradation?
2. Has anyone written an ATL to Java conversion tool (perhaps this is
heracy for MDA!)
Paul
Re: [ATL] ATL transform performance problems [message #33758 is a reply to message #33656] |
Tue, 24 April 2007 06:00   |
Originally posted by: mikael.barbero.gmail.com
Hi Paul,
Find my answers below:
Paul Gribben wrote:
> for large files (15MB+) the transform runs very, very slowly. I've added
> trace output so I know it is processing the transform, however it got
> less than half way after about 1 hour. I wrote the same transform in
> Java and it took less than 2 minutes to complete.
We do not have so much large files for testing, so we can not say much
about it. However, ATL's global algorithm deals quite good with big
models ONLY if it is fully declarative. So my question is: does your
transformation contain a lot of called rules? Does it make a lot of
allInstances() calls (this is not a imperative feature, but a real
bottleneck for large transformation)?
> heracy for MDA!)
Yes, it is heracy :) Moreover, I don't know anyone who tried to play
such a burning soul game !
> Thanks
> Paul
Mikael
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] ATL transform performance problems [message #33826 is a reply to message #33792] |
Tue, 24 April 2007 08:23   |
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
Hi Paul,
I have been testing some variants of the Cartesian product matching transformation, also
because of the high number of combinations for large models.
What I have been doing is to restrict as early as possible the number of combinations, by
matching only elements of a given type (e.g., an EClass x EClass, EAttribute x EAttribute,
etc.). Usually I have fairly good results for EClasses.
I don't think there is a 'best' approach. This depends a lot on the application scenario
of the weaving model created by your match.
For instance, if you want to compare two versions of metamodels with a lot of similar
elements, you can use lazy (or called) rules to match EAttributes and EReference. However,
this is a trade-off between the accuracy of the result and the performance of the
transformation.
Marcos.
Paul Gribben wrote:
> Hi Mikael,
> Thanks for your answers. I started by defining a fully declarative
> transformation. Given that I'm trying to construct a match weave I
> followed the approach shown in the AMW 'cartesian product'
> transformation. However this causes the transform to create an CP
> explosion of combinations (as you might expect), and dispite applying
> all possible OCL filters on the 'from' elements the transform takes even
> longer that my more recent attempt (which uses more imperative approach).
> So my imperative approach creates collections of specific types that I
> want to match from each input model. This at least does allow the
> transform to process, but very slowly.
> Is there a better declarative approach I should be using?
> Thanks
> Paul
Re: [ATL] ATL transform performance problems [message #34980 is a reply to message #33945] |
Sat, 28 April 2007 13:52  |
An additional optimization would be to name your two source metamodels
differently (e.g., UMLLeft and UMLRight). This way, ATL will not even
try to match two elements from the same model, which will save some
testings.
For instance:
create OUT : AMWExt from left : UMLLeft, INRight : UMLRight;
from
a : UMLLeft!Class, b : UMLRight!Class (
a.hasStereotype('sometype') and b.hasStereotype('sometype')
and a.name = b.name )
Frédéric Jouault
Marcos Didonet Del Fabro wrote:
> Hello,
> Considering you have a left and a right UML models, you match all the
> elements of the left
> model with all the elements of the right model, but it also matches
> between the left
> elements. The transformation rule does not make the distinction that "a
> : UML!Class" is from the left model or that "b : UML!Class" is from the
> right model.
> You may add in the guard some condition that tests if "a" is from the
> left and "b" is
> from the right.
> Regards,
> Marcos.
> Paul Gribben wrote:
>> Hi Marcos,
>> I did restrict my matches so that they only consider UML classes that
>> have particular stereotypes. In the model this still results in about
>> 2000 elements for each of the 2 input UML models. In the declarative
>> approach did something like this:
>> from
>> a : UML!Class, b : UML!Class (
>> where hasStereotype is a helper returning true if
>> self.getAppliedStereotypes()->exists(s | s.name = name)
>> With the imperative approach, I defined collections using helpers like
>> this:
>> Sequence(UML!Class) = UML!Class.allInstancesFrom('left')->select(s |
>> s.hasStereotype('sometype'))
>> then iterated through the left model collection looking for matches in
>> the corresponding right collection.
>> Thanks for taking a look anyway.
>> Paul
FUDForum. Page generated in 0.66235 seconds
