Home » Eclipse Projects » Eclipse Platform » Is there any command to change font size in the platform?
Is there any command to change font size in the platform? [message #336337] Tue, 09 June 2009 03:02 Go to next message
Hello,folks!
In Eclipse 3.5,
There is a font size change feature on the welcome view.
Is there similar feature in Eclipse?
In Japan, people want to use Eclipse during presentation,
They want to change font to adjust on the projector at the presentation.
Yes, I know the plug-in Font Size Changer for this purpose.
http://flymewiththeeclipseway.blogspot.com/2009/03/font-size -changer-it-is-good-plug-in.html
I would like to do this in default Eclipse.
Could someone suggest an idea for this use case?
Re: Is there any command to change font size in the platform? [message #336340 is a reply to message #336337] Tue, 09 June 2009 03:48 Go to previous messageGo to next message
Originally posted by: aurelien.pupier.esial.net
Hiroki Kondo a écrit :
> Hello,folks!
> In Eclipse 3.5,
Look in Window->Preferences->General->Appearance->Colors and Font
select the target ou want to change :
like Basic->text Font thne click Change and choose your font ;)
Like that you need to change various and multiple fonts by hand (not so
much finally) I don't kniow if we can change all in one time.
hope this will help
Aurélien Pupier
Re: Is there any command to change font size in the platform? [message #336379 is a reply to message #336340] Tue, 09 June 2009 21:51 Go to previous messageGo to next message
Thank you for reply and tell me how to change font size at
Preferences,Aurélien.
I'm looking for how to change font's size using short-cut.
Do you know some OS supports zoom-in and zoom-out using short-cut?
I want to do this on Eclipse in the presentation.
Because sometimes I explain some code in the presentation with my friends.
Someone will say "Excuse me,Could you change font size to be more bigger?I
can't read these code."
"OK. I'll change it...".
I want to change the size using short-cut,because it is smart!
How do you think this? Is it new Eclipse's enhancement?
> Like that you need to change various and multiple fonts by hand (not so much
finally) I don't know if we can change all in one time.
> hope this will help
> Aurélien Pupier
Re: Is there any command to change font size in the platform? [message #336391 is a reply to message #336379] Wed, 10 June 2009 03:27 Go to previous message
> bigger?I can't read these code."
You can set custom key shortcut :
Window->Preferences->General->Keys
now you have to found the corresponding command :s
>> Hi,
>> so much
>> hope this will help
>> Aurélien Pupier
Previous Topic:Automatic updates fail: No repository found containing ...
Next Topic:Avoiding a selection change during a drag
Current Time: Sun Oct 19 13:35:13 EDT 2025
Powered by FUDForum. Page generated in 0.03528 seconds
