| Replacing the debug perspective with my own [message #336351] | Tue, 09 June 2009 09:02  |  |
| Eclipse User  |  |  |  |  | Originally posted by: subs._nospam_consertum.com
 I wish to replace the standard Debug perspective
 (org.eclipse.debug.ui.DebugPerspective) wiht my own.
 I have created the perspective and it works as I want, but I can't work
 out how to make it the 'default'. I can change it through the UI, but I
 want to set it programmatically.
 Can somebody point me in the right direction?
 Derek
| Re: Replacing the debug perspective with my own [message #336398 is a reply to message #336387] | Wed, 10 June 2009 04:01   |  |
 Hi Eric,
 Thanks for the tip, but that doesn't help. See comments below:
 Eric Rizzo wrote:
 > Derek wrote:
 >> Hi,
 >> work out how to make it the 'default'. I can change it through the UI,
 >> but I want to set it programmatically.
 > I'm not 100% sure what you mean by making it the "default." Do you mean
 > that whenever you launch a program in debug mode, it should switch to
 > your custom perspective?
 Yes, this is what I want.
 If so, you can control that in the Preferences;
 > just type "perspectives" in the search field of the Preferences dialog
 > and you'll find the appropriate page.
 No, I want to do this programmatically. I want this behavior for the
 users of my Eclipse-based product.
 > By the way, another option would be to just customize the Debug
 > perspective the way you want it and then save it under the same name.
 > Hope this helps,
 > Eric
 Derek
| Re: Replacing the debug perspective with my own [message #336452 is a reply to message #336398] | Fri, 12 June 2009 13:40  |  |
| Eclipse User  |  |  |  |  | Originally posted by: eclipse-news.rizzoweb.com
 Derek wrote:
 > Hi Eric,
 > Eric Rizzo wrote:
 >> Derek wrote:
 >>> Hi,
 >>> UI, but I want to set it programmatically.
 >> mean that whenever you launch a program in debug mode, it should
 >> switch to your custom perspective?
 I would take a look at the code of that preferences page to see what it
 does behind the scenes. Use Plug-in Spy to find the class that
 implements the preferences page.
 http://www.eclipse.org/pde/incubator/spy/
 Hope this helps,
 Eric
FUDForum. Page generated in 0.06014 seconds
