| Adding console filter to external tool? [message #336045] |
Fri, 15 May 2009 00:25  |
Originally posted by: fraserofthenight.gmail.com
Hi all,
I apologize if this question has been asked before. Is there any easy
way to create a plugin that adds links to the console based on regular
expressions? I only want to do this on certain programs. The only way I
can think of is to create a new external tools launch delegate, copy
over all of
org.eclipse.ui.externaltools.internal.prohgram.launchConfigu ration, and
modify just the console (I'm looking through the source to see how to do
that right now). I'm sure there's an easier way, though.
All the best,
Robert
| Re: Adding console filter to external tool? [message #336049 is a reply to message #336045] |
Fri, 15 May 2009 04:16   |
Robert Fraser wrote:
> Hi all,
> over all of
> All the best,
> Robert
Okay, now is there any quick way to search for a file, given a path that
might be somewhere in the workspace? So if I have a path:
.../candy/compiler/parser.d
.... is there a quick way to find that file?
Robert
| Re: Adding console filter to external tool? [message #336061 is a reply to message #336060] |
Mon, 18 May 2009 02:39  |
>> that might be somewhere in the workspace? So if I have a path:
> You'll probably have to construct an IPath (instance of
> org.eclipse.core.runtime.Path) and then get the IFile for that path.
> This section of the Plug-in Development help will probably be useful:
> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/resInt.htm
> The gist is that, once you have the IPath, get the IWorkspaceRoot via
> ResourcesPlugin.getWorkspace().getRoot()
> and from the root you can get files.
> I don't think you can use relative paths like above as-is; you'll have
> to figure a way to make it an absolute path (absolute in the workspace).
> Hope this helps,
> Eric
Yup; I know about IPath, etc., the problem is how to search the
workspace for the relative path. I've found a sort-of solution that
works in 95% of cases, and short of implementing an entire search
indexer that's about as good as I think I'll get.
Thanks!
FUDForum. Page generated in 0.03543 seconds
