Home » Eclipse Projects » Eclipse Platform » Key binding sequence in label
Key binding sequence in label [message #335802] Thu, 30 April 2009 11:52 Go to next message
When I define a key binding via org.eclipse.ui.bindings extension point,
the shortcut sequence does not show up in the label of the menu item. How
can I add the sequence to the label? I am pretty sure sequence appears
there not because of direct manipulation of the label.
thanks,
Alex
Re: Key binding sequence in label [message #335803 is a reply to message #335802] Thu, 30 April 2009 13:06 Go to previous messageGo to next message
Aleksandr Kravets wrote:
> Hello,
> How can I add the sequence to the label? I am pretty sure sequence
> appears there not because of direct manipulation of the label.
> thanks,
> Alex
Is there a conflict for your keybinding?
- Prakash
http://blog.eclipse-tips.com
Re: Key binding sequence in label [message #335804 is a reply to message #335803] Thu, 30 April 2009 13:14 Go to previous messageGo to next message
I don't think so, the binding is M1+I D. How would I know if there is a
conflict?
I also tried M1+Z D and same result.
Re: Key binding sequence in label [message #335806 is a reply to message #335802] Thu, 30 April 2009 13:32 Go to previous messageGo to next message
> Hello,
How are you defining your menu item? If using org.eclipse.ui.menus, it
should show up for free. If you are using org.eclipse.ui.actionSets you
would need to set the definitionId. If you are creating IActions
programmatically, you would use setActionDefinitionId(*) (but then how
are you tying this to the command?)
PW
Paul Webster
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Re: Key binding sequence in label [message #335807 is a reply to message #335806] Thu, 30 April 2009 13:43 Go to previous messageGo to next message
Like this: http://pastebin.com/m1520cff
Re: Key binding sequence in label [message #335808 is a reply to message #335807] Thu, 30 April 2009 13:49 Go to previous messageGo to next message
Those are the requisite command and binding definitions ...
How are you defining the menu item? That's what determines how the
command could show up.
PW
Paul Webster
Re: Key binding sequence in label [message #335809 is a reply to message #335808] Thu, 30 April 2009 13:58 Go to previous messageGo to next message
Right, here it is: http://pastebin.com/m738e9f0
Re: Key binding sequence in label [message #335810 is a reply to message #335809] Thu, 30 April 2009 14:09 Go to previous messageGo to next message
Ah, OK. objectContributions don't support keybindings, as they are only
active as long as the context menu is open.
PW
Paul Webster
Re: Key binding sequence in label [message #335811 is a reply to message #335810] Thu, 30 April 2009 14:35 Go to previous message
I see. Thanks Paul.
Previous Topic:Export plugin
Next Topic:[CNF] Enablement with resources
Current Time: Fri Oct 03 06:14:42 EDT 2025
Powered by FUDForum. Page generated in 0.04912 seconds
