Home » Eclipse Projects » DSDP - Target Management » How to get remote process PID
| How to get remote process PID [message #33192] |
Wed, 11 March 2009 14:55  |
Does RSE SDK provide API to query the remote process PID?
If I have IHost object, which API can I invoke to query all the processes
in IHost machine?
Thank you for sharing.
Wendy
| Re: How to get remote process PID [message #33265 is a reply to message #33192] |
Thu, 12 March 2009 10:33   |
Hi Wendy,
There is a process subsystem that can be used depending on the system type
of your host. Which system type are you using?
Once you have a connection that has a process subsystem, the following
IRemoteProcessSubSystem API is available:
* Return a list of all processes on the remote system.
* This version is called directly by users.
* @param processNameFilter filter the results according to this object
* @param context A context object that will be associated with each returned
process
* @param monitor the progress monitor
* @return the list of all processes running on the host machine that
correspond to the filter,
* or null if there are none.
public IRemoteProcess[] listAllProcesses(IHostProcessFilter
processNameFilter, IRemoteProcessContext context, IProgressMonitor monitor)
throws InterruptedException, SystemMessageException;
Dave
"Wendy Zheng" <wezheng@cisco.com> wrote in message
news:65a528e121c02ae41835b4db294cef21$1@www.eclipse.org...
> Does RSE SDK provide API to query the remote process PID? If I have IHost
> in IHost machine?
> Regards,
> Wendy
| Re: How to get remote process PID [message #34258 is a reply to message #34188] |
Mon, 06 April 2009 14:04   |
Hi Wendy,
For your linux system, you may want to create a "Linux" connection (instead
of an SSH Only connection) and configure the services (via the wizard) to
use Sftp, SSH shells and linux shell processes.
For each of your solaris systems, you may need the dstore server to be
installed. In that case, you might use a "Unix" connection and configure
the services (via the wizard) to use the dstore shell processes.
Dave
news:87c90986f5c0a0be3020e9860cd8dc71$1@www.eclipse.org...
> Hi Dave,
> I tried both "SSH - only" and "Unix" system types, they end up in the same
> result.
> My goal is to run RSE application from Window or Linux desktop to connect
> to remote Linux host or Solaris host programmatically. Then launch the
> process in the remote host and monitor the process status.
> Will you suggest "dstore service" in this case? Do I need to install
> dstore server in each remote host the application will connect to?
> Besides "dstore service", do I have other choices that my application will
> be able get remote process infomatiion in either Linux or Solaris hosts?
> Thank you!
> Regards,
> Wendy
| Re: How to get remote process PID [message #34326 is a reply to message #34258] |
Tue, 07 April 2009 16:16  |
Thank you, Dave.
I got the clear picture of how it works.
Currently our system do remote process launching randomly,
install/run dstore server may not be feasible.
I will do process management through command subsystem for now.
When RSE SDK becomes more generic and flexible, we will switch back to
IRemoteProcessSubysystem.
Great thanks !
Wendy
| Re: How to get remote process PID [message #579784 is a reply to message #33192] |
Hi Wendy,
process
Dave
> in IHost machine?
> Regards,
> Wendy
| Re: How to get remote process PID [message #579860 is a reply to message #33265] |
Thu, 19 March 2009 19:05  |
Hi Dave,
Thank you for the suggestion. Yes, that is very convenient API to use.
Will you tell me how do I get IRemoteProcessSubSystem from IHost?
Currently we are busy with beta release, I use shell command
"ps -ef " to get all PIDs. But it is not idea solution.
Thank you.
Wendy
| Re: How to get remote process PID [message #579953 is a reply to message #33442] |
Fri, 20 March 2009 14:33  |
Hi Wendy,
Assuming that you have an IRemoteProcessSubSystem under your IHost, you
could do something like this:
ISubSystem[] sses = getHost().getSubSystems();
IRemoteProcessSubSystem pss = null;
for (int i = 0; i < sses.length && pss == null; i++){
if (sses[i] instanceof IRemoteProcesSubSystem){
pss = (IRemoteProcessSubSystem)sses[i];
news:08a4892cde8d760fc3bf157b6c37be2c$1@www.eclipse.org...
> Hi Dave,
> Thank you.
> Regards,
> Wendy
| Re: How to get remote process PID [message #580030 is a reply to message #33545] |
Tue, 24 March 2009 17:52  |
Thank you, David.
Can we programmatically create IRemoteProcessSubSystem under IHost?
Will you show me how?
Looks like if it is not created, my program will not be able to find it
under IHost. Is it right?
Thank you.
Wendy
| Re: How to get remote process PID [message #580038 is a reply to message #33709] |
Wed, 25 March 2009 10:51  |
You could need to have an appropriate subsystem configuration registered
against the SystemType that you're using. What is the system type in your
case? (i.e. SSH-only, Linux, Unix, etc.?)
Dave
news:f3862dc3e23927b81d389327e06d8b6e$1@www.eclipse.org...
> Thank you, David.
> Can we programmatically create IRemoteProcessSubSystem under IHost? Will
> you show me how?
> Thank you.
> Wendy
| Re: How to get remote process PID [message #580160 is a reply to message #33743] |
Tue, 31 March 2009 18:23  |
Hi Dave,
First I tried:
IRSESystemType systemType =
RSECorePlugin.getTheCoreRegistry().getSystemTypeById(IRSESys temType.SYSTEMTYPE_SSH_ONLY_ID);
then I tried:
RSECorePlugin.getTheCoreRegistry().getSystemTypeById(IRSESys temType.SYSTEMTYPE_UNIX_ID);
then call
host = registry.createHost(profile.getName(),systemType,hostName,ho stName,
"Connection to " + hostName);
to get IHost object.
Then I got IRemoteFileSubSystem through:
RemoteFileUtility.getFileSubSystem(IHost)
I got IRemoteCmdSubSystem through:
RemoteCommandHelpers.getCmdSubSystem(remoteHost);
When I do:
ISubSystem[] sses = IHost.getSubSystems()
I only see 3 sub systems:
- ssh.shells
- ssh.files
- ssh.terminals
I don't see IRemoteProcessSubSystem. Should I invoke API call to create
it?
Thank you !
Wendy
| Re: How to get remote process PID [message #580200 is a reply to message #34087] |
Wed, 01 April 2009 12:31  |
Hi Wendy,
You say you tried both an "SSH only" and a "Unix" conneciton but I'm not
sure which one you ended up using.
An SSH only connection does not have a process subsystem registered against
it by default. A "Unix" connection, on the other hand does - via the dstore
process service.
There are two process services in RSE that can be used:
1) dstore process service -can be used when a dstore server is installed and
works for linux and various unix flavours
2) linux shell process service - can be used via the shell subsystem for
linux systems
I don't know what type of system you're connecting to so I can't say whether
one of these options is possible for you. Could you tell me what the system
you're connecting to is?
news:5f623135b247a84d6a9d7432367ac6fe$1@www.eclipse.org...
> Hi Dave,
> First I tried:
> then I tried:
> then call host =
> When I do:
> - ssh.shells
> - ssh.files
> - ssh.terminals
> it?
> Thank you !
> Regards,
> Wendy
| Re: How to get remote process PID [message #580220 is a reply to message #34157] |
Wed, 01 April 2009 17:06  |
Hi Dave,
result.
Do I need to install dstore server in each remote host the application
will connect to?
Thank you!
Wendy
| Re: How to get remote process PID [message #580263 is a reply to message #34188] |
Hi Wendy,
Dave
> Hi Dave,
> result.
> Thank you!
> Regards,
> Wendy
| Re: How to get remote process PID [message #580308 is a reply to message #34258] |
Thank you, Dave.
Great thanks !
Wendy
Current Time: Sun Nov 09 18:08:37 EST 2025
Powered by FUDForum. Page generated in 0.07547 seconds
