Home » Archived » EPF » Installing epf-composer once for many users
Installing epf-composer once for many users [message #33394] Wed, 06 June 2007 12:16 Go to next message
Someone here has asked me for EPF Composer on Linux. I've unpacked
epf-composer-1.0.2-linux.tar.gz under a Linux file server directory
/usr/local/pkg/epf-composer-1.0.2 visible to all our Linux desktop clients
here. I've arranged that a two-line shell script be callable as
/usr/local/bin/epf which calls /usr/local/pkg/epf-composer-1.0.2/epf - and
this starts fine. I'm wondering how similarly to make one copy of OpenUP,
XP and Scrum available to all the Linux clients.
I've read the installation instructions on the download pages for OpenUP,
XP and Scrum on
http://www.eclipse.org/epf/downloads/openup/openup_downloads .php,
http://www.eclipse.org/epf/downloads/xp/xp_downloads.php and
http://www.eclipse.org/epf/downloads/scrum/scrum_downloads.p hp,
respectively. Taking OpenUp as an example, which has files
OpenUP_Basic_published-0.9-20061002.zip and
OpenUP_library-0.9-20061002.zip. The instructions say:
>Published Web site
> 1. Delete previous installations of the published web site.
> 2. Unzip the downloaded zip file.
> 3. This creates the following folder structure: "Publish\". Go into
this directory and launch index.html.
>Method Library
> 1. Delete previous installations of the method library.
> 3. Open EPF Composer, menu File->Open, then point to the folder where
you unzipped the library (where library.xmi file is)
Does each user have to make a copy of each of the two zip files in their
own directory, unzip them and follow the instructions above to make them
available to EPF Composer? Or can I unpack the files once for all users to
share? Such shared files are usually owned by user 'bin'.
Re: Installing epf-composer once for many users [message #33534 is a reply to message #33394] Mon, 18 June 2007 17:34 Go to previous message
John,
You can unzip the published web site in a network drive or deploy to a web
server and have multiple users browsing through it using an Internet
browser.
For the library, you can have it unzipped to a network drive too, but if you
are going to allow multiple users to edit the library using EPF Composer,
you want to have the library under a version control system. For more
information, see "Using EPF Composer with a Version Control System" at
http://www.eclipse.org/epf/general/documentation.php.
Ricardo Balduino
IBM | EPF Committer
"John A. Murdie" <john@cs.york.ac.uk> wrote in message
news:420b376198b7aa877269f8add73a26cc$1@www.eclipse.org...
> XP and Scrum on
>>Published Web site
>>Method Library
>> where
Re: Installing epf-composer once for many users [message #579082 is a reply to message #33394] Mon, 18 June 2007 17:34 Go to previous message
John,
browser.
Ricardo Balduino
IBM | EPF Committer
> XP and Scrum on
>>Published Web site
>>Method Library
>> where
Previous Topic:Problem with "Rich Text Editor"
Next Topic:New trend - Practice over Process - where to from here?
Current Time: Thu Jul 24 21:32:42 EDT 2025
Powered by FUDForum. Page generated in 0.06891 seconds
