Home » Modeling » M2T (model-to-text transformation) » [JET2] Custom XPath to access stereotypes.
[JET2] Custom XPath to access stereotypes. [message #30840] |
Tue, 14 August 2007 08:41  |
Hi everybody. I know Paul is on holidays, but as there is a lot of very
capable people around, I felt encouraged to ask this question anyhow.
I read in some post (also available as "JET FAQ Can JET handle UML
models as input?" in
http://wiki.eclipse.org/JET_FAQ_Can_JET_handle_UML_models_as _input%3F)
that although JET cannot access stereotypes or stereotype properties,
custom XPath functions could be created to access these.
This is exactly what I need, so I started making my own XPath function,
according to "JET FAQ How do I create custom XPath Function?"
( http://wiki.eclipse.org/JET_FAQ_How_do_I_create_custom_XPath _Function%3F).
However, I am stuck in the part of accessing the stereotypes while
coding the java class.
I know Ecore has no notion of stereotypes. Meanwhile, .emx and .uml2
models do. I thought of using UML2 metamodel/API to be able to access
the stereotypes. Therefore, I placed "org.eclipse.uml2" as a required
plugin (in the manifest). However, when trying to import this package in
my java class, I get a "org.eclipse.uml2 cannot be resolved" message. I
tried re-building the project from scratch, with the same result.
Am I missing something here?, did I make wrong assumptions?, if so,
which is the line to follow?.
I would really appreciate your help on this one,
Thanks in advance,
Juan Pedro Silva
Re: [JET2] Custom XPath to access stereotypes. [message #30875 is a reply to message #30840] |
Tue, 14 August 2007 09:04   |
--------------000603080600000506060908
Juan,
Did you add org.eclipse.uml2.*uml *to the dependencies? Note that if
you use Ctrl-Shift-T to open a class you need to use, you can then use
the little left right arrow in the package explorer to locate which
plugin that class appears in and use that to help ensure that the right
plugin dependencies get added.
> function, according to "JET FAQ How do I create custom XPath
> Function?"
> in my java class, I get a "org.eclipse.uml2 cannot be resolved"
> message. I tried re-building the project from scratch, with the same
> result.
> Thanks in advance,
> Juan Pedro Silva
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Juan,<br>
<br>
Did you add org.eclipse.uml2.<b>uml </b>to the dependencies? Note
that if you use Ctrl-Shift-T to open a class you need to use, you can
then use the little left right arrow in the package explorer to locate
which plugin that class appears in and use that to help ensure that the
right plugin dependencies get added.<br>
<br>
<br>
<br>
<blockquote cite="mid:f9s7uj$fhv$1@build.eclipse.org" type="cite">Hi
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/JET_FAQ_Can_JET_handle_UML_models_as _input%3F"> http://wiki.eclipse.org/JET_FAQ_Can_JET_handle_UML_models_as _input%3F</a>)
<br>
<br>
<br>
<br>
(<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/JET_FAQ_How_do_I_create_custom_XPath _Function%3F"> http://wiki.eclipse.org/JET_FAQ_How_do_I_create_custom_XPath _Function%3F</a>).
<br>
<br>
<br>
result.
<br>
<br>
<br>
<br>
Thanks in advance,
<br>
Juan Pedro Silva
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------000603080600000506060908--
Re: [JET2] Custom XPath to access stereotypes. [message #31086 is a reply to message #30875] |
Tue, 14 August 2007 14:00   |
Juan,
Unfortunately I'm not familiar with all the cool things Paul has done to
support XPaths and my XPath knowledge is very rusty. Hopefully someone
can jump in and answer these. I would expect the basic docs would have
covered these issues...
> Thank you, Ed, that was a silly mistake (importing org.eclipse.uml2
> instead of org.eclipse.uml2.uml).
> I wrote these questions below some time ago, I think I got them
> (almost) clear now, but I leave them just to be sure and for
> documentation purposes (someone may have these same questions later in
> time).
> Referring to the fundamental issue, I'm having problems figuring out
> the type of the elements I'm dealing with.
> Lets say, when I use in XPath "/contents" against a uml2 model, what I
> get are EObjects (to be precise, an EList<EObject>), am I right?.
> Which is the type of "contents" itself?.
> If I try to pass a reference of the root of the model, the outermost
> container, what should I use?. If I use "/*", what I get is an element
> named "content", which (as I see it) must be a mapping of the
> Resource.getContents() method into a tree to be able to use the XPath
> expression "/contents" instead. If I get a hold of any "Element" from
> the model, and then do "element.getModel()", would that do?. How would
> I do that in XPath?.
> Thank you very much in advance.
> Regards,
> Juan Pedro
> Ed Merks escribió:
>> Juan,
>> the right plugin dependencies get added.
>>> Function?"
>>> access the stereotypes. Therefore, I placed "org.eclipse.uml2" as a
>>> required plugin (in the manifest). However, when trying to import
>>> this package in my java class, I get a "org.eclipse.uml2 cannot be
>>> resolved" message. I tried re-building the project from scratch,
>>> Thanks in advance,
>>> Juan Pedro Silva
Re: [JET2] Custom XPath to access stereotypes. [message #31121 is a reply to message #30875] |
Tue, 14 August 2007 14:46   |
I wrote a message a few moments ago and had to cancel it, as I realized
I was mistaken, sorry.
An update: if I try to pass an element to my XPath function, I am really
passing a org.eclipse.jet.internal.xpath.NodeSetImpl (a set of nodes).
How can I get a reference of an "Element" to pass it to the XPath
function?. I was trying to get a hold of any "Element" from
the model, and then do "element.getModel()" to get the outermost element
of the model.
I believe I may be loosing my north. Am I going in the right direction,
o should I use a completely different strategy to try to get the
stereotypes?.
Thank you,
Juan Pedro
Ed Merks escribió:
> Juan,
>> Function?"
>> result.
>> Thanks in advance,
>> Juan Pedro Silva
Re: [JET2] Custom XPath to access stereotypes. [message #31609 is a reply to message #30840] |
Mon, 27 August 2007 11:39   |
Juan Pedro:
Your approach is consistent with that of others. Thanks to Ed and Aleks for
helping out with the technical problems.
I would probably create one of two XPath functions:
getStereotypeValue( object, 'myprofile::myStereoType', 'stPropertyName')
and
isStereotypeApplied( object, 'myprofile::myStereoType')
This would use Element.getValue() and element.isStereotypeApplied()
respectively as their key funcions.
On the technical side, XPath functions will receive arguments in the form of
NodeSet, Number, String or Boolean.
You can return any of the above for types or an object that JET knows how to
handle (EObject's fall into this category).
There is no public NodeSet implementation, but something as simple as:
class MyNodeSet extends java.util.HashSet implements NodeSet {
will do.
Paul
"Juan Pedro Silva" <jpsilvagallino@gmail.com> wrote in message
news:f9s7uj$fhv$1@build.eclipse.org...
> However, I am stuck in the part of accessing the stereotypes while coding
> the java class.
> models do. I thought of using UML2 metamodel/API to be able to access the
> stereotypes. Therefore, I placed "org.eclipse.uml2" as a required plugin
> (in the manifest). However, when trying to import this package in my java
> class, I get a "org.eclipse.uml2 cannot be resolved" message. I tried
> Am I missing something here?, did I make wrong assumptions?, if so, which
> Thanks in advance,
> Juan Pedro Silva
Re: [JET2] Custom XPath to access stereotypes. [message #31850 is a reply to message #31609] |
Wed, 29 August 2007 04:21   |
Thanks Paul, Alex, Ed..
I'm sorry it took me so long to answer, but I had to travel abroad and
lost touch.
Paul, I was thinking of two very similar functions, thank for your advice.
One further question about this subject: the different elements (I mean
each Item, not referring to the 'Element' class in particular) in the
NodeSet, correspond to which class?, are they 'Element', 'NamedElement',
or something else?. I need to know this in order to be able to deal with
them.
Thank you all for your answers.
Juan Pedro
Paul Elder escribió:
> Juan Pedro:
> and
> will do.
> Paul
>> the java class.
>> Thanks in advance,
>> Juan Pedro Silva
Re: [JET2] Custom XPath to access stereotypes. [message #31886 is a reply to message #31850] |
Wed, 29 August 2007 06:44   |
I just found the answer to my last question browsing the newsgroup. As a
reference, it's in a post from Paul and Zsolt Parocziz titled "Xpath
node" in 19/07/2007. According to this, as I'm using the emf loader, I
get a NodeSet of EObject's. That's fine.
As already discussed, it's desirable to work with
org.eclipse.uml2.uml.Element since it provides a lot of useful methods
(for instance, means to access stereotypes, or the 'Model' itself).
Regretfully, if I try to cast the EObject to Element, I get a:
Error: Error executing tag handler: java.lang.ClassCastException:
org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to
Which would be the right approach here?.
Thank you all, again,
Juan Pedro
> lost touch.
> them.
> Regards,
> Juan Pedro
>> Juan Pedro:
>> Aleks for helping out with the technical problems.
>> and
>> form of NodeSet, Number, String or Boolean.
>> how to handle (EObject's fall into this category).
>> will do.
>> Paul
>>> Function?"
>>> result.
>>> Thanks in advance,
>>> Juan Pedro Silva
Re: [JET2] Custom XPath to access stereotypes. [message #31921 is a reply to message #31886] |
Wed, 29 August 2007 08:42   |
Juan Pedro:
This is weird. You should not be getting DynamicEObjectImpl's, you should be
getting actual UML2 objects (like ClassImpl, PackageImpl, ...)
I suspect you are not using the correct model loader. Try the following:
1) open plugin.xml in your JET transformation
2) Click on the Extensions tab, and expand org.eclipse.jet.transform, and
then click on transform.
3) Set the 'modelLoader' property to 'org.eclipse.jet.emf'
Save, and try again.
Paul
news:fb3iml$6v5$2@build.eclipse.org...
>reference, it's in a post from Paul and Zsolt Parocziz titled "Xpath node"
>in 19/07/2007. According to this, as I'm using the emf loader, I get a
> Juan Pedro
Re: [JET2] Custom XPath to access stereotypes. [message #32372 is a reply to message #32025] |
Tue, 04 September 2007 05:06   |
I tried re-stating the model loader as 'org.eclipse.jet.emf' and I keeo
getting the same results.
At this time I don't know what to do next.
Juan Pedro
> Paul, I'm attaching my plugin.xml.
> In it you can see that the model loader is in fact org.eclipse.jet.emf
> What else could it be?
> I'm attaching the java code of the hasSterotype() function class, as
> well as its plugin xml. I'm also attaching the model which I use to try
> it, just in case.
> I'm trying it out with this simple JET code:
> <c:iterate select="/contents" var="container">
> ServiceProviders:
> <c:iterate select="$container" var="elem">
> Element <c:get select="name($elem)" />
> <c:choose> <c:when test="hasStereotype($elem,
> 'Perfil_SOA::serviceProvider')">
> <c:get select="name($reference)"/> es ServiceProvider.
> </c:when> </c:choose>
> </c:iterate>
> </c:iterate>
> I realize I may have other errors (for instance, I'm not completely sure
> that the workspace found the particular profile that was applied), but
> I'm tackling them one at a time.
> Thank you.
>> Juan Pedro:
>> should be getting actual UML2 objects (like ClassImpl, PackageImpl, ...)
>> and then click on transform.
>> Paul
>>> As a reference, it's in a post from Paul and Zsolt Parocziz titled
>>> "Xpath node" in 19/07/2007. According to this, as I'm using the emf
>>> loader, I get a NodeSet of EObject's. That's fine.
>>> methods (for instance, means to access stereotypes, or the 'Model'
>>> itself). Regretfully, if I try to cast the EObject to Element, I get a:
>>> Juan Pedro
>>>> and lost touch.
>>>> advice.
>>>> mean each Item, not referring to the 'Element' class in particular)
>>>> in the NodeSet, correspond to which class?, are they 'Element',
>>>> 'NamedElement', or something else?. I need to know this in order to
>>>> be able to deal with them.
>>>> Regards,
>>>> Juan Pedro
>>>>> Juan Pedro:
>>>>> 'stPropertyName')
>>>>> and
>>>>> the form of NodeSet, Number, String or Boolean.
>>>>> knows how to handle (EObject's fall into this category).
>>>>> will do.
>>>>> Paul
>>>>>> very
>>>>>> Function?"
>>>>>> .uml2 models do. I thought of using UML2 metamodel/API to be able
>>>>>> to access the stereotypes. Therefore, I placed "org.eclipse.uml2"
>>>>>> as a required plugin (in the manifest). However, when trying to
>>>>>> import this package in my java class, I get a "org.eclipse.uml2
>>>>>> cannot be resolved" message. I tried re-building the project from
>>>>>> so, which is the line to follow?.
>>>>>> Thanks in advance,
>>>>>> Juan Pedro Silva
Re: [JET2] Custom XPath to access stereotypes. [message #32990 is a reply to message #32025] |
Thu, 06 September 2007 10:32   |
Juan Pedro:
Can you tell me what version of UML2 features/plug-ins you are using. Also,
what tool are you using to generate your UML models?
We'll get to the bottom of this yet! That a you are finding a DynamicEObject
is an indication (I think) that EMF did not find an implementation of the
UML2 EPackage. One thing to try is loading the UML model using the Java
API's yourself, and seeing whether you get DynamicEObjects or not. If you
do, then this is not a JET problem (and we can ask a question on the UML
news group).
Paul
news:fb3sjv$7fv$2@build.eclipse.org...
> it, just in case.
> ServiceProviders:
> </c:iterate>
> </c:iterate>
> Thank you.
Re: [JET2] Custom XPath to access stereotypes. [message #33201 is a reply to message #32990] |
Fri, 07 September 2007 04:45   |
Hi Paul.
Let me see, the model I'm using as input was developed in RSA 7.0.0.3,
which has UML2 plugin version 2.0.3v200702141227
I'm using Eclipse with UML2 plugin 2.1.0v200706251652
The input model was transformed into a UML2 (from .emx) model in RSA
before importing it into eclipse. It also uses a profile that has not
been imported yet into eclipse.
I will load the model in java and get back to you with the results.
Thank you,
Juan Pedro
> Juan Pedro:
> news group).
> Paul
>> it, just in case.
>> ServiceProviders:
>> </c:iterate>
>> </c:iterate>
>> Thank you.
Re: [JET2] Custom XPath to access stereotypes. [message #33376 is a reply to message #33201] |
Fri, 07 September 2007 10:09   |
Hmmm.
I'm suspecting it has something to do with move from UML2 2.0.x to 2.1.x.
I have done some tests (in RSA 7.0.0.x), and a JET transform gets actual
UML2 implementations. I have tried with:
..emx files
..uml files (created by using the Export > UML Model wizard)
..xmi files (created by using the Export > UML XMI Interchange Model wizard)
I'll have to move on over to a Eclipse 3.3/UML 2.1 based install to test
under that, but at this point, it appears that this is UML2 behavior not
JETs.
I'm attaching my test projects as a ZIP, there are two projects:
* juan.pedro.jet contains a simple JET transformation that dumps information
about the loaded model to the JET execution console.
* juan.pedro contains a the EMX, UML and XMI files, plus JET launch
configurations to run juan.pedro.jet on them.
Paul
news:fbr342$959$1@build.eclipse.org...
> Hi Paul.
> Thank you,
> Juan Pedro
> Paul Elder escribi
Re: [JET2] Custom XPath to access stereotypes. [message #33481 is a reply to message #33376] |
Fri, 07 September 2007 10:33   |
As soon as I get home I'll give them a try.
Thanks.
> Hmmm.
> .emx files
> JETs.
> Paul
>> Hi Paul.
>> Thank you,
>> Juan Pedro
>>> Juan Pedro:
>>> Also,
>>> DynamicEObject
>>> news group).
>>> Paul
>>>> it, just in case.
>>>> ServiceProviders:
>>>> </c:iterate>
>>>> </c:iterate>
>>>> Thank you.
Re: [JET2] Custom XPath to access stereotypes. [message #33515 is a reply to message #33376] |
Fri, 07 September 2007 12:26   |
Paul, I tried your code with my model and the result was empty:
templates/main.jet(57,1): <ws:file template="templates/dump.jet"
path="{$org.eclipse.jet.resource.project.name}/dump.xml">
Writing file: /juan.pedro/dump.xml
Successful Execution
So it most probably the problem that you figured out, something related
with migration from UML 2.0.X to UML 2.1.X
So is an RSA problem, let's say, because I cannot update it so that it
uses UML 2.1, am I right?. I had a similar problem when I ran into a bug
in OCL's plugin and couldn't update it to a newer version which had
fixed it.
An alternative?, using Eclipse with UML 2.0.X instead?.
Juan Pedro
> Hmmm.
> .emx files
> JETs.
> Paul
>> Hi Paul.
>> Thank you,
>> Juan Pedro
>>> Juan Pedro:
>>> Also,
>>> DynamicEObject
>>> news group).
>>> Paul
>>>> it, just in case.
>>>> ServiceProviders:
>>>> </c:iterate>
>>>> </c:iterate>
>>>> Thank you.
Re: [JET2] Custom XPath to access stereotypes. [message #33616 is a reply to message #33515] |
Tue, 11 September 2007 08:11   |
Juan Pedro:
Based on your results in message news:fbrn5a$msm$1@build.eclipse.org,
I'd say that is the problem. If you want to stay compatible with RSA
7.0.0.x, then I think your Eclipse shell will have to use UML 2.0.X. I'll go
ask the UML development lead (who are just a leisurely stroll across my
building) - I'll post another reply if I get anything useful.
Paul
news:fbru43$rqu$1@build.eclipse.org...
> in OCL's plugin and couldn't update it to a newer version which had fixed
> it.
> Regards,
> Juan Pedro
> Paul Elder escribi
Re: [JET2] Custom XPath to access stereotypes. [message #33679 is a reply to message #33616] |
Wed, 12 September 2007 05:47  |
Paul, good and bad news: after fixing minor details, your code works
fine on my uml2 model in the Eclipse environment set up with exactly the
same plugins that RSA uses.Thank you all very much for your help.
However, I keep getting the "java.lang.ClassCastException:
org.eclipse.uml2.uml.Element" error message.
I will try to find out on which elements in particular (it seems to me
the problem is not among all elements).
Juan Pedro
> Juan Pedro:
> Paul
>> it.
>> Regards,
>> Juan Pedro
>>> Hmmm.
>>> .emx files
>>> wizard)
>>> JETs.
>>> information about the loaded model to the JET execution console.
>>> Paul
>>>> Hi Paul.
>>>> Thank you,
>>>> Juan Pedro
>>>>> Juan Pedro:
>>>>> Also,
>>>>> DynamicEObject
>>>>> the
>>>>> you
>>>>> UML
>>>>> news group).
>>>>> Paul
>>>>>> try
>>>>>> it, just in case.
>>>>>> ServiceProviders:
>>>>>> </c:iterate>
>>>>>> </c:iterate>
>>>>>> sure
>>>>>> Thank you.
Current Time: Fri Jul 18 17:51:19 EDT 2025
Powered by FUDForum. Page generated in 0.08550 seconds
