Home » Eclipse Projects » Eclipse Platform » opensuse 11.1 build error?
opensuse 11.1 build error? [message #334349] Wed, 04 February 2009 06:10 Go to next message
Please excuse this post if it is an opensuse build problem but I would
like to get my system running properly.
I have installed the eclipse platform in openSuse 11.1 in x86 architecture.
When I try to install a plugin eclipse error log says:
Unable to access file
"plugins/org.eclipse.core.filesystem.linux.x86_64_1.0.100.v
20080604-1400.jar!META-INF/MANIFEST.MF".
When I inspect the eclipse package under /usr I find that the file in
question vis:
org.eclipse.core.filesystem.linux.x86_64_1.0.100.v 20080604-1400.jar
is a link to a similarly named file under /usr/lib64/eclipse/plugins/. My
system, being an x86 system, does not have such a directory so the link
goes nowhere.
Under /usr/lib/eclipse/plugins/ I find a file called
org.eclipse.core.filesystem.linux.x86_1.2.0.v20080 604-1400.jar which
could be an alternative link destination.
Would the system work if I created a link to this file to replace the link
to the non-existent 64 bit jar?
Can anyone help?
Re: opensuse 11.1 build error? [message #334488 is a reply to message #334349] Thu, 12 February 2009 09:44 Go to previous message
Is it possible that you accidently downloaded and installed the 64-bit
version of eclipse instead of the 32-bit version? I can't think of any
other reason that it would attempt to look for
plugins/org.eclipse.core.filesystem.linux.x86_64_1.0.100.v.. .
Grant
"peterblewis " <lewisp@avex.co.uk> wrote in message
news:99ae270c2809ff5010a119fc2b7bdd9a$1@www.eclipse.org...
architecture.
> question vis:
> goes nowhere.
> Can anyone help?
Previous Topic:Search Plugin
Next Topic:Rampant OutOfMemory errors in 3.4
Current Time: Tue Oct 21 14:22:07 EDT 2025
Powered by FUDForum. Page generated in 0.04310 seconds
