| Can I customize the ant build script exported by eclipse? [message #334357] | Wed, 04 February 2009 11:58  |  |
| Eclipse User  |  |  |  |  | Hey,
 Our plug-in has implemented a builder which is used to build some resource
 files (let's call it resource builder). The files created by the resource
 builder are used when the java builder builds a project. Now, we are
 looking for a way to add the task which is done by our resource builder to
 the ant build script exported by eclipse through "Export-->Ant Buildfile"
 wizard. By defaul, the generated ant descript file only contains java
 build task. Is there any way we can customize it?
 Thanks.
| Re: Can I customize the ant build script exported by eclipse? [message #334385 is a reply to message #334377] | Fri, 06 February 2009 09:39   |  |
| Eclipse User  |  |  |  |  | Andrew,
 Thanks for you answer. It is good for me to know this mechanism. However,
 it is not exactly what I want. This way, it seems users still need to
 create the customBuildCallbacks.xml manually, then, when the build.xml is
 executed, it can be called, right?
 What I am looking for is does eclipse provides any support to
 programmatically create an ANT build script file? When a project is
 created, the properties of our resource builder are set, when users click
 the export ant buildfiles function, I want it can programmatically create
 an ANT task for our resource builder in the build.xml file or the
 customBuildCallbacks.xml mentioned in your answer.In short words, I am
 more interested in programmatically generating an ANT build file.
 Thanks.
FUDForum. Page generated in 0.05614 seconds
