Home » Eclipse Projects » Eclipse Platform » Java Reflection Classloading Extensionpoint Defined Classes
Java Reflection Classloading Extensionpoint Defined Classes [message #334302] Mon, 02 February 2009 11:25 Go to next message
I've an extensionpoint that at one point need an classpath and name.
Later, on extensionpoint processing, this classname is used to create an
instance of this class using Java reflections.
Everything is fine as long I'm only using classes that are defined in the
extensionpoint defining plugin or a plugin that is known by it.
When ever I'm adding classes from else where the Classloader does not know
the class. Its quite obviouse why. If I could use the bundle classloader
of the plugin consuming to the extensionpoint I'll would probaly be done.
But unfortunately IExtensionPoint.getDeclaringPluginDescriptor() is
deprecated :(
So my question is, how can I use the bundle classloader, or how else could
my problem be solved?
Thanks!
Re: Java Reflection Classloading Extensionpoint Defined Classes [message #334322 is a reply to message #334302] Tue, 03 February 2009 04:51 Go to previous messageGo to next message
Hello again,
its somehow so simple that it was quite imposssible to get it at the first
sight ... :)
When processing the extensionpoint at some point you get an
IConfigurationElement element. Frome here you can get the contributors
name and with this its easy to get the Bundle. With the Bundle you can
load any class that is in the bundle classpath:
String controllerClassName = element.getAttribute("InputController");
String name = element.getContributor().getName();
bundle = Platform.getBundle(name);
Class<InputController> controllerClass =
(Class<InputController>)bundle.loadClass(controllerClassName);
Jan
Re: Java Reflection Classloading Extensionpoint Defined Classes [message #334334 is a reply to message #334322] Tue, 03 February 2009 13:59 Go to previous messageGo to next message
And you cannot use element.createExecutableExtension("InputController")?
That's what it is designed for.
PW
Paul Webster
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Re: Java Reflection Classloading Extensionpoint Defined Classes [message #334343 is a reply to message #334334] Wed, 04 February 2009 03:23 Go to previous messageGo to next message
Paul,
InputController is a Control. Therefor it needs be get instantiated on
creationtime of an part/editor/dialog. Also it needs constructors like a
parent Composite and a style.
> PW
Re: Java Reflection Classloading Extensionpoint Defined Classes [message #334355 is a reply to message #334343] Wed, 04 February 2009 09:48 Go to previous message
Maybe you should change the extension point to be for a factory class
for the InputController instead. The factory could use the default ctor
to be constructed and then call a method on the factory with parent and
style to create the InputController.
That way you won't be digging into weird places to do what
createExecutableExtension is supposed to do anyway.
Jan Kohnert wrote:
> Paul,
> Paul Webster wrote:
>> And you cannot use
>> element.createExecutableExtension("InputController")? That's what it
>> is designed for.
>> PW
Rich Kulp
Previous Topic:Original Tasks View missing in 3.4 with Mylyn
Next Topic:Overriding IExtensionRegistry / IExtensionPoint / IExtension
Current Time: Sat Oct 25 11:43:34 EDT 2025
Powered by FUDForum. Page generated in 0.03585 seconds
