| [ATL] transform model to metamodel with ATL [message #33258] |
Mon, 23 April 2007 04:08  |
Originally posted by: sylvain.maillard.univ-nantes.fr
Hi All,
I want to use ATL to programatically transform a model that conforms to
eCore into an eCore model (I want to generate a MM in fact).
for now I have my xyz.ecore file as an input MM, a xxx.xyz file that is
the input Model. I set eCore as the output (file is ecore.ecore from
EMF distribution), but ATL generate a XMI file that Eclipse can not
manage.
Please Help,
Sylvain
Sylvain
| Re: [ATL] transform model to metamodel with ATL [message #33363 is a reply to message #33293] |
Mon, 23 April 2007 06:09  |
Hi Mikael, thanks for your reply.
The problem was that my atl script was not correct, now it work ;-)
> Hi Sylvain,
> Did you try to set the location of the Ecore metametamodel by URI ? I think
> it should solve your problem.
> Regards,
> Mikael
> Sylvain wrote:
>> Hi All,
>> for now I have my xyz.ecore file as an input MM, a xxx.xyz file that is the
>> input Model. I set eCore as the output (file is ecore.ecore from EMF
>> distribution), but ATL generate a XMI file that Eclipse can not manage.
>> Please Help,
>> Sylvain
Sylvain
FUDForum. Page generated in 0.25348 seconds
