Home » Eclipse Projects » Eclipse Platform » How to enable / disable button on toolbar?
How to enable / disable button on toolbar? [message #331715] Thu, 18 September 2008 03:54 Go to next message
I have added a button on toolbar using the org.eclipse.ui.actionSets
extension.
I want it to be enabled only if a project
(org.eclipse.core.resources.IProject) is selected inside the workbench.
How do I do that?
I googled for this problem and came across this thread :
http://dev.eclipse.org/newslists/news.eclipse.platform/msg77 563.html
If I follow the solution in this thread, my button on the toolbar remains
disabled by default but gets enabled if user selects some resource
(project / folder / package / file).
Only when the user clicks on the button for the first time, the enable /
disable feature starts working. That's not what I want.
The button should be disabled by default and I should be able to enable it
only when user selects a project and disable it otherwise.
Here are details :
Plugin.xml :
<extension
point="org.eclipse.ui.actionSets">
<actionSet
id="com.abc.actionSet1"
visible="true"
label="Test button">
<action
class="com.abc.ActionClass"
icon="icons/logo.gif"
id="com.abc.actionId1"
label="Test action"
enablesFor="1"
toolbarPath="org.eclipse.ui.workbench.file/new.ext"
tooltip="Test the button's action">
</action>
</actionSet>
</extension>
com.abc.ActionClass :
public class ActionClass implements
IWorkbenchWindowActionDelegate {
ISelection selection;
IProject selectedProject;
public void dispose() {
public void init(IWorkbenchWindow window) {
public void selectionChanged(IAction action, ISelection selection) {
this.selection = selection;
IStructuredSelection sSelection = (IStructuredSelection) selection;
Object[] selectedObjects = sSelection.toArray();
for(Object selectedObject : selectedObjects) {
if(selectedObject instanceof IAdaptable) {
Object adaptableObject =
((IAdaptable)selectedObject).getAdapter(IResource.class);
if(adaptableObject instanceof IProject) {
selectedProject = (IProject)adaptableObject;
break;
else {
action.setEnabled(false);
public void run(IAction action) {
// use selectedProject;
Is there any other way of adding a button to the toolbar that'll give me
this flexibility?
Thanks.
Re: How to enable / disable button on toolbar? [message #331730 is a reply to message #331715] Thu, 18 September 2008 10:33 Go to previous messageGo to next message
In theory you can use action/selection or action/enablement for some
minimal declarative enabled state. It is the older platform expression
language.
I believe we discussed this on IRC and in commands+handlers you can do
something like:
<with variable="selection">
<and>
<count value="1"/>
<iterate> <!-- you might want to set the ifEmpty attribute -->
<adapt type="org.eclipse.core.resources.IResource">
<instanceof value="org.eclipse.core.resources.IProject"/>
</adapt>
</iterate>
</and>
</with>
[/xml]
Later,
PW
Paul Webster
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Re: How to enable / disable button on toolbar? [message #331743 is a reply to message #331730] Fri, 19 September 2008 05:38 Go to previous message
> something like:
Yes indeed.
Thanks a lot.
Previous Topic:Is it possible to override VariableLabelProvider for varibles view
Next Topic:Custom Eclipse Distribution
Current Time: Mon Sep 01 02:02:11 EDT 2025
Powered by FUDForum. Page generated in 0.03693 seconds
