Home » Eclipse Projects » Eclipse Platform » clipboard paste fails in eclipse 3.4.0
clipboard paste fails in eclipse 3.4.0 [message #331375] Wed, 03 September 2008 21:04 Go to next message
All of a sudden my paste (control V) into Replace Text Matches fails.
Every time it wants to paste an old buffer from earlier in the day.
Copy and paste in to the editor works. Paste has worked before today.
I've tried re-copying the text. I've pasted in to other apps no problem.
I've re-booted the OS (winXP) and restarted eclipse. Same problem, same
old buffer.
Now it seems that I get this old buffer of text in every Eclipse text
entry field.
I managed to get the old buffer to change one time but I can't reproduce it.
Any hints? Any workaround? It makes eclipse not very useful to say the
least.
I have PDE and source so any way of debugging would also be welcome.
John
Re: clipboard paste fails in eclipse 3.4.0 [message #331401 is a reply to message #331375] Thu, 04 September 2008 14:36 Go to previous messageGo to next message
> old buffer.
> entry field.
> it.
> least.
> John
More curious info: when I paste and get the old buffer, my editor window
highlights the old text.
Re: clipboard paste fails in eclipse 3.4.0 [message #331404 is a reply to message #331401] Thu, 04 September 2008 16:22 Go to previous messageGo to next message
Does eclipse support replacing a single line of text with multiple lines
in the Search..Replace function?
To my surprise, the answer maybe no! This explains my problem: when I
paste into the replace field, only the first line shows up, which I
interpreted as an old bit of text (as it accidentally was).
Re: clipboard paste fails in eclipse 3.4.0 [message #331457 is a reply to message #331404] Mon, 08 September 2008 10:18 Go to previous messageGo to next message
> lines in the Search..Replace function?
Yes.
In fact only the first line is taken and used to search/replace.
Dani
> which I interpreted as an old bit of text (as it accidentally was).
Re: clipboard paste fails in eclipse 3.4.0 [message #331463 is a reply to message #331457] Mon, 08 September 2008 17:03 Go to previous messageGo to next message
> Yes.
> Dani
? How can "only the first line is taken" also be "Yes" its supported?
I'd say its more like "there is a bug: multi line replacements are
ignored and you are not warned".
Re: clipboard paste fails in eclipse 3.4.0 [message #331470 is a reply to message #331463] Tue, 09 September 2008 02:45 Go to previous message
>> Yes.
>>> I paste into the replace field, only the first line shows up,
>> Dani
You can say for pasting but search/replaces works by using regex.
Dani
Previous Topic:[Data Binding] Re: Widget [org.eclipse.swt.custom.StyledText] is not supported.
Next Topic:How to participate in cut / copy / paste?
Current Time: Mon Sep 29 16:46:50 EDT 2025
Powered by FUDForum. Page generated in 0.04002 seconds
