Home » Eclipse Projects » Eclipse Platform » How to programmatically invoke Save All command?
How to programmatically invoke Save All command? [message #331024] Thu, 21 August 2008 10:50 Go to next message
Originally posted by: nick.allen.onlinehome.de
In my plug-in I have registered a number of command handlers that invoke
OS commands. I would like to ensure that all files in Eclipse have been
saved to disk before doing so (to make sure the commands work on the
most recent data).
Can anyone point me in the right direction?
Nicholas Allen
Re: How to programmatically invoke Save All command? [message #331026 is a reply to message #331024] Thu, 21 August 2008 11:13 Go to previous messageGo to next message
I found this by looking at ActionFactory.SAVE_ALL, going to the
SaveAllAction and looking at it's run method.
Call WorkbenchPage.saveAllEditors()
Francis
Nicholas Allen wrote:
> most recent data).
> Nicholas Allen
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: How to programmatically invoke Save All command? [message #331029 is a reply to message #331026] Thu, 21 August 2008 12:08 Go to previous messageGo to next message
Thanks for the feedback. saveAllEditors is not a static method so how do
I obtain a pointer to an IWorkbenchPage from with my command handler
execute method? I'm sorry if that is a silly question - I am completely
new to Eclipse plugins.
Nick
> Francis
>> Hi,
>> most recent data).
>> Thanks,
>> Nicholas Allen
Re: How to programmatically invoke Save All command? [message #331030 is a reply to message #331029] Thu, 21 August 2008 12:11 Go to previous messageGo to next message
Sorry - I think I worked it out!
IWorkbenchWindow workbenchWindow =
HandlerUtil.getActiveWorkbenchWindowChecked(event);
workbenchWindow.getActivePage().saveAllEditors(true);
Re: How to programmatically invoke Save All command? [message #331219 is a reply to message #331030] Thu, 28 August 2008 10:24 Go to previous message
That will call the programmatic APIs. The other way is to simply invoke
the org.eclipse.ui.file.saveAll command using the IHandlerService.
You can use the workbenchWindow.getService(IHandlerService.class) to
retrieve it. The advantage of calling the command is that any command
execution listeners are notified.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Perspective bar programmatically
Next Topic:How to get notified when Eclipse renames or deletes a file in the workspace?
Current Time: Tue Oct 07 05:18:08 EDT 2025
Powered by FUDForum. Page generated in 0.14545 seconds
