Home » Eclipse Projects » Eclipse Platform » extension points distribution
extension points distribution [message #329154] Sat, 14 June 2008 09:25 Go to next message
Originally posted by: b26rsfdi8r6u643.mail.svenz.eu
I have troubles with the distribution configuration of my plug-ins. I
defined several extension-points and did some extensions for them within
my own code. Now I want to provide other developers the capability to do
so as well, but I have problems to access (Plug-in Manifest Editor | New
Extension...) them once the plug-ins are installed.
Is there something special I have to take into account for plug-in/
feature configuration!?
Thanks, Tom.
Wasn't sure about the newsgroup jdt - pde - platform!?
Re: extension points distribution [message #329170 is a reply to message #329154] Mon, 16 June 2008 08:05 Go to previous message
Tom Oleg wrote:
While I'm not 100% sure if it's the only way, the eclipse SDK ships the
schema files in the source plugins. Without the schema files (which are
not normally included in your development plugins) all you'll get is the
generic XML sections in the PDE Editor.
I'm not sure if it's good enough to simply put the schema directory in
your binary plugin, or if you really do need a source plugin as well.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Dynamic drop-down menu for a toolitem
Next Topic:How to get IAction from actionSet?
Current Time: Wed Oct 08 09:22:59 EDT 2025
Powered by FUDForum. Page generated in 0.07842 seconds
