Home » Eclipse Projects » Eclipse Platform » [DataBinding] Connect Databinding Error Message with Eclipse Forms
[DataBinding] Connect Databinding Error Message with Eclipse Forms [message #328971] Mon, 09 June 2008 12:21 Go to next message
I'm using Eclipse Forms and Eclipse Databinding for the individual text
elements.
In Eclipse Forms I can display messages, e.g.
form.setMessage("This is an error message", IMessageProvider.ERROR);
Is there a simple way of connecting the message part of the form to the
databinding?
Currently I'm defining an label which I'm connecting to the error message of
the databinding. I'm then registering a changeListener to this label and I'm
updating then the message of the Form.
errorLabel.setLayoutData(gridData);
uiElement = SWTObservables.observeText(errorLabel);
// Lets Change the color of the field
uiElement.addChangeListener(new IChangeListener(){
public void handleChange(ChangeEvent event) {
if (uiElement.getValue().equals("OK")){
firstName.setBackground(Display.getCurrent().getSystemColor( SWT.COLOR_WHITE));
} else{
firstName.setBackground(Display.getCurrent().getSystemColor( SWT.COLOR_RED));
bindingContext.bindValue(uiElement, new
AggregateValidationStatus(bindingContext.getBindings(),
AggregateValidationStatus.MAX_SEVERITY), null, null);
I believe that it must be possible to connect the message directly with the
databinding validation but I cannot not find an example.
Any advice?
Best regards, Lars
Re: [DataBinding] Connect Databinding Error Message with Eclipse Forms [message #328974 is a reply to message #328971] Mon, 09 June 2008 13:59 Go to previous messageGo to next message
Lars,
AggregateValidationStatus is an IObservableValue so it is not necessary
to bind to a dummy label. You can listen to the status directly:
final IObservableValue validationStatus = new AggregateValidationStatus(
AggregateValidationStatus.MAX_SEVERITY);
validationStatus.addChangeListener(new IChangeListener() {
IStatus status = (IStatus) status.getValue();
if (status.isOK()) {
// handle ok status
} else {
// handle non-ok status
It may be helpful to look at the source for WizardPageSupport,
particularly in the handleStatusChanged() method to see how wizard pages
are supported (which are not too different from UI Forms as far as
setting error messages).
Matthew
Lars Vogel wrote:
> Hello,
> elements.
> databinding?
> @Override
> } else{
> Any advice?
> Best regards, Lars
Re: [DataBinding] Connect Databinding Error Message with Eclipse Forms [message #328978 is a reply to message #328974] Mon, 09 June 2008 15:10 Go to previous messageGo to next message
Hi Matthew,
cool. Thank you, Lars
"Matthew Hall" <matthall@woodcraftmill.com> wrote in message
news:g2jnib$qg2$1@build.eclipse.org...
> Lars,
> // handle ok status
> } else {
> are supported (which are not too different from UI Forms as far as setting
> error messages).
> Matthew
> Lars Vogel wrote:
>> Hello,
>> elements.
>> databinding?
>> of the databinding. I'm then registering a changeListener to this label
>> and I'm updating then the message of the Form.
>> @Override
>> } else{
>> the databinding validation but I cannot not find an example.
>> Any advice?
>> Best regards, Lars
Re: [DataBinding] Connect Databinding Error Message with Eclipse Forms [message #328979 is a reply to message #328974] Mon, 09 June 2008 15:20 Go to previous messageGo to next message
Hi Matthew,
There was a small typo in your code. I believe it should have been:
IStatus status = (IStatus) validationStatus.getValue();
Thank again for your help.
Best regards, Lars
> Lars,
> // handle ok status
> } else {
> error messages).
> Matthew
> Lars Vogel wrote:
>> Hello,
>> elements.
>> databinding?
>> @Override
>> } else{
>> Any advice?
>> Best regards, Lars
Re: [DataBinding] Connect Databinding Error Message with Eclipse Forms [message #328991 is a reply to message #328979] Mon, 09 June 2008 23:48 Go to previous message
See also https://bugs.eclipse.org/bugs/show_bug.cgi?id=219661
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:g2jvpk$eao$1@build.eclipse.org...
> Hi Matthew,
> Best regards, Lars
>> Lars,
>> // handle ok status
>> } else {
>> Matthew
>> Lars Vogel wrote:
>>> Hello,
>>> elements.
>>> databinding?
>>> message of the databinding. I'm then registering a changeListener to
>>> this label and I'm updating then the message of the Form.
>>> @Override
>>> } else{
>>> Any advice?
>>> Best regards, Lars
Previous Topic:[DataBinding] How to bind a List/ListViewer multi selection
Next Topic:How to navigate from StyledText to IEditorPart
Current Time: Tue Nov 04 12:41:49 EST 2025
Powered by FUDForum. Page generated in 0.03503 seconds
