Home » Eclipse Projects » Equinox » aspectj load-time weaving works for OSGi
aspectj load-time weaving works for OSGi [message #31757] Wed, 31 December 2003 11:27 Go to next message
I succeeded to integrate the load-time weaving for AspectJ into the M6
version of the OSGi-based runtime. Thanks for the help.
There are a few points where I somehow struggled with the OSGi runtime.
Any ideas how to improve these things are welcome.
- I wrote my own adaptor to create special class loaders, to start an
additional bundle at startup time and to register a special service.
That is all fine except from the fact that there is currently no
official way to hook my adaptor into the system (as well as to provide
some additional packages to other bundles). Therefore I wrote a bug
report: https://bugs.eclipse.org/bugs/show_bug.cgi?id=48695
- I need to add dependencies between bundles at runtime (as a result of
a woven class, for example). I didn't find a way to do this via the
normal dependency handling inside the OSGi runtime. I finally enhanced
my special class loader with a list of additional required bundles.
These bundles are asked to load a class if the first attempt to load the
class fails. New required bundles can be added at runtime.
-> works for me and does not require any changes to the Eclipse code.
-> but is somehow duplicated code for dependency handling.
- The weaver of AspectJ needs a lot of type information to weave a class
(the class itself and all required types within that class and all
required types of these classes and so on). In my first implementation
for Eclipse 2.1 I collected all required plugins (recursively) for a
plugin, asked for the classpath URLs of the plugins and added them to
the weaver. This is more complicated inside the new runtime. Now I am
using the Bundle.getResource method to load the bytecode for a class if
the weaver asks for it. This is a lot more elegant than the old
implementation but has one problem: Bundle.getResource loads only
resources that are found within the bundle itself or required (or
imported) bundles. I need to find even resources of bundles that are
required (or imported) by required bundles and so on. Therefore I need
an elegant way to collect all required (or imported) bundles from a
bundle recursively. (This part is not part of my special adaptor so I
can use only official API stuff. I found similar code inside the
StateImpl class which I could not adapt because of internal API usage.)
Any ideas and comments are welcome. Thanks!!!
Martin
Re: aspectj load-time weaving works for OSGi [message #31831 is a reply to message #31757] Tue, 06 January 2004 14:00 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
We will address the bug in the next couple weeks. Expect something for M7.
As for the dependency info, the State interface is the thing you want. It
is not official API but will likely end up as "experimental" API in 3.0.
You should look at the PlatformAdmin service and from there get the current
state and traverse the state to find everything you need. Let us know if
there is something you need that you cannot get through this mechanism.
Jeff
"Martin Lippert" <lippert@acm.org> wrote in message
news:bsutb7$nk0$1@eclipse.org...
> Best regards,
> Martin
Re: aspectj load-time weaving works for OSGi [message #32008 is a reply to message #31831] Wed, 07 January 2004 05:41 Go to previous messageGo to next message
Perfect!!! Thanks a lot for that!
Okay, the State interface seems to be pretty fine for that. Thanks for
the hint.
Any idea or comment about this:
Thanks again!
Martin
> Jeff
>>Hi,
>>Best regards,
>>Martin
Re: aspectj load-time weaving works for OSGi [message #32256 is a reply to message #32008] Fri, 09 January 2004 16:57 Go to previous messageGo to next message
for adding dependencies, can you install bundles to add the dependencies?
This allows them to be added ot the state and properly managed by the
runtime.
Jeff
news:btgnnq$3c1$1@eclipse.org...
M7.
It
current
if
> the hint.
> Thanks again!
> Best regards,
> Martin
> > Jeff
> >>Hi,
> >>Best regards,
> >>Martin
Re: aspectj load-time weaving works for OSGi [message #32291 is a reply to message #32256] Sat, 10 January 2004 07:28 Go to previous messageGo to next message
> runtime.
I am not sure what you exactly mean. Do you think of uninstalling and
reinstalling bundles?
Let me give you an example of my problem: bundle A is loaded and
installed. Now class C of bundle A is loaded. At class loading my weaver
weaves this class with aspect X of bundle Y. As a result the type of
aspect X is referenced inside class C. Therefore bundle A needs to
import a package of bundle Y (or require the complete bundle).
This happens during class loading time and might occur after the bundle
A is installed because class C is not the first class of bundle A that
is loaded. Bundle A might already be working for a long time - same for
bundle Y.
The problem might be that this issue seems to be completely against the
idea of bundle dependencies within OSGi. With OSGi each bundle defines
which other bundles (or packages) are needed at bundle install time. I
would like to change this while the bundle is already working. Do you
think that this is somehow possible?
Thanks again,
Martin
Re: aspectj load-time weaving works for OSGi [message #32400 is a reply to message #32291] Sat, 10 January 2004 21:16 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer.ca.ibm.com
I think I see where you are going. I was off with the install bundles
comment.
What I am really trying to get at is that whatever mechanism you use, you
should not just hack something in to the classloaders. You need to actually
express the new dependency in the state. I will demonstrate using your
example.
Assume that C has been loaded and so now bundle A has a dependency on bundle
Y. What happens if Y is uninstalled? The OSGi framework detects who is
affected by traversing the state and associated datastrucutres. If you
dependency is not in there, bundle A will likely be left inconsistent.
The notion of dynamically adding dependencies is not foreign to OSGi. The
Dynamic-ImportPackage mechanism accomplishes this. For example, if all
bundles in your system had
Dynamic-ImportPackage: *
in their manifest.mf and they bundles supplying aspects had
Export-Package: <packages containing aspects>
in theirs, you woudl be quite happy.
This feels like the best route for you to follow.
Jeff
news:btor3o$2go$1@eclipse.org...
dependencies?
> > runtime.
> bundle Y.
> Thanks again,
> Martin
Re: aspectj load-time weaving works for OSGi [message #32609 is a reply to message #32400] Sun, 11 January 2004 15:57 Go to previous messageGo to next message
> example.
Yes, I know that the classloader hack is somewhat ugly and does not
conform to the ideas of a dynamic runtime. That is why I am asking... ;-)
I see that the dynamic package import stuff is the right way. But I am
not sure whether I fully understood the mechanism. Three open questions:
- any plugin that could be affected by an aspect would need to specify
"Dynamic-ImportPackage: *" in the manifest. But I would like to weave
existing plugins, for example several JDT plugins, with some aspects
without adapting the plugins to the weaving (by adding the "*" dynamic
import).
- I know from the weaving which aspect is woven into which class.
Therefore I am able to define the newly added dependencies exactly.
- What does the "*" dynamic import means to the dynamic features of the
runtime? What happens if a plugin specifies a "*" dynamic import and
another plugin that exports some package is uninstalled?
Is it somehow possible to tell the runtime to add some exact dynamic
imports to installed bundles?
Thanks for all the support!
Martin
Re: aspectj load-time weaving works for OSGi [message #32679 is a reply to message #32609] Sun, 11 January 2004 21:10 Go to previous messageGo to next message
news:btsd8o$9fb$1@eclipse.org...
> import).
first two quesitons with one answer... There is no real magic here. At a
certain point in the class look up sequence we look for dynamic imports. At
that point you could (for question 1) automagically assume there is a * and
lookup any class or (for question 2), keep a list of classes you need to
depend on and look them up there.
The real issue here is how to ensure that the framework still behaves in the
face of dynamic uninstall/update. There will be details. I don't have the
code in front of me right now so cannot go further but suggest that making
your new classes look as much like dynamic imports as possible will be the
easiest path for you.
This is handled correctly. The when something is uninstalled/updated the
framework effectively knows who has loaded classes from it and so who needs
to be kicked. The dependencies are reresolved and dependent bundles either
link up to a different bundle or become unresolved. It is here you want to
ensure that the dependencies you have dynamically added need to be handled.
See above.
Jeff
Re: aspectj load-time weaving works for OSGi [message #32853 is a reply to message #32679] Tue, 13 January 2004 13:06 Go to previous messageGo to next message
I took a look at the dynamic package import functionality and it seems
to me that mainly the BundleLoader deals with it. Therefore I don't know
how to add, for example, a new dynamic import to that loader or to
change the setting to "*" at runtime. Did I ignore something?
Thanks again!
Martin
Re: aspectj load-time weaving works for OSGi [message #34218 is a reply to message #32853] Tue, 20 January 2004 16:18 Go to previous messageGo to next message
>> At a
>> imports. At
>> * and
>> in the
>> have the
>> making
>> the
Any idea on that?
-Martin
Re: aspectj load-time weaving works for OSGi [message #34356 is a reply to message #34218] Wed, 21 January 2004 21:32 Go to previous messageGo to next message
news:buk5r6$oip$1@eclipse.org...
> >> At a
> >> imports. At
> >> * and
to
> >> in the
> >> have the
> >> making
> >> the
> Any idea on that?
Not right now. I'd have to dig through the code to see what is happening
where. what you say about the BundleLoader sounds right though. Try adding
something to bundle loader like addDynamicImport(). The implementation
should be reasonably straightforward. If you can prototype this we can look
at adding the support for real. Otherwise we are all up to our necks
preparing for EclipseCon and M7 so cannot be too proactive on non-critical
items.
Jeff
Re: aspectj load-time weaving works for OSGi [message #34490 is a reply to message #34356] Fri, 23 January 2004 18:08 Go to previous messageGo to next message
>>Any idea on that?
> items.
The BundleLoader has a method called "initDynamicImportPackage". This
method could be used to add dynamic imports at runtime, from my point of
view. For that it only has to be set to public visibility.
The way to access this method (for example from my special adaptor or
class loader) would still be somewhat ugly, but that might be okay (two
ways to access the BundleLoader: cast from Bundle to BundleHost to call
the method getBundleLoader on BundleHost or access the protected field
of BundleClassLoader "delegate" to BundleLoader).
Does that sounds reasonable?
Thanks again!
Martin
Re: aspectj load-time weaving works for OSGi [message #34558 is a reply to message #34490] Wed, 28 January 2004 10:25 Go to previous messageGo to next message
Can you do what you need to or do you need changes? For now we can hack to
get you going and understand how to do this more elegantly later.
Jeff
news:bus9dd$8d5$1@eclipse.org...
know
> >>Any idea on that?
happening
adding
look
non-critical
> > items.
> Thanks again!
> Best regards,
> Martin
Re: aspectj load-time weaving works for OSGi [message #34592 is a reply to message #34558] Wed, 28 January 2004 16:02 Go to previous messageGo to next message
The only change I need is a change in the visibility of the method:
protected void initDynamicImportPackage(ManifestElement[] packages)
in BundleLoader. This is now protected and I would need it to be public
(to call it from my specialised classloader). I already tried it and it
works fine with the dynamic import mechanism. Would be wonderful to have
that in an upcoming milestone release. Thanks again!!!
-Martin
> Jeff
>>Hi,
> know
>>>>Any idea on that?
> happening
> adding
> look
> non-critical
>>>items.
>>Thanks again!
>>Best regards,
>>Martin
Re: aspectj load-time weaving works for OSGi [message #34626 is a reply to message #34592] Thu, 29 January 2004 00:18 Go to previous messageGo to next message
done
news:bv97tt$9s7$1@eclipse.org...
to
> -Martin
> > Jeff
> >>Hi,
seems
> > know
> >>>>Any idea on that?
> > happening
> > adding
> > look
> > non-critical
> >>>items.
> >>Thanks again!
> >>Best regards,
> >>Martin
Re: aspectj load-time weaving works for OSGi [message #34660 is a reply to message #34626] Thu, 29 January 2004 17:56 Go to previous messageGo to next message
> done
Perfect. Thanks a lot for the support!!!
-Martin
>>Hi,
> to
>>-Martin
>>>Jeff
>>>>Hi,
> seems
>>>know
>>>>>>Any idea on that?
>>>happening
>>>adding
>>>look
>>>non-critical
>>>>>items.
>>>>Thanks again!
>>>>Best regards,
>>>>Martin
Re: aspectj load-time weaving works for OSGi [message #36270 is a reply to message #34558] Thu, 04 March 2004 17:03 Go to previous messageGo to next message
I observed one problem with my dynamic adding of DynamicImportPackages.
The list of dynamic imports inside BundleLoader is growing with each
class that is loaded because the loader does not check if the package
that is added via initDynamicImportPackage is already in the list of
dynamic imports. They are always added and I got a huge number of
duplicates in it. I would like to solve this problem. Therefore I found
two options:
1. Make the initDynamicImportPackage method of BundleLoader aware of
duplicates.
2. Make the method isDynamicallyImported of BundleLoader public so that
I can check if the package is already importet before I call
initDynamicImportPackage to add it.
I would prefer option 2 since it requires less changes to the code of
BundleLoader. What do you think?
Thanks!!!
Martin
> Jeff
>>Hi,
> know
>>>>Any idea on that?
> happening
> adding
> look
> non-critical
>>>items.
>>Thanks again!
>>Best regards,
>>Martin
Re: aspectj load-time weaving works for OSGi [message #36869 is a reply to message #36270] Thu, 11 March 2004 05:02 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
Sorry for the delay in responding. For some reason my news reader only just
decided to show my your post...
Please enter an enhancement request. #2 looks good/easy.
Jeff
news:c288tg$pu4$1@eclipse.org...
to
> two options:
> duplicates.
> Thanks!!!
> Best regards,
> Martin
> > Jeff
> >>Hi,
seems
> > know
> >>>>Any idea on that?
> > happening
> > adding
> > look
> > non-critical
> >>>items.
> >>Thanks again!
> >>Best regards,
> >>Martin
Re: aspectj load-time weaving works for OSGi [message #37070 is a reply to message #36869] Thu, 11 March 2004 14:59 Go to previous message
Done. Take a look at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=54524
Thanks for the support!!!
-Martin
> Jeff
>>Hi,
> to
>>two options:
>>duplicates.
>>Thanks!!!
>>Best regards,
>>Martin
>>>Jeff
>>>>Hi,
> seems
>>>know
>>>>>>Any idea on that?
>>>happening
>>>adding
>>>look
>>>non-critical
>>>>>items.
>>>>Thanks again!
>>>>Best regards,
>>>>Martin
Previous Topic:Knopflerfish OSGi
Next Topic:[advice needed] Programmatically installed bundles
Current Time: Fri Jul 18 18:47:41 EDT 2025
Powered by FUDForum. Page generated in 0.54527 seconds
