Home » Eclipse Projects » Eclipse Platform » Externally using a plugin
Externally using a plugin [message #327883] Wed, 07 May 2008 07:31 Go to next message
I would like to use the org.eclipse.compare plugin from en external Java
swing application.
I found this:
http://dev.eclipse.org/newslists/news.eclipse.platform.swt/m sg39359.html
which shows how to integrate Eclipse components with Swing.
When I try to create the compare plugin classes there are a lot of inner
variables that are not initialized and cause NullPointerException.
How can I work with this plugin externally?
Thank you,
Moshe.
Re: Externally using a plugin [message #327889 is a reply to message #327883] Wed, 07 May 2008 09:44 Go to previous message
Originally posted by: eclipse-news.rizzoweb.com
Moshe wrote:
> Hello,
> swing application.
> I found this:
This is not a realistic goal. Most Eclipse plugins are not designed or
implemented as simple reusable components. For example,
org.eclipse.compare depends on all of these other plugins:
org.eclipse.ui
org.eclipse.core.resources
org.eclipse.jface.text
org.eclipse.ui.ide
org.eclipse.ui.views
org.eclipse.ui.workbench.texteditor
org.eclipse.core.runtime
org.eclipse.core.expressions
org.eclipse.ui.editors
org.eclipse.ui.forms
So for it to work all of those plugins' code has to be available along
with whatever each of them depends on.
Eclipse plugins are NOT generic stand-alone components to be reused;
they only work in the context of the Eclipse platform.
Eric
Previous Topic:On pressing enter in a text box the cursor goes to the first position
Next Topic:bin directory stays empty
Current Time: Sat Oct 11 15:50:18 EDT 2025
Powered by FUDForum. Page generated in 0.29094 seconds
