Home » Language IDEs » Java Development Tools (JDT) » accessing non-Java files
accessing non-Java files [message #32786] |
Tue, 20 May 2003 18:47  |
Originally posted by: wrcox.ucsd.edu
Eclipse Platform v2.1.0
Windows XP
My web application is structured as follows:
\webapps\mywebapp\javascript\*.js
\webapps\mywebapp\WEB-INF\classes\com\mycompany\myproject\*. java
\webapps\mywebapp\WEB-INF\xml\com\mycompany\myproject\*.xml
When I set up an Eclipse Java Project, I point it to
\webapps\mywebapps\WEB-INF\classes. This works fine for Java. I can see
all the packages and classes in the Java Browsing perspective. However, I
cannot see my XML and Javascript. I tried pointing Eclipse to
\webapps\mywebapp, but then I could not see the Java packages and classes
properly. For those, I need to use the linked folder feature, which works
fine. I view Javascript and XML in the Resources perspective.
But, when I start adding the Java to CVS, it does not allow me to add any
of the XML or Javascript. I guess this is because they are linked folders.
1. Is there an easier way to see non-Java files in my project and still
have the benefits of the Java Browsing perspective? That is, is
...\classes the right place to point Eclipse for my project?
2. How can I have one project within which I commit and update Java, XML
and Javascript through CVS?
-Will
Re: accessing non-Java files [message #33403 is a reply to message #32786] |
Wed, 21 May 2003 09:15   |
You should point your project to '\webapps\mywebapp', then add
'WEB-INF\classes' as a source folder (see Project->Properties->Java Build
Path->Source)
You will be able to see non-Java files in 'javascript' and 'WEB-INF\xml'
under the project and you will be able to manage them through CVS.
Jerome
"Will Cox" <wrcox@ucsd.edu> wrote in message
news:baeba2$8c1$1@rogue.oti.com...
> Windows XP
folders.
> -Will
Re: accessing non-Java files [message #34333 is a reply to message #33403] |
Wed, 21 May 2003 14:56   |
Several people asked me this question today...
How, within Eclipse, can I open a file anywhere on my local machine (i.e.
not part of the project).
Related...if someone mailed me a few .java files, how do I add these to an
existing project?
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:bafu4r$f0r$1@rogue.oti.com...
> Path->Source)
> Jerome
> > Windows XP
see
I
classes
works
any
> folders.
XML
> > Thanks,
> > -Will
Re: accessing non-Java files [message #35409 is a reply to message #33403] |
Thu, 22 May 2003 12:31   |
Jerome,
Thank you for your response. I solved this a different way and it brings
up a larger issue. My *.java files really shouldn't be in
WEB-INF/classes, right? They should be in WEB-INF/src. My current
project puts both *.java and *.class into WEB-INF/classes.
What I did to make it work is as follows: Added /WEB-INF/classes/edu to
the Java Build Path-Libraries and in Java Build Path-Source excluded
WEB-INF/classes/edu (otherwise it complains). That seems to work OK
except that it exhibits a strange behavior. In the Java Browsing
perspective, I cannot edit the source until I've first gone to view it in
the Resource Perspective!?
When I try your way, it immediately tells me that all builds will go into
a MyProject/bin directory. If I say YES. I press OK and it then says
"The output folder has changed. OK to remove all generated sources from
the old location /MyProject".
I'm going to try seperating out the source from the class files
(WEB-INF/src and WEB-INF/classes), and then tell it about each in the
Source and Libraries tabs respectively. Hopefully that will make it happy.
-Will
> Path->Source)
> Jerome
> > Windows XP
> folders.
> > Thanks,
> > -Will
Re: accessing non-Java files [message #36377 is a reply to message #34333] |
Fri, 23 May 2003 04:41   |
This is not currently possible. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37935 for more details.
"Paul Duffy" <paduffy@cisco.com> wrote in message
news:bagi4v$1op$1@rogue.oti.com...
> existing project?
Build
> > Path->Source)
> > Jerome
> > > Windows XP
> see
However,
> I
> classes
> works
> any
> > folders.
still
> XML
> > > Thanks,
> > > -Will
Re: accessing non-Java files [message #37610 is a reply to message #36404] |
Fri, 23 May 2003 18:12  |
> Actually you could have your .java files and .class files in the same
> directory. You need to use a custom output folder for the source folder:
> 1. Check 'Allow output folders for source folders'
> 2. In the list above, expand the source folder
> 3. Select 'Output folder'
> 4. Edit
> 5. Select the same folder
I achieved the same thing by not checking the "Allow output folders..."
and setting the "Default output folder" to be the same as the source
folder. Are there any pros/cons doing it my way vs yours?
> But if you want to separate the source and the compiled classes, that's ok
> too.
> Not sure what you mean here. Are you saying that you don't see the source in
> the Java perspective?
No, actually, I was seeing it in both but the preprocessor (checking for
warnings and errors) and editor were not working in the Java Browsing
perspective and *were* working in the Resource perspective. Strange.
Current Time: Fri Jul 18 10:09:45 EDT 2025
Powered by FUDForum. Page generated in 1.06448 seconds
