Home » Eclipse Projects » Eclipse Platform » Ganymede java development setup
Ganymede java development setup [message #327858] Tue, 06 May 2008 12:08 Go to next message
I installed Ganymede and created a new project from source I had used
under Europa. Somehow I must have changed a setting because the runtime
debugging does not find the source files in my project. Specifically if
I push F3 on a declaration in a .java file, I end up in a .class file,
not another .java file of source. Even then the .class file was shown as
decompiled until I used the button on the decompile view to link the
source. Now the source shows up, but it not .java but .class file.
Any hints on how to make it work on source files?
John.
Re: Ganymede java development setup [message #327859 is a reply to message #327858] Tue, 06 May 2008 12:25 Go to previous message
I remembered the magical Project->PDE Command->Update Classpath: it
fixed itself.
John
Previous Topic:How to disable a feature without Eclipse Configuration Manager?
Next Topic:compile error for eclipse-sourceBuild-srcIncluded-3.4M7.zip
Current Time: Tue Oct 07 20:00:12 EDT 2025
Powered by FUDForum. Page generated in 0.02197 seconds
