Home » Archived » M2M (model-to-model transformation) » [ATL] [newbie] acces to enumeration
[ATL] [newbie] acces to enumeration [message #32601] Thu, 19 April 2007 03:56 Go to next message
Originally posted by: tristan.faure.c-s.fr
I am new with ATL and i have to do model transformation from UML2 (Class /
statemachine) to IF (verification language)
I've made my metamodel IF and i have an ecore file and i don't have any
problem for some transformations but ....
i've defined an enumeration type in my ecore
<eClassifiers xsi:type="ecore:EEnum" name="ParametersMode">
<eLiterals name="null"/>
<eLiterals name="out" value="1"/>
<eLiterals name="inout" value="2"/>
<eLiterals name="in" value="3"/>
</eClassifiers>
and I don't know how to access to it from ATL rule
rule Property2Variables {
from
p : UML!Property
to
v : _IF!Vars (
name <- p.name,
mode <- ? ? ? ,
type <- p.getType()
at the launching I have a problem when i try to insert the mode because he
needs a parametersMode (my enum)
Thank you
Re: [ATL] [newbie] acces to enumeration [message #32635 is a reply to message #32601] Thu, 19 April 2007 04:24 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Tristan,
Tristan FAURE wrote:
> Hi
> / statemachine) to IF (verification language)
> </eClassifiers>
> from p : UML!Property to
> v : _IF!Vars (
> name <- p.name,
> mode <- ? ? ? ,
> type <- p.getType()
> he needs a parametersMode (my enum)
> Thank you
To set the value of the "mode" attribute (which is of an enumeration
type)you can write: "mode <- #null", "mode <- #out", etc
The way we often use is to define an helper that returns the right value
corresponding to a given parameter. Here is an example of such an helper
(the context and the parameter(s) may vary):
helper def: getParametersMode(p : String) : IF!ParametersMode =
if (p = ??) then
#null
else
if (p = ??) then
#out
else
endif;
Then you can call this helper in the matched rule:
"mode <- thisModule.getParametersNode(p.??),"
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] [newbie] acces to enumeration [message #32670 is a reply to message #32635] Thu, 19 April 2007 04:35 Go to previous messageGo to next message
Hugo Bruneliere wrote:
> Hi Tristan,
>> Hi
>> </eClassifiers>
>> v : _IF!Vars (
>> name <- p.name,
>> mode <- ? ? ? ,
>> type <- p.getType()
>> Thank you
> if (p = ??) then
> #null
> else
> if (p = ??) then
> #out
> else
> endif;
> Best regards,
> Hugo
Thank you for your answer assigning the value with a sharp was what i
understanded from the documentation but when I insert #null or when I use
the helper you provide to me I have this launching error
java.lang.IllegalArgumentException: The value '' is not a valid enumerator
of 'ParametersMode'
at
org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFa ctoryImpl.java:269)
at
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getDefault Value(EStructuralFeatureImpl.java:129)
at
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:780)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:1115)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:833)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:818)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1114)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2548)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1043)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:929)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2268)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1397)
at
at
at
at
at
at
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XM LSaveImpl.java:617)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:549)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:233)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:203)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1008)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:896)
at
org.atl.eclipse.engine.AtlEMFModelHandler.saveModel(AtlEMFMo delHandler.java:79)
at
org.atl.eclipse.engine.AtlEMFModelHandler.saveModel(AtlEMFMo delHandler.java:43)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:241)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:168)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:145)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:121)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .launch(AtlLaunchConfigurationDelegate.java:97)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:710)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:603)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Re: [ATL] [newbie] acces to enumeration [message #32705 is a reply to message #32670] Thu, 19 April 2007 05:16 Go to previous messageGo to next message
It seems that the transformation works but that the problem comes when
the produced model is saved (i.e. serialized).
Could you send the helper you use and the rule in which you call it?
Have you got other error messages from the console (I mean ATL ones)?
>> Hi Tristan,
>>> Hi
>>> (Class / statemachine) to IF (verification language)
>>> any problem for some transformations but ....
>>> </eClassifiers>
>>> v : _IF!Vars (
>>> name <- p.name,
>>> mode <- ? ? ? ,
>>> type <- p.getType()
>>> because he needs a parametersMode (my enum)
>>> Thank you
>> value corresponding to a given parameter. Here is an example of such
>> an helper (the context and the parameter(s) may vary):
>> if (p = ??) then
>> #null
>> else
>> if (p = ??) then
>> #out
>> else
>> endif;
>> Best regards,
>> Hugo
> use the helper you provide to me I have this launching error
> enumerator of 'ParametersMode'
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [ATL] [newbie] acces to enumeration [message #32738 is a reply to message #32705] Thu, 19 April 2007 05:29 Go to previous messageGo to next message
First i'm sorry because i'm using the web interface of the newsgroup and i
don't know if it is possible to join files so i will copy code here (if
you know a newsgroup software which works with proxy :/)
I'm also sorry the error was not the good there is no launching error but
there is this trace in the console :
****** BEGIN Stack Trace
message: cannot set feature _IF!Vars.mode to value null
exception:
of 'ParametersMode'
at
at
at
at
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(Basi cEObjectImpl.java:709)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:683)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:654)
at
org.atl.engine.repositories.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:226)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:27 6)
at org.atl.engine.vm.ASMOperation.exec(ASMOperation.java:155)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 60)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 50)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:21 4)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:30 9)
at org.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:276)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:1 36)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:9 4)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:6 8)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:6 4)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:230)
at
at
at
at
at
at
at
at
A.main() : ??#24 null
local variables = {self=uml2if : ASMModule}
local stack = []
A.__exec__() : ??#38 null
local variables = {e=TransientLink {rule = 'Property2Variables',
sourceElements = {p = IN!cursor}, targetElements = {v = OUT!cursor},
variables = {}}, self=uml2if : ASMModule}
local stack = []
A.__applyProperty2Variables(1 : NTransientLink;) : ??#21 75:25-75:69
local variables = {v=OUT!cursor, p=IN!cursor, link=TransientLink {rule =
'Property2Variables', sourceElements = {p = IN!cursor}, targetElements =
{v = OUT!cursor}, variables = {}}, self=uml2if : ASMModule}
local stack = [OUT!cursor]
****** END Stack Trace
Execution terminated due to error (see launch configuration to allow
continuation after errors).
So this is my module it's just a prototype so it's not very big
module uml2if; -- Module Template
create OUT:_IF from IN:UML ;
-- getting the enum value from a string
if (p = 'null') then
#null
else
if (p = 'out') then
#out
else
#null
endif
endif
helper context UML!Property def : getType() : String =
if (self.type = 'Integer') then
'integer'
else
'integer1'
endif
helper context UML!Package def : getProcesses() : Set(UML!Class) =
self.ownedMember->select(a|a.oclIsTypeOf(UML!Class))
rule Package2System {
from
p : UML!Package (p.oclIsTypeOf(UML!Package))
to
s : _IF!System (
id <- p.name,
process <- p.getProcesses()
rule Class2Process {
from
c : UML!Class (c.oclIsTypeOf(UML!Class))
to
s : _IF!Process (
id <- c.name ,
nbInstancesToStart <- '1',
vars
rule Vertex2State {
from
v : UML!Vertex (v.oclIsTypeOf(UML!Vertex))
to
s : _IF!State (
id <- v.name
from
p : UML!Property
to
v : _IF!Vars (
name <- p.name,
mode <- thisModule.getParametersNode('null') ,
type <- p.getType()
Re: [ATL] [newbie] acces to enumeration [message #32763 is a reply to message #32738] Thu, 19 April 2007 05:45 Go to previous messageGo to next message
> i don't know if it is possible to join files so i will copy code here
> (if you know a newsgroup software which works with proxy :/)
> but there is this trace in the console :
> exception: java.lang.IllegalArgumentException: The value '' is not a
> valid enumerator of 'ParametersMode'
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> local stack = []
> local stack = []
> {rule = 'Property2Variables', sourceElements = {p = IN!cursor},
> targetElements = {v = OUT!cursor}, variables = {}}, self=uml2if :
> ASMModule}
> #null
> else
> if (p = 'out') then
> #out
> else
> #null
> endif
> endif
> 'integer'
> else
> 'integer1'
> endif
> helper context UML!Package def : getProcesses() : Set(UML!Class) = (
> from
> to
> s : _IF!System (
> id <- p.name,
> from
> to
> s : _IF!Process (
> id <- c.name ,
> vars
> rule Vertex2State {
> from v : UML!Vertex (v.oclIsTypeOf(UML!Vertex))
> to s : _IF!State (
> id <- v.name
> v : _IF!Vars (
> name <- p.name,
> type <- p.getType()
Is the IF!Vars.mode attribute of type IF!ParametersMode in your IF
metamodel?
Re: [ATL] [newbie] acces to enumeration [message #32778 is a reply to message #32763] Thu, 19 April 2007 06:00 Go to previous messageGo to next message
yes
this my declaration in my if.ecore (generated by topcased)
<eClassifiers xsi:type="ecore:EClass" name="Vars">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type"
lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="mode"
lowerBound="1" eType="#//ParametersMode"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value"
</eClassifiers>
Re: [ATL] [newbie] acces to enumeration [message #32842 is a reply to message #32778] Thu, 19 April 2007 08:08 Go to previous message
I think I have a probleme with my meta model because I've just used
another enum and it's ok so I will check and notify if it still not work
Previous Topic:Comparative study between ATL and ETL
Next Topic:[ATL Plugin] Autocompletion doesn't work
Current Time: Fri Aug 15 23:06:34 EDT 2025
Powered by FUDForum. Page generated in 0.08217 seconds
