Home » Eclipse Projects » Eclipse Platform » How to setup data binding for master details page
How to setup data binding for master details page [message #327363] Wed, 16 April 2008 11:23 Go to next message
Originally posted by: harald.pehl.googlemail.com
I'm currently writing a contact manager for managing contact from different sources (http://code.google.com/p/abcom/).
In my application each contact has several addresses, emails, phone numbers, etc. I created a form based / multi page editor for the contact. On the addresses page there's a list with all addresses. By selecting one address the user can edit the address details (like street, city, zip, ...)
For the sync between the model and the master details stuff I'd like to use JFace Databinding. I found a very simple example under http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.e xamples.databinding/src/org/eclipse/jface/examples/databindi ng/snippets/Snippet010MasterDetail.java?view=markup
The example is very limited: There's just one text widget to edit the selected entry from the list. What I need is to sync several widgets with the selected address from the contacts address list.
Does someone have samples how to use data binding in combination with master detail pages and more complex model objects?
Thanks in advance!
Harald
Re: How to setup data binding for master details page [message #327379 is a reply to message #327363] Wed, 16 April 2008 17:17 Go to previous messageGo to next message
Harald,
Take a look at Snippet 017: Table viewer with derived columns
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.e xamples.databinding/src/org/eclipse/jface/examples/databindi ng/snippets/Snippet017TableViewerWithDerivedColumns.java?vie w=markup
Matthew
Harald Pehl wrote:
> Thanks in advance!
> Harald
Re: How to setup data binding for master details page [message #327488 is a reply to message #327379] Tue, 22 April 2008 04:15 Go to previous message
Hi Matthew,
thanks for your tip! After adopting the sample code to my special needs, my master-details formeditor works!
Greetings from Munich, Germany
Harald
Previous Topic:Problem with installing Plug-in
Next Topic:SharedHeaderFormEditor with complex HeadClient and decorateFormHeading
Current Time: Sun Nov 09 16:59:13 EST 2025
Powered by FUDForum. Page generated in 0.05482 seconds
