| [buckminster-dev] Buckminster, headless and making the two co-operate [message #32699] |
Fri, 15 May 2009 12:03 |
Hi!
I have a working setup of Buckminster (in my IDE) and I have a
Buckminster headless installation. So to explain my problem in a simple way:
Works for me:
http://wiki.eclipse.org/Hello_XML_World_Example_(Buckminster)
So that's using Buckminster in an IDE.
Also works for me (partially):
http://wiki.eclipse.org/Sample_headless_configuration_(Buckminster)
I was able to finish the "Installing required features" section, so I am
here:
../buckminster listsite
Features:
org.eclipse.buckminster.core.headless.feature_1.1.340.r10056
(Buckminster - Core Headless)
org.eclipse.buckminster.cvs.headless.feature_1.0.0.r09930
(Buckminster - CVS support for headless operation)
org.eclipse.buckminster.maven.feature_1.1.0.r09904 (Buckminster -
Maven support)
org.eclipse.buckminster.pde.headless.feature_1.1.340.r10061
(Buckminster - PDE support for headless operation)
org.eclipse.buckminster.product_1.1.340.r10068 (Buckminster Product)
org.eclipse.buckminster.subversive.headless.feature_1.0.0.r0 9908
(Buckminster - Subversive based SVN support for headless operation)
Now I am trying to do something useful as described under "Let's try
loading a workspace with some very simple test components:"
Unfortunately
http://www.eclipse.org/buckminster/samples/queries/build_a.c query
(the URL used in the example)
is a 404.
So I tried the URL from the other IDE based Howto:
../buckminster -data fridaysworkspace resolve
http://www.eclipse.org/buckminster/samples/queries/demo.cque ry
All I am getting is a single line of output:
org.xml.sax.SAXNotSupportedException:
http://apache.org/xml/features/validation/schema
I guess this may very well be because my headless environment does not
have a lot of stuff in it. It might not even have a Java compiler for
examples, does it?
But my question is: How would I
a) determine and
b) install
the features I would need in my headless environment to build my app?
Torsten
FUDForum. Page generated in 0.03391 seconds
