| Home » Eclipse Projects » Eclipse Platform » How to reference a documentation plug-in's HTML in the browser widget?
 Goto Forum:|
| How to reference a documentation plug-in's HTML in the browser widget? [message #326536] | Sun, 23 March 2008 01:54  |  |
| Eclipse User  |  |  |  |  | Hi,
 Basically I have HTML content displayed by an IInformationControl, such
 as the BrowserInformationControl, which is implemented to use the SWT
 Browser widget to display HTML content.
 How would I specify via the href tag in my HTML content to reference a
 documentation plug-in's HTML content.
 I tried the below format, but does not help.
 <a href="/com.acme.doc.plugin_id/html/index.html">go to acme's doc
 plug-in content</a>
 That does not seem to work.
 Thanks for any tips!
| Re: How to reference a documentation plug-in's HTML in the browser widget? [message #326567 is a reply to message #326552] | Tue, 25 March 2008 08:38   |  |
| Eclipse User  |  |  |  |  | Originally posted by: merks.ca.ibm.com
 AL,
 I think you could use FileLocator.toFileURL which I think will unpack
 the plugin if necessary.  Of course it's best to use the URL directly if
 at all possible, i.e, get the input stream from the URL directly...
 AL wrote:
 > AL wrote:
 >> Hi,
 >> such as the BrowserInformationControl, which is implemented to use
 >> the SWT Browser widget to display HTML content.
 >> a documentation plug-in's HTML content.
 >> plug-in content</a>
 > I think I've figured out how to do this.  Get my documentation's
 > plug-in's bundle via
 > Activator.getInstance().getBundle().getEntry("html-path").  This
 > returns a java.net.URL.  I should then able to resolve it to an
 > absolute path.
 > The one requirement is that the documentation plug-in, when deployed,
 > must be deployed with the unpack="true", which is specified in the
 > feature.xml.
 > Any other way to do this?
 > Thanks.
| Re: How to reference a documentation plug-in's HTML in the browser widget? [message #326581 is a reply to message #326567] | Tue, 25 March 2008 13:04   |  |
| Eclipse User  |  |  |  |  | Ed Merks wrote: > AL,
 Thanks for tip, but I am still a bit not clear.  The HTML stuff I want
 to display in my IInformationControl has an href to the documentation
 plug-in's HTML content, for example, the TOC content.  So, basically, I
 need the href to have the correct path put in the href at runtime.  I am
 not attempting to read the content, just referencing it.
 Not sure if I need FileLocator.
 So, if my documentation plug-in is deployed as a JAR file, where would
 FileLocator.toFileURL unpack the stuff at runtime? It would be probably
 bad to unpack every time I need to locate something that had already
 been unpacked already.
 Anyway, I ended up doing the below to get the path to my plug-in--with
 one caveat and that is requiring the doc plug-in to have "unpack=true".
 "Activator" is my doc plug-in.
 String slocation = Activator.getDefault().getStateLocation().toOSString();
 int index = slocation.indexOf(':');  //$NON-NLS-1$
 String location = Activator.getDefault().getBundle().getLocation();
 location = location.substring(location.indexOf('/'),
 location.length());
 if (index > 0) {
 location = slocation.substring(0, index + 1) + location;
 > AL wrote:
 >> AL wrote:
 >>> Hi,
 >>> plug-in content</a>
 >> absolute path.
 >> feature.xml.
 >> Thanks.
| Re: How to reference a documentation plug-in's HTML in the browser widget? [message #326584 is a reply to message #326581] | Tue, 25 March 2008 14:16   |  |
 AL,
 I think it would unpack the whole plugin.   You could use
 platform:/plugin/<plugin-ID>/<path in plugin> to refer to it that way;
 the platform: protocol is a real live registered URL handler when
 running in Eclipse...
 AL wrote:
 > Ed Merks wrote:
 >> AL,
 >> if at all possible, i.e, get the input stream from the URL directly...
 > I need the href to have the correct path put in the href at runtime.
 > I am not attempting to read the content, just referencing it.
 > probably bad to unpack every time I need to locate something that had
 > already been unpacked already.
 > "unpack=true".  "Activator" is my doc plug-in.
 > String slocation =
 > location.length());
 >       if (index > 0) {
 >> AL wrote:
 >>> AL wrote:
 >>>> Hi,
 >>>> reference a documentation plug-in's HTML content.
 >>>> plug-in content</a>
 >>> absolute path.
 >>> deployed, must be deployed with the unpack="true", which is
 >>> specified in the feature.xml.
 >>> Thanks.
| Re: How to reference a documentation plug-in's HTML in the browser widget? [message #326592 is a reply to message #326591] | Tue, 25 March 2008 16:47   |  |
 AL,
 You're actually running this within an Eclipse process?  You're sure you
 have the path right?  If you create a URL for your path and open a
 stream, does that work?   The information in
 http://lmap.blogspot.com/2008/03/platform-scheme-uri.html should be
 accurate...
 AL wrote:
 > Ed Merks wrote:
 >> AL,
 >> I think you could use this directly in your href tag.  I think the
 >> file locator would handle it too.  The advantage of the former is
 >> that the plugin shouldn't need to be unzipped and the value doesn't
 >> change depending on the installed location of the plugin...
 > Tried it out to use form "platform:/plugin/<plugin-ID>/<path in
 > plugin>" directly in the href tag. It does not work.
 > If you have any more tips, greatly appreciate it.  Thanks.
 >> AL wrote:
 >>> Ed Merks wrote:
 >>>> AL,
 >>>> way; the platform: protocol is a real live registered URL handler
 >>>> when running in Eclipse...
 >>> Thanks, just to be clear.  I put "platform:/plugin/<plugin-ID>/<path
 >>> to HTML file>" in my href tag?  Or I am passing this in to
 >>> FileLocator, which, looking at the code, takes Bundle and IPath?
| Re: How to reference a documentation plug-in's HTML in the browser widget? [message #326598 is a reply to message #326597] | Tue, 25 March 2008 17:32  |  |
 > Yes, but you should be able to do all this without EMF.  new
 > URL("platform:/plugin/<plugin-id>/plugin.xml").openStream() for example...
 Ok, the openstream does not cause any exception, but the href still does
 not work with platform URI format.  It wants an absolute path, and
 currently my using Bundle.getLocateState() and Bundle.getLocation() does
 the trick.  I tested on Linux and Windows.  It works fine, although I
 like the URI approach better.
 Thanks.
 Current Time: Thu Oct 30 21:01:16 EDT 2025
 Powered by FUDForum . Page generated in 0.09821 seconds |
