Home » Eclipse Projects » Eclipse Platform » Extending Folder resource
| Extending Folder resource [message #325568] |
Fri, 22 February 2008 04:37  |
I want to extend the org.eclipse.core.internal.resources.Folder to create my
own type of a Folder and add to the behavior and some of my own
manipulations. When I try to directly extend it, the constructor returns a
ClassCastException. Even if I try to cast a folder object to my own custom
folder, I get the same ClassCastException.
We cannot extend classes defined under org.eclipse.core.internal.resources,
is it? Would you suggest on how to try to the same! :-)
Thanks.
| Re: Extending Folder resource [message #325633 is a reply to message #325608] |
Sun, 24 February 2008 04:26   |
Hi Eric and Ed!
Thanks a lot for the prompt responses. From what I did read around, I felt
you cannot pretty much extend the internal classes but I wanted to reconfirm
from someone.. So thanks for that... Eric I am looking at basically holding
a custom object/handle associated with each folder falling under a certain
group of special folders I have defined under a project.. So for this, one
of the approach was to make my custom class extend the folder and then add
some of my own behaviorial methods to it.. This way I would be able to keep
it all under a single object, my stuff + folder representation..
Am not sure how I would be able to do something similar via extension
points... Any direction there would be great! But thanks a lot for the
replies anyway...
Rahul
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:fpnpe1$hj5$3@build.eclipse.org...
> Rahul Kamdar wrote:
>> Hi,
>> my own type of a Folder and add to the behavior and some of my own
>> a ClassCastException. Even if I try to cast a folder object to my own
>> custom folder, I get the same ClassCastException.
>> org.eclipse.core.internal.resources, is it? Would you suggest on how to
> As Ed already said, its futile to try to extend internal classes.
> What behavior, specifially, are you wanting to add? Many things can be
> done via extension points.
> Eric
| Re: Extending Folder resource [message #325635 is a reply to message #325633] |
Sun, 24 February 2008 08:16   |
--------------070409010403050104040102
Rahul,
I imagine this could be done via a registered IAdapterFactory; an
IResource is an IAdaptable. You could exploit
IResource.getPersistenceProperty/setPersistenProperty to help implement
your adapter.
Rahul Kamdar wrote:
> Hi Eric and Ed!
> replies anyway...
> Rahul
>> Rahul Kamdar wrote:
>>> Hi,
>> Eric
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Rahul,<br>
<br>
your adapter.<br>
<br>
<br>
Rahul Kamdar wrote:
<blockquote cite="mid:fprd8r$53u$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Eric and Ed!
replies anyway...
Rahul
"Eric Rizzo" <a class="moz-txt-link-rfc2396E" href="mailto:eclipse-news@rizzoweb.com"><eclipse-news@rizzoweb.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fpnpe1$hj5$3@build.eclipse.org">news:fpnpe1$hj5$3@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Rahul Kamdar wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap="">As Ed already said, its futile to try to extend internal classes.
Eric
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------070409010403050104040102--
| Re: Extending Folder resource [message #325637 is a reply to message #325635] |
Sun, 24 February 2008 12:37  |
------=_NextPart_000_001F_01C8773A.0B212830
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Ed,
Thanks again for the quick help... I think the IAdaptorFactory should do =
just the work I need... I'll check up and get back if I need some =
help/pointers!! Thanks a lot!
Rahul
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fprqnd$nit$1@build.eclipse.org...
Rahul,
I imagine this could be done via a registered IAdapterFactory; an =
IResource is an IAdaptable. You could exploit =
IResource.getPersistenceProperty/setPersistenProperty to help implement =
your adapter.
Rahul Kamdar wrote:=20
Hi Eric and Ed!
Thanks a lot for the prompt responses. From what I did read around, I =
felt=20
you cannot pretty much extend the internal classes but I wanted to =
reconfirm=20
from someone.. So thanks for that... Eric I am looking at basically =
holding=20
a custom object/handle associated with each folder falling under a =
certain=20
group of special folders I have defined under a project.. So for this, =
one=20
of the approach was to make my custom class extend the folder and then =
add=20
some of my own behaviorial methods to it.. This way I would be able to =
keep=20
Am not sure how I would be able to do something similar via extension=20
points... Any direction there would be great! But thanks a lot for the=20
replies anyway...
Rahul
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message=20
Rahul Kamdar wrote:
I want to extend the org.eclipse.core.internal.resources.Folder to =
create=20
my own type of a Folder and add to the behavior and some of my own=20
manipulations. When I try to directly extend it, the constructor returns =
a ClassCastException. Even if I try to cast a folder object to my own=20
We cannot extend classes defined under=20
org.eclipse.core.internal.resources, is it? Would you suggest on how to=20
What behavior, specifially, are you wanting to add? Many things can be=20
Eric=20
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.6000.16525" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanks again for the quick help... I =
think the=20
IAdaptorFactory should do just the work I need... I'll check up and get =
back if=20
I need some help/pointers!! Thanks a lot!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Rahul</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fprqnd$nit$1@build.eclipse.org">news:fprqnd$nit$1@build.ecli=
pse.org</A>...</DIV>Rahul,<BR><BR>I=20
IResource is=20
an IAdaptable. You could exploit=20
IResource.getPersistenceProperty/setPersistenProperty to help =
implement your=20
adapter.<BR><BR><BR>Rahul Kamdar wrote:=20
<BLOCKQUOTE cite=3Dmid:fprd8r$53u$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi Eric and Ed!
felt=20
reconfirm=20
holding=20
certain=20
one=20
add=20
keep=20
replies anyway...
Rahul
"Eric Rizzo" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:eclipse-news@rizzoweb.com"><eclipse-news@rizzoweb.com&g=
t;</A> wrote in message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fpnpe1$hj5$3@build.eclipse.org">news:fpnpe1$hj5$3@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Rahul Kamdar wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
create=20
</PRE></BLOCKQUOTE><PRE wrap=3D"">As Ed already said, its futile =
Eric=20
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_001F_01C8773A.0B212830--
Current Time: Sat Nov 08 12:33:35 EST 2025
Powered by FUDForum. Page generated in 0.03762 seconds
