Home » Eclipse Projects » Eclipse Platform » Contributing popup menu item only for selected project nature
Contributing popup menu item only for selected project nature [message #325146] Mon, 11 February 2008 02:49 Go to next message
Originally posted by: ptrinchini.quipo.it
I would contribute some commands to the pop-up menu of the project
explorer view; for this purpose I defined the following menu contribution:
<extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI=" popup:org.eclipse.ui.navigator.ProjectExplorer#PopupMenu?aft er=additions ">
<command
commandId="myplugin.command.mycommand"
icon="icons/etool16/mycommand.png"
label="Run mycommand"
mnemonic="M1+P"
tooltip="Do something with this project">
</command>
</menuContribution>
</extension>
this works fine, i.e. the command appears in the popup menu.
However, when I try to add a filter to have the command visible only
when a project with a given nature is selected:
<visibleWhen>
<test property="org.eclipse.core.resources.projectNature"
value="myplugin.natures.mynature">
</test>
</visibleWhen>
the command simply disappears!
This happens also for any other kind of visibleWhen filter; maybe I'm
missing something, but what?
Thanks a lot for your time reading this post
Patrizio
Re: Contributing popup menu item only for selected project nature [message #325154 is a reply to message #325146] Mon, 11 February 2008 08:15 Go to previous messageGo to next message
> <visibleWhen>
> </test>
> </visibleWhen>
Try:
<visibleWhen>
<iterate operator="and">
</test>
</iterate>
</visibleWhen>
[/xml]
Also check out the core expressions link in my sig.
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Contributing popup menu item only for selected project nature [message #325346 is a reply to message #325154] Fri, 15 February 2008 01:45 Go to previous messageGo to next message
>> <visibleWhen>
>> </test>
>> </visibleWhen>
> Try:
> <visibleWhen>
> </test>
> </iterate>
> </visibleWhen>
> [/xml]
> Later,
> PW
Thanks a lot Paul, adding the iterate element solved the problem, Now
I'm able to get my command when a project with the given nature i
selected in the project explorer.
However I get it also when I right click on an empty space in the
project explorer; in this case the selection is empty (null) so the
handler doesn't execute, but it would be nice to hide the command when
the selection is empty.
Is it possible to achieve this with the visibleWhen condition ?
Thanks again for your help
Patrizio
Re: Contributing popup menu item only for selected project nature [message #325361 is a reply to message #325346] Fri, 15 February 2008 09:42 Go to previous messageGo to next message
It's an attribute on the iterate element, what to return if empty.
PW
Paul Webster
Re: Contributing popup menu item only for selected project nature [message #325368 is a reply to message #325361] Fri, 15 February 2008 10:49 Go to previous message
> PW
Paoul,
again, many many thanks ! it works perfectly now!!
Patrizio
Previous Topic:Problem with launching RCP application on eclipse 3.3
Next Topic:actionSet location in toolbar
Current Time: Mon Sep 22 07:23:52 EDT 2025
Powered by FUDForum. Page generated in 0.07516 seconds
