Home » Archived » M2M (model-to-model transformation) » [ATL] find a target element by resolveTemp
[ATL] find a target element by resolveTemp [message #31548] |
Fri, 13 April 2007 13:38  |
Originally posted by: benoit.combemale.gmail.com
Hi all,
It is possible to find in a "matched rule" (A) a target model
element (by resolveTemp) created by a "called rule" called by
another "matched rule" (B) ?
thx,
Ben.
Benoît COMBEMALE
Re: [ATL] find a target element by resolveTemp [message #31618 is a reply to message #31584] |
Sat, 14 April 2007 09:10   |
Hi Mikael,
Thx you for your response. In fact, my concrete problem is the fallowing :
rule A2B {
from MMa!A
to
..... -- target elements creation for all A
do {
if ( A.isXXX ) {
thisModule.myCalledRule(A) -- target elements creation when A is XXX
And now, i would like to find target elements created when A is XXX in another
rule.
Indeed, i can use two matched rule (A_WhichIsXXX2B and A_WhichIsNotXXX2B) but
i repeat all the common part :(
have you got some solutions ?
ben.
On Fri, 13 Apr 2007 20:56:23 +0200, Mikaël Barbero <mikael.barbero@gmail.com> wrote :
> Hi Ben,
> No, it is not possible as called rule are not matched !! You must use
> matched rule or lazy rule (restrictions exist in this case).
> Regards,
> Mikael
> Benoit Combemale wrote:
>> Hi all,
>> thx,
>> Ben.
Benoît COMBEMALE
Re: [ATL] find a target element by resolveTemp [message #31653 is a reply to message #31618] |
Sat, 14 April 2007 11:06   |
Thx you for your help Mikael.
I resolve my problem by the use of rule inheritance.
Ben.
On Sat, 14 Apr 2007 15:10:06 +0200, Benoit Combemale <benoit.combemale@gmail.com> wrote :
> Hi Mikael,
> rule A2B {
> from MMa!A
> to
> do {
> if ( A.isXXX ) {
> rule.
> Regards,
> ben.
>> Hi Ben,
>> Regards,
>> Mikael
>>> Hi all,
>>> thx,
>>> Ben.
Benoît COMBEMALE
Re: [ATL] find a target element by resolveTemp [message #32250 is a reply to message #32215] |
Tue, 17 April 2007 03:57   |
Originally posted by: mikael.barbero.gmail.com
Hi Benoit,
I'm glad to see that you solved your problem.
There are restrictions when you have multiple lazy rules matching the
same model element: ATL is not able to determine which one has to be
selected.
Mikael
> which are the restrictions on resolveTemp when the target element
> is created by one lazy rule ?
> Thx
> ben.
>> Hi Ben,
>> Regards,
>> Mikael
>>> Hi all,
>>> thx,
>>> Ben.
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] find a target element by resolveTemp [message #32533 is a reply to message #32250] |
Wed, 18 April 2007 09:51   |
Hi Mikael,
In my work, I've one lazy rule called by one matched rule (A).
In another matched rule (B), I try to find the target element created
by the lazy rule.
I've an execution error :
"message: ERROR: could not find operation including on Module
having supertypes: [OclAny]"
Have you got an example with a lazy rule called by a first matched rule
and a second matched rule which use resolveTemp to find the target element
created by the lazy rule ?
Ben.
On Tue, 17 Apr 2007 09:57:30 +0200, Mikaël Barbero <mikael.barbero@gmail.com> wrote :
> Hi Benoit,
> selected.
> Regards,
> Mikael
>> Thx
>> ben.
>>> Hi Ben,
>>> Regards,
>>> Mikael
>>>> Hi all,
>>>> thx,
>>>> Ben.
Benoît COMBEMALE
Re: [ATL] find a target element by resolveTemp [message #34709 is a reply to message #32533] |
Fri, 27 April 2007 11:07  |
Hello Benoit,
It is possible that resolveTemp does not always work correctly with lazy
rules, I will have to look into this.
However, there is a relatively simple way to make this work: splitting
the lazy rule (see example below).
If you have something like:
rule A {
from
s : MMa!A
to
t : MMb!A (
b <- thisModule.B(s.b),
-- may not work, and apparently does not
-- work in your case
c <- thisModule.resolveTemp(s.b, 't2')
-- Note that referring to several target elements of a lazy rule
-- mostly makes sense when this rule is *unique*, otherwise it would
-- mean invoking the rule once again.
unique lazy rule B {
from
s : MMa!B
to
t : MMb!B (
c <- t2
t2 : MMb!C
You may rewrite it into:
rule A {
from
s : MMa!A
to
t : MMb!A (
b <- thisModule.B_1(s.b),
c <- thisModule.B_2(s.b)
unique lazy rule B_1 { -- or B2B
from
s : MMa!B
to
t : MMb!B (
c <- thisModule.B_2(s)
unique lazy rule B_2 { -- or B2C
from
s : MMa!B
to
t : MMb!C
Frédéric Jouault
> Hi Mikael,
> by the lazy rule.
> Regards,
> Ben.
>> Hi Benoit,
>> selected.
>> Regards,
>> Mikael
>>> Thx
>>> ben.
>>>> Hi Ben,
>>>> Regards,
>>>> Mikael
>>>>> Hi all,
>>>>> thx,
>>>>> Ben.
Current Time: Sat Jun 07 21:52:37 EDT 2025
Powered by FUDForum. Page generated in 0.05689 seconds
