Home » Eclipse Projects » Eclipse Platform » Decouple org.eclipse.compare from IDE
Decouple org.eclipse.compare from IDE [message #325325] Thu, 14 February 2008 12:20 Go to next message
I saw this bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=207704
which mentions decoupling the compare functionality from the IDE to be
used in RCP application. The bug goes in a different direction
(decoupling the ui from the core), so I though I should post here first.
Is it feasible to make compare usable in RCP applications and is there
any interest? Are there better alternatives? Should I make a separate
enhancement request for this?
Sorry for posting on two newsgroups, but I was not sure which was
appropriate.
Re: Decouple org.eclipse.compare from IDE [message #325355 is a reply to message #325325] Fri, 15 February 2008 05:44 Go to previous messageGo to next message
In 3.3 the application specific part got removed from the ide.ui plug-in
and hence you can simply add it to your list of required plug-ins,
unless of course size is really crucial for your RCP application.
Dani
> separate enhancement request for this?
> appropriate.
Re: Decouple org.eclipse.compare from IDE [message #325389 is a reply to message #325355] Fri, 15 February 2008 22:42 Go to previous messageGo to next message
> Dani
I don't understand - in 3.3 org.eclipse.ui.ide seems to contain quite a
bit of Eclipse IDE application specific code.
>> appropriate.
Re: Decouple org.eclipse.compare from IDE [message #325410 is a reply to message #325389] Mon, 18 February 2008 05:44 Go to previous messageGo to next message
>>> be used in RCP application. The bug goes in a different direction
>>> first.
>> plug-in and hence you can simply add it to your list of required
>> plug-ins, unless of course size is really crucial for your RCP
>> application.
>> Dani
> a bit of Eclipse IDE application specific code.
What exactly are you referring to?
Dani
>>> there any interest? Are there better alternatives? Should I make a
>>> appropriate.
Re: Decouple org.eclipse.compare from IDE [message #325434 is a reply to message #325410] Mon, 18 February 2008 12:50 Go to previous messageGo to next message
>>>> first.
>>> application.
>>> Dani
I was looking at the views (ResourceNavigator, etc) and the commands
(buildProject, selectWorkingSets, etc). I guess this is fairly generic
code, but it only makes sense in an "IDE".
The only immediately noticeable thing I get from adding
org.eclipse.ui.ide is some unwanted menu items ("File Open..." in the
file menu, "Software Updates..." on the Help menu, etc).
> Dani
>>>> appropriate.
Re: Decouple org.eclipse.compare from IDE [message #325449 is a reply to message #325434] Tue, 19 February 2008 03:26 Go to previous message
>>>> Will Horn wrote:
>>>>> I saw this bug
>>>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=207704 which
>>>>> first.
>>>> application.
>>>> Dani
>>> quite a bit of Eclipse IDE application specific code.
> generic code, but it only makes sense in an "IDE".
That's why I said "if you don't care about size". Some apps might indeed
want to use working sets and some might want to use core.resources and
hence all the core.resources related UI stuff.
Your RCP application can provide its own workbench advisor and hence
remove the unwanted menu(items)s easily.
Dani
>> Dani
>>>>> a separate enhancement request for this?
>>>>> appropriate.
Previous Topic:Eclipse Project SDK 3.2.2 - repair broken plugin?
Next Topic:Template preference page, auto insert column label
Current Time: Fri Sep 19 05:55:20 EDT 2025
Powered by FUDForum. Page generated in 0.07645 seconds
