Home » Eclipse Projects » Eclipse Platform » General IDE slowdown and cleanliness
General IDE slowdown and cleanliness [message #324612] |
Tue, 29 January 2008 06:54  |
Good morning,
First, I would like to state that Eclipse is one of the best IDE(s) /
platforms that I have worked with over the course of my many years of
development and absolutely love the platform.
Having said that, we have a small development team building a Web
application and have found that over time the IDE tends to slow down in many
regards (build, launch, editors, etc). This is expected as the application
grows in size but a large part of this can be related to the platform
itself.
Over time as the platform evolves and plugins are added / removed / updated,
it has a negative impact on the performance of the platform. This can be
evidenced by the fact that 4 months ago we started with a clean IDE
environment and just recently went to a clean environment again (fresh
install, including plugins) and the environment has become much snappier
(albeit an over the should stop watch approach, but significant
nonetheless). I can only assume that this is related to artifacts that tend
to accumulate in the system itself that causes this performance degradation.
I guess my question is, has anyone else experienced this (I am going to
assume yes) and is anyone looking at this?
Furthermore, the refresh of our environment (including plugins) has not been
what I would consider a painless procedure due to the fact that a large
number of our plugins and settings have to be reconfigured (we do have a
separate extension point for plugins, but have found that it was not a
seamless procedure to bring these forward). It has been a few days and we
are still trying to configure our new and snappier IDE with our plugin set,
with some of them just not functioning as before.
Again, why is this such a painful procedure?
Any thoughts.?
BTW: In no way is this meant to start a religious rant / flame war, just
wanted to highlight some of our "real" experiences in an effort to improve
the situation which I am sure other people are experiencing.
Whatty
Re: General IDE slowdown and cleanliness [message #324617 is a reply to message #324612] |
Tue, 29 January 2008 07:17   |
Steve,
Comments below.
Steve Whatmore wrote:
> Good morning,
Yes, along with vi plugin to pamper my long term dependency, it's hard
to beat
> itself.
Is this perhaps more a WTP question/issue than a platform one?
It might well be. Personally I'm always getting new ones because I need
to track the development stream. It's not clear though how much of your
issue comes from what's accumulated in the workspace verses what's
accumulated in the configuration. If you use a new workspace with the
existing configuration, does that still seem to have gotten more sluggish?
I wouldn't assume that. I'm not aware of any known issues with the
configuration itself growing slower over time. (Even simple
fragmenting in the file system itself at the OS level could cause
slowness; speaking of which, I think I need to defragment my disk again.)
Generally I export all my preferences and then import them. It's a
little annoying because some preference point at physical things that
depend on the install location, so I end up scanning the preference file
looking for such hard coded dependencies and deleting them textually.
Generally the result makes me happy since I will install new eclipses
sometime several times per month.
That sucks. Doesn't exporting preferences work for these?
I'm a little frustrated that most projects don't contribute categories
for their preferences, so it's hard to selectively deal with them as a
big whack of all of them crammed together. But then, I'm not sure if
you've tried this approach?
> Any thoughts.?
Your positive comments at the beginning made that clear. The old
"butter'm up before you bash'm approach", or what an old friend used to
call "damning with faint praise". When you have a good thing, of course
you want it to be better...
> Whatty
Re: General IDE slowdown and cleanliness [message #324636 is a reply to message #324612] |
Tue, 29 January 2008 14:25   |
Originally posted by: wharley.bea.com
"Steve Whatmore" <steven.whatmore@lynxdev.com> wrote in message
news:fnn45r$fd4$1@build.eclipse.org...
> updated, it has a negative impact on the performance of the platform. This
> can be evidenced by the fact that 4 months ago we started with a clean IDE
> tend to accumulate in the system itself that causes this performance
> degradation.
As Ed pointed out, "platform" is a little ambiguous here. To folks on this
list, "platform" just refers to a particular Eclipse component (basically
the IDE framework), but I think you mean "all of Eclipse" by that term,
including WTP, PDE, JDT, and perhaps other components as well. The
distinction is important because you may get different answers from people
using different components.
As a Java developer only, I use JDT and PDE, but not WTP or its other
dependencies. I also don't have any third-party plugins. I haven't noticed
any slowdown in IDE performance over time, even in workspaces that I've had
in continuous development for several years. Just one data point.
The Eclipse platform (including JDT and PDE) gets regular automated
performance testing, to ensure that new features and bug fixes don't cause
performance degradation; you can see those results linked to from the
downloads page. However, of course, those apply only to fresh installs, not
to installs that have been used over time, which is the scenario you're
discussing. I mention this simply to clarify a possible point of confusion.
> been what I would consider a painless procedure due to the fact that a
> large number of our plugins and settings have to be reconfigured (we do
> have a separate extension point for plugins, but have found that it was
> not a seamless procedure to bring these forward). It has been a few days
> and we are still trying to configure our new and snappier IDE with our
> plugin set, with some of them just not functioning as before.
Can you be a bit more specific? I'm not clear whether you're talking about
the plug-ins that came with Eclipse, about third-party plug-ins you've
added, or about plug-in projects that you're developing.
-Walter Harley
JDT APT team
Re: General IDE slowdown and cleanliness [message #324638 is a reply to message #324636] |
Tue, 29 January 2008 15:22   |
Just another data point here - I have a Toshiba laptop (3GHz P4, 1.5 GB
RAM) on which Eclipse starts lightning fast the very first time I run a
new install. After that it is dog slow every time. This is the only
machine I have that behaves this way but I can literally go get lunch
and it *might* be started up when I get back. Sometimes not so much.
Using the network to do something else seems to kick it in the tail
sometimes but that's not consistent either. Once it starts it works as
well as any other system I use. This has been going on since I bought
the machine in the 3.1 time frame. The fact that any machine acts that
way makes me hesitate to distribute Eclipse based product to pedestrian
users. Fortunately for now I can build the things I need to distribute
as SWT/JFace applications. Those launch without any hesitation issues
beyond Java's own.
Now I suppose I need to go try again to track down the start up troubles
and either fix whatever is wrong with the Toshiba configuration or get
enough good data to open a bug.
Steve
>> degradation.
> -Walter Harley
> JDT APT team
Re: General IDE slowdown and cleanliness [message #324639 is a reply to message #324638] |
Tue, 29 January 2008 15:28   |
Steve,
What else do you have installed? It sounds like a network time out
kind of problems. Might you have documents that are validated be
schemas loaded from the network?
> GB RAM) on which Eclipse starts lightning fast the very first time I
> run a new install. After that it is dog slow every time. This is the
> only machine I have that behaves this way but I can literally go get
> lunch and it *might* be started up when I get back. Sometimes not so
> much. Using the network to do something else seems to kick it in the
> tail sometimes but that's not consistent either. Once it starts it
> works as well as any other system I use. This has been going on since
> I bought the machine in the 3.1 time frame. The fact that any machine
> acts that way makes me hesitate to distribute Eclipse based product to
> pedestrian users. Fortunately for now I can build the things I need
> to distribute as SWT/JFace applications. Those launch without any
> hesitation issues beyond Java's own.
> troubles and either fix whatever is wrong with the Toshiba
> configuration or get enough good data to open a bug.
> Steve
>>> platform. This can be evidenced by the fact that 4 months ago we
>>> started with a clean IDE environment and just recently went to a
>>> clean environment again (fresh install, including plugins) and the
>>> environment has become much snappier (albeit an over the should stop
>>> watch approach, but significant nonetheless). I can only assume that
>>> this is related to artifacts that tend to accumulate in the system
>>> to assume yes) and is anyone looking at this?
>> on this list, "platform" just refers to a particular Eclipse
>> component (basically the IDE framework), but I think you mean "all of
>> Eclipse" by that term, including WTP, PDE, JDT, and perhaps other
>> components as well. The distinction is important because you may get
>> different answers from people using different components.
>> noticed any slowdown in IDE performance over time, even in workspaces
>> that I've had in continuous development for several years. Just one
>> data point.
>> cause performance degradation; you can see those results linked to
>> from the downloads page. However, of course, those apply only to
>> fresh installs, not to installs that have been used over time, which
>> is the scenario you're discussing. I mention this simply to clarify
>>> not been what I would consider a painless procedure due to the fact
>>> that a large number of our plugins and settings have to be
>>> reconfigured (we do have a separate extension point for plugins, but
>>> have found that it was not a seamless procedure to bring these
>>> forward). It has been a few days and we are still trying to
>>> configure our new and snappier IDE with our plugin set, with some of
>> about the plug-ins that came with Eclipse, about third-party plug-ins
>> you've added, or about plug-in projects that you're developing.
>> Thanks,
>> -Walter Harley
>> JDT APT team
Re: General IDE slowdown and cleanliness [message #324640 is a reply to message #324639] |
Tue, 29 January 2008 15:59   |
I got the same behavior when I installed 3.4M4 Platform SDK before I
added anything else. I'll do some digging to sort it out now that I
mentioned it.
Ed Merks wrote:
> Steve,
>> Steve
>>> data point.
>>> Thanks,
>>> -Walter Harley
>>> JDT APT team
Re: General IDE slowdown and cleanliness [message #324700 is a reply to message #324640] |
Wed, 30 January 2008 15:22   |
First of all thanks for the responses.
1) Plug-ins
I purposely install any plugs-in into their own extension point (based
on a article I read a while back) where I should be able to update the base
Eclipse environment (ie. 3.2 -> 3.3) and just point it at the extension
point to get all my installed plug-ins. This to a certain degree works but I
find various differences between the old environment and the updated
environment. I am not sure why this is but is not what I expected.
I utilize a number of plugins such as PMD, Subversion,
ResourceBundleEditor, etc and the hope was that once I update the base
Eclipse environment it would not be a difficult process to bring this
plugins forward, but again given that this process is not seamless it has
proven more difficult than expected.
2) As too general slow-down.
Once I update the base environment, it seems for whatever reason that IDE
becomes much more responsive. I can run two parallel environments the
original install that I have been working with over the course of the last
several months and the clean install (essentially the same version installed
into a new directory). The two versions definitely perform at a much
different level, with the newer install generally being much snappier. This
is why I am lead to believe (given all else being equal, ie. network,
projects, etc) that there are some artifacts being created in the normal
course of working with the IDE that has a negative impact on the performance
of the IDE.
I hope this provides further clarification as too the root of some of my
experiences.
Whatty
"Steve Blass" <sblass@acm.org> wrote in message
news:fno43q$q70$1@build.eclipse.org...
>I got the same behavior when I installed 3.4M4 Platform SDK before I added
>anything else. I'll do some digging to sort it out now that I mentioned
>it.
> Ed Merks wrote:
>> Steve,
>> What else do you have installed? It sounds like a network time out kind
>> of problems. Might you have documents that are validated be schemas
>>> beyond Java's own.
>>> Steve
>>>>> This can be evidenced by the fact that 4 months ago we started with a
>>>>> clean IDE environment and just recently went to a clean environment
>>>>> again (fresh install, including plugins) and the environment has
>>>>> become much snappier (albeit an over the should stop watch approach,
>>>>> but significant nonetheless). I can only assume that this is related
>>>>> to artifacts that tend to accumulate in the system itself that causes
>>>> this list, "platform" just refers to a particular Eclipse component
>>>> (basically the IDE framework), but I think you mean "all of Eclipse" by
>>>> that term, including WTP, PDE, JDT, and perhaps other components as
>>>> well. The distinction is important because you may get different
>>>> data point.
>>>> cause performance degradation; you can see those results linked to from
>>>> the downloads page. However, of course, those apply only to fresh
>>>> installs, not to installs that have been used over time, which is the
>>>> scenario you're discussing. I mention this simply to clarify a
>>>>> forward). It has been a few days and we are still trying to configure
>>>>> our new and snappier IDE with our plugin set, with some of them just
>>>> Thanks,
>>>> -Walter Harley
>>>> JDT APT team
Re: General IDE slowdown and cleanliness [message #324704 is a reply to message #324700] |
Wed, 30 January 2008 16:22   |
news:fnqmb9$kti$1@build.eclipse.org...
> base Eclipse environment (ie. 3.2 -> 3.3) and just point it at the
> extension point to get all my installed plug-ins. This to a certain degree
> works but I find various differences between the old environment and the
> updated environment. I am not sure why this is but is not what I expected.
I think you're using "extension point" to mean something different than what
it usually means in the Eclipse context. Mostly that term refers to a
declarative means of providing specific functionality, that plug-ins declare
and use via their plugin.xml files. For instance,
"org.eclipse.ui.propertyPages" is the extension point that plug-ins use to
declare property pages.
I think you're describing what would more commonly be called an "extension
location".
Not trying to criticize, just trying to clarify a possible confusion, and
help anyone who's trying to Google these terms.
> installed into a new directory). The two versions definitely perform at a
> much different level, with the newer install generally being much
> snappier. This is why I am lead to believe (given all else being equal,
> ie. network, projects, etc) that there are some artifacts being created in
> the normal course of working with the IDE that has a negative impact on
> the performance of the IDE.
That's a nice way to do the experiment, and seems quite relevant. It's hard
to say how to take it the next step, into figuring out where the bug might
lie.
I'm guessing that the important thing that happens when you update the base
environment is that any plug-in caches and installation metadata get
replaced. You might try simulating this, in a currently-slow install, by
removing the eclipse/configuration directory in that install (or using
command-line or .ini options to specify a different configuration directory
location). Back it up first! If that makes it speed up, you could further
pursue by removing only individual subfolders of that directory.
Thanks! Input of this sort is valuable.
-walter
Re: General IDE slowdown and cleanliness [message #324748 is a reply to message #324704] |
Thu, 31 January 2008 10:42   |
You are correct what I am referring to is an extension location.
"Walter Harley" <wharley@bea.com> wrote in message
news:fnqpr4$g0s$1@build.eclipse.org...
>> degree works but I find various differences between the old environment
>> and the updated environment. I am not sure why this is but is not what I
>> expected.
> what it usually means in the Eclipse context. Mostly that term refers to
> a declarative means of providing specific functionality, that plug-ins
> declare and use via their plugin.xml files. For instance,
> location".
>> last several months and the clean install (essentially the same version
>> in the normal course of working with the IDE that has a negative impact
>> on the performance of the IDE.
> hard to say how to take it the next step, into figuring out where the bug
> might lie.
> base environment is that any plug-in caches and installation metadata get
> directory location). Back it up first! If that makes it speed up, you
> could further pursue by removing only individual subfolders of that
> directory.
> -walter
Re: General IDE slowdown and cleanliness [message #324756 is a reply to message #324639] |
Thu, 31 January 2008 11:36   |
It wasn't network time outs but on-access virus scanner settings that
had been making Eclipse start slow for me on that one PC. Updating to
the newest AV software engine and adjusting settings has sped things up
incredibly. D'Oh!
Steve
Ed Merks wrote:
> Steve,
>> Steve
>>> data point.
>>> Thanks,
>>> -Walter Harley
>>> JDT APT team
Re: General IDE slowdown and cleanliness [message #324760 is a reply to message #324756] |
Thu, 31 January 2008 12:02   |
Steve,
Not only do we answer questions, we take confessions and absolve
transgressions. :-P
> up incredibly. D'Oh!
> Steve
> Ed Merks wrote:
>> Steve,
>>> the only machine I have that behaves this way but I can literally go
>>> get lunch and it *might* be started up when I get back. Sometimes
>>> not so much. Using the network to do something else seems to kick it
>>> in the tail sometimes but that's not consistent either. Once it
>>> starts it works as well as any other system I use. This has been
>>> going on since I bought the machine in the 3.1 time frame. The fact
>>> that any machine acts that way makes me hesitate to distribute
>>> Eclipse based product to pedestrian users. Fortunately for now I
>>> can build the things I need to distribute as SWT/JFace
>>> applications. Those launch without any hesitation issues beyond
>>> Java's own.
>>> Steve
>>>>> / updated, it has a negative impact on the performance of the
>>>>> stop watch approach, but significant nonetheless). I can only
>>>>> assume that this is related to artifacts that tend to accumulate
>>>>> going to assume yes) and is anyone looking at this?
>>>> of Eclipse" by that term, including WTP, PDE, JDT, and perhaps
>>>> other components as well. The distinction is important because you
>>>> may get different answers from people using different components.
>>>> other dependencies. I also don't have any third-party plugins. I
>>>> haven't noticed any slowdown in IDE performance over time, even in
>>>> workspaces that I've had in continuous development for several
>>>> don't cause performance degradation; you can see those results
>>>> linked to from the downloads page. However, of course, those apply
>>>> only to fresh installs, not to installs that have been used over
>>>> time, which is the scenario you're discussing. I mention this
>>>>> has not been what I would consider a painless procedure due to the
>>>>> fact that a large number of our plugins and settings have to be
>>>>> but have found that it was not a seamless procedure to bring these
>>>> talking about the plug-ins that came with Eclipse, about
>>>> third-party plug-ins you've added, or about plug-in projects that
>>>> you're developing.
>>>> Thanks,
>>>> -Walter Harley
>>>> JDT APT team
Current Time: Thu Sep 18 20:05:24 EDT 2025
Powered by FUDForum. Page generated in 0.04393 seconds
