Home » Eclipse Projects » Eclipse Platform » Where is the XML Editor in 3.4M4?
Where is the XML Editor in 3.4M4? [message #324037] Wed, 16 January 2008 17:36 Go to next message
Originally posted by: mark_z.charter.net
This is very similar to my solved question back after the release of 3.3,
which can be found here:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg66 168.html
I'm trying to use the 3.4M4 download of "Eclipse Classic". Upon
upgrading, it seems I lost the XML Editor (and other web features).
As I had installed the WTP/WST downloads into a separate plugins
directory, I thought that maybe there was just an incompatibility. So I
removed all my other plugins, and downloaded and installed the matching,
latest WTP 3.3M4 release from here:
http://www.eclipse.org/downloads/download.php?file=/webtools /downloads/drops/R3.0/S-3.0M4-20080105091323/wtp-S-3.0M4-200 80105091323.zip
Before and after my WTP/WST upgrade, "Eclipse XML Editors and Tools"
appeared under my Help / Software Updates / Manage Configuration screen.
However, no editors appear available. The "Web & XML" preferences section
is also missing from Window / Preferences.
I've verified that Eclipse is running under jdk1.6.0_04.
Is this a known issue, or is there something else I need to
configure/download?
Thanks!
Re: Where is the XML Editor in 3.4M4? [message #324062 is a reply to message #324037] Thu, 17 January 2008 05:02 Go to previous messageGo to next message
Mark,
Likely it's better to ask on the WTP newsgroup. Maybe try the
following. Clear the error log (using the Error Log view or removing
<workspace>/.metadata/.log, shutdown, and restart with eclipse.exe
-clean -debug. Then look closely at the error log to see if it's
complaining about any plugins that have failed to activate...
> 3.3, which can be found here:
> I removed all my other plugins, and downloaded and installed the
> matching, latest WTP 3.3M4 release from here:
> screen. However, no editors appear available. The "Web & XML"
> preferences section is also missing from Window / Preferences.
> configure/download?
> Thanks!
Re: Where is the XML Editor in 3.4M4? [message #324089 is a reply to message #324062] Thu, 17 January 2008 10:19 Go to previous messageGo to next message
Thanks for the response. I've already checked the log, as well as using a
new workspace. I'll try to continue trouble-shooting it a bit more, then
will probably take your suggestion to try the WTP newsgroup.
Thanks!
Ed Merks wrote:
> Mark,
>> configure/download?
>> Thanks!
Re: Where is the XML Editor in 3.4M4? [message #324091 is a reply to message #324089] Thu, 17 January 2008 10:25 Go to previous messageGo to next message
Mark,
The -debug flag will produce more messages than you'd get otherwise.
In particular it will describe why plugins are disabled. The -clean
might be needed to make it reprocess all the plugins...
> using a new workspace. I'll try to continue trouble-shooting it a bit
> more, then will probably take your suggestion to try the WTP newsgroup.
> Thanks!
> Ed Merks wrote:
>> Mark,
>>> So I removed all my other plugins, and downloaded and installed the
>>> configure/download?
>>> Thanks!
Re: Where is the XML Editor in 3.4M4? [message #324114 is a reply to message #324091] Thu, 17 January 2008 11:55 Go to previous messageGo to next message
Thanks! That helped solved it. I was missing the prerequisites for the
"Eclipse Modeling Framework" and "Graphical Editing Framework".
Interesting this doesn't show up without -debug...
Ed Merks wrote:
> Mark,
>> Thanks!
>> Ed Merks wrote:
>>> Mark,
>>>> configure/download?
>>>> Thanks!
Re: Where is the XML Editor in 3.4M4? [message #324122 is a reply to message #324114] Thu, 17 January 2008 12:19 Go to previous messageGo to next message
Mark,
How could you over look EMF?! It's like a linchpin! :-P
Yes, without the -debug, plugins will just quietly be disabled when
their dependencies aren't satisfied... That's intentional because the
platform ships some plugins that only work for Java 5.0 and they don't
want folks getting warned about that. For everything else it seems
generally not so good...
> the "Eclipse Modeling Framework" and "Graphical Editing Framework".
> Ed Merks wrote:
>> Mark,
>>> bit more, then will probably take your suggestion to try the WTP
>>> newsgroup.
>>> Thanks!
>>> Ed Merks wrote:
>>>> Mark,
>>>> removing <workspace>/.metadata/.log, shutdown, and restart with
>>>> eclipse.exe -clean -debug. Then look closely at the error log to
>>>> see if it's complaining about any plugins that have failed to
>>>> activate...
>>>>> of 3.3, which can be found here:
>>>>> incompatibility. So I removed all my other plugins, and
>>>>> downloaded and installed the matching, latest WTP 3.3M4 release
>>>>> from here:
>>>>> Tools" appeared under my Help / Software Updates / Manage
>>>>> Configuration screen. However, no editors appear available. The
>>>>> "Web & XML" preferences section is also missing from Window /
>>>>> Preferences.
>>>>> configure/download?
>>>>> Thanks!
Re: Where is the XML Editor in 3.4M4? [message #324141 is a reply to message #324122] Thu, 17 January 2008 16:02 Go to previous message
Originally posted by: eclipse-news.rizzoweb.com
Ed Merks wrote:
> Mark,
See this bug discussion on that topic:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=174515
Eric
>> Ed Merks wrote:
>>> Mark,
>>>> newsgroup.
>>>> Thanks!
>>>> Ed Merks wrote:
>>>>> Mark,
>>>>> activate...
>>>>>> from here:
>>>>>> Preferences.
>>>>>> configure/download?
>>>>>> Thanks!
Previous Topic:Eclipse 3.3 platform update site.xml broken?
Next Topic:Missing projects in Project Explorer
Current Time: Wed Jul 23 01:56:32 EDT 2025
Powered by FUDForum. Page generated in 0.04874 seconds
