Home » Eclipse Projects » Eclipse Platform » how to import the class that is present in default package
how to import the class that is present in default package [message #324002] Wed, 16 January 2008 01:23 Go to next message
Originally posted by: automatic.javalobby.org
I have created a class("xyz.java") in default package and i have made one more package(hello.abc) and created a class inside that package(new.java) i want to import the class that is in the default package in new.java how can i do that.is it possible or i have to create a package and put that file(xyz.java) to package
Re: how to import the class that is present in default package [message #324011 is a reply to message #324002] Wed, 16 January 2008 06:42 Go to previous messageGo to next message
It is not possible to import things from the default package. Don't use
the default package. It's a useless thing.
Re: how to import the class that is present in default package [message #324012 is a reply to message #324002] Wed, 16 January 2008 08:34 Go to previous messageGo to next message
Hi Gudsy!
You can drag a Java file between packages in the Project Explorer view.
Eclipse will insert the correct package statement for you.
Happy programming.
Henning
"gudsy" <automatic@javalobby.org> wrote in message
news:33014078.15111200464660178.JavaMail.root@cp1.dzone.com...
Re: how to import the class that is present in default package [message #324015 is a reply to message #324011] Wed, 16 January 2008 10:11 Go to previous message
Well it's not useless, just very limited :-) .
If you are doing a "one-off I just need to run this little thing right
now and I'm not talking to anybody else and they aren't talking to me
and I'm not putting it into a jar to run later in a fancy application"
then the default package is OK. Notice all of the qualifiers in the
above statement. :-)
Rich Kulp
Previous Topic:Copy/paste to external application on Linux
Next Topic:Eclipse 3.3 - Open resource dialog + derived directories
Current Time: Fri Sep 19 04:39:07 EDT 2025
Powered by FUDForum. Page generated in 0.08284 seconds
