Home » Eclipse Projects » Eclipse Platform » Workspace location - saving at first use
Workspace location - saving at first use [message #323962] Mon, 14 January 2008 14:23 Go to next message
Hi!
I am trying to use the workspace in a similar manner as the IDE uses
the workspace, for that I went through the source code.
But I encountered the problem that I could not find where the
workspace location is saved in the IDE, especially when I start the
application the first time.
So now I have two questions: first where will the location be saved,
second how could I save the location so that my application( eclipse
RCP ) knows where the location is located at the beginning with
Platform.getInstanceLocation(). I don't want to use the -data command
line add - and there has to be a way, because it seems as the IDE
doesn't use it either.
Thanks in advance
Andreas
P.s.: Maybe someone could give me the location where to look in the
source code of the IDE too. Thanks.
Re: Workspace location - saving at first use [message #323966 is a reply to message #323962] Mon, 14 January 2008 14:57 Go to previous messageGo to next message
The default value is "workspace" in the current directory.
You can change this in the config.ini file using the osgi.instance.area
option.
Snjeza
Andreas Winkler wrote:
> Hi!
> Thanks in advance
> Andreas
Re: Workspace location - saving at first use [message #323971 is a reply to message #323966] Mon, 14 January 2008 19:56 Go to previous messageGo to next message
Thanks, I already have seen the value, but when you start eclipse and
choose a workspace this value must be saved somewhere else then in
config.ini. Maybe user.home is the value which points to my chosen
workspace? Do you know where this value is stored?
But since I want to save the value programmatically I would need to
know which class is responsible for storing the location in the right
place. And since in the IDE it is done, there must be a way ;-). But I
didn't find it in the source code.
I guess there must be a more or less simple way to achieve this.
On Mon, 14 Jan 2008 20:57:08 +0100, Snjezana Peco
>option.
>Snjeza
>> Hi!
>> Thanks in advance
>> Andreas
Re: Workspace location - saving at first use [message #323977 is a reply to message #323971] Tue, 15 January 2008 06:36 Go to previous messageGo to next message
The IDE saves data about the selected workspaces in
<ECLIPSE_HOME>/configuration/.settings/org.eclipse.ui.ide.prefs
See the ChooseWorkspaceData.writePersistedData() method.
Snjeza
>> option.
>> Snjeza
>>> Hi!
>>> Thanks in advance
>>> Andreas
Re: Workspace location - saving at first use [message #323978 is a reply to message #323977] Tue, 15 January 2008 06:59 Go to previous message
I know I already saw the class and the prefs file BUT the workspace
is not saved there. Only the recently chosen Workspaces which should
be displayed in the dropdown menu of the changeWorkspace Dialog are
saved there.
AND readPersistedData is called after Platform.getInstanceLocation()
where the workspace is already read. So the workspace as such must be
saved in a different class.
Andreas
On Tue, 15 Jan 2008 12:36:59 +0100, Snjezana Peco
>Snjeza
>>> option.
>>> Snjeza
>>>> Hi!
>>>> Thanks in advance
>>>> Andreas
Previous Topic:Question about width of SWT component
Next Topic:Scrollable TableViewer in Form
Current Time: Fri Sep 19 05:55:52 EDT 2025
Powered by FUDForum. Page generated in 0.03635 seconds
