Home » Eclipse Projects » Eclipse Platform » SWT-Swing Problem!
SWT-Swing Problem! [message #323618] Thu, 03 January 2008 22:50 Go to next message
Originally posted by: hiteshn.mail.gmail.com
Hi All,
I created a simple application where I put a JDialog inside a JFrame. When I
move the JFrame within the editor area or after some interval of time, the
workbench gets hanged and it doesn't respond at all.
Can someone please suggest me the correct way of doing it....
Hitesh...
Re: SWT-Swing Problem! [message #323624 is a reply to message #323618] Fri, 04 January 2008 06:46 Go to previous messageGo to next message
--------------020902060705040504070208
Hitesh,
Maybe these instructions will help you gather more data about what's
going wrong:
< http://runnerwhocodes.blogspot.com/2007/10/deadlock-detectio n-with-eclipse.html>
<http://wiki.eclipse.org/index.php/How_to_report_a_deadlock>
Hitesh Nembhwani wrote:
> Hi All,
> Hitesh...
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Hitesh,<br>
<br>
going wrong:<a
href=" http://runnerwhocodes.blogspot.com/2007/10/deadlock-detectio n-with-eclipse.html"><br>
</a>
<blockquote><a
href="http://wiki.eclipse.org/index.php/How_to_report_a_deadlock"> http://runnerwhocodes.blogspot.com/2007/10/deadlock-detectio n-with-eclipse.html</a><br>
<a href="http://wiki.eclipse.org/index.php/How_to_report_a_deadlock">http://wiki.eclipse.org/index.php/How_to_report_a_deadlock</a><br>
</blockquote>
<br>
<blockquote cite="mid:flkadv$qlo$1@build.eclipse.org" type="cite">
<pre wrap="">Hi All,
Hitesh...
</pre>
</blockquote>
<br>
</body>
</html>
--------------020902060705040504070208--
Re: SWT-Swing Problem! [message #323632 is a reply to message #323618] Fri, 04 January 2008 11:03 Go to previous message
> Hi All,
> I move the JFrame within the editor area or after some interval of time,
> the workbench gets hanged and it doesn't respond at all.
> Hitesh...
Hi Hitesh,
I had similar behavior with my first Swing/SWT program. What I forgot to
account for is that there are two event-handling threads, one for Swing and
one for SWT. If you call a Swing method that should only be called from
the Swing event-handling thread, and you call it from the SWT
event-handling thread by mistake, you can get lockups. They might be
sporadic, or they might happen consistently.
-David
Previous Topic:Can a builder be started when the workbench/workspace loads, in addition to builds?
Next Topic:How To Share A POJO Across Plugins?
Current Time: Fri Jul 18 02:41:19 EDT 2025
Powered by FUDForum. Page generated in 0.07786 seconds
