Home » Eclipse Projects » Mylyn » Mylyn 2.1 is now available
Mylyn 2.1 is now available [message #31684] Fri, 28 September 2007 16:46 Go to next message
Originally posted by: beatmik.acm.org
We are pleased to announce that Mylyn 2.1 is now available and supports
Eclipse 3.3 and 3.4M2.
http://eclipse.org/mylyn/new/
http://eclipse.org/mylyn/downloads/
This release of Mylyn is also included with three of the Eclipse Europa
Fall Update bundles released today:
http://eclipse.org/downloads/
The Mylyn Team
Re: Mylyn 2.1 is now available [message #31758 is a reply to message #31684] Sun, 30 September 2007 07:15 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
It seems as if the task list now shows some bugs as sub tasks.
I find this terrible because I can't recognize active sub tasks anymore.
How can I disable that?
BTW if I enter a find pattern in the task list the nested bugs are shown
as top level bugs, too.
But they disppear when I clear the find pattern ;-(
In general I believe it'd be good if new features that conflict with
expected behaviour can be turned of.
Why have you chosen to nest the bug that has to be fixed first into the
bug that depends on the first?
Not very practical in my opinion.
Cheers
/Eike
> supports Eclipse 3.3 and 3.4M2.
> Europa Fall Update bundles released today:
> The Mylyn Team
Re: Mylyn 2.1 is now available [message #31788 is a reply to message #31758] Sun, 30 September 2007 07:18 Go to previous messageGo to next message
Eike Stepper schrieb:
> shown as top level bugs, too.
Forgot to mention that it'd also be good if the active task is revealed
and selected when i click
on te active task link in the task list (in addition to opening the task
editor).
> the bug that depends on the first?
> Cheers
> /Eike
Re: Mylyn 2.1 is now available [message #31823 is a reply to message #31758] Mon, 01 October 2007 13:36 Go to previous messageGo to next message
See the first screenshot in the New & Noteworthy for disabling the
"Group Subtasks" option:
http://www.eclipse.org/mylyn/new/
This is partly by design, but I agree that it doesn't quite meet
expectations for Bugzilla, so please file a bug against the Bugzilla
component on that.
We try to reduce option bloat as much as we can. In this case we had
significant evidence that some people preferred a flat task listing and
others a nested one, so we made sure that this was an option via the
accessible via the Task List's view menu. I think the problem here was
that the behavior changed without your noticing, which I agree can be
disorienting. Currently our only mechanism for informing the user of
changes is the New & Noteworthy, which this was listed in. If you have
ideas on how to better inform users of changes of this sort please post.
Now and then I wonder if we should have a dialog or some other sort of
indication that pro-actively points the user at the New & Noteworthy,
but those can be annoying.
This is in accordance with suggested usage of depends-on and blocks
(i.e. a task is not done until subtasks are done). It reflects usage in
Mozilla's Bugzilla and on the Mylyn project. The corresponding bug is:
151655: make dependent bug reports show up as subtasks in task list
https://bugs.eclipse.org/bugs/show_bug.cgi?id=151655
If our current approach does not meet your expectations or Bugzilla
usage please comment either on this thread or there, since others could
be in the same boat and so we should at least add a FAQ entry.
Mik
Re: Mylyn 2.1 is now available [message #32137 is a reply to message #31684] Tue, 02 October 2007 03:38 Go to previous messageGo to next message
Hi Mik,
I can't yet report bugs against 2.1 in bugzilla...
its either 2.0M2 or dev
Maarten
> The Mylyn Team
Re: Mylyn 2.1 is now available [message #32348 is a reply to message #32137] Tue, 02 October 2007 19:15 Go to previous messageGo to next message
Maarten: please note my latest post on the newsgroup and the following
bug. We are doing everything we can to address this issue and ensure
that bugs.eclipse.org is not put into such a state again.
205249: blocked config.cgi access is preventing Mylyn clients from
accessing bugs.eclipse.org
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205249
I have also updated the Mylyn homepage with a bulletin stating the
following:
IMPORTANT: bugs.eclipse.org outage for Mylyn users
Mik
Maarten Meijer wrote:
> Hi Mik,
Re: Mylyn 2.1 is now available [message #32659 is a reply to message #31684] Sun, 07 October 2007 19:39 Go to previous messageGo to next message
It seems, both the official 2.1 release and the Weekly Build (already
labels itself 2.2.x) don't work with 3.4M2 and WTP 3 correctly?!
Nothing can be installed and the errors shown by Update Manager don't
seem to make much sense:
The current configuration contains errors and this operation can have
unpredictable results.
WST Web Services UI (2.0.1.v200710021354-792EGwAufYO8FqYlmS_5Ff4sbiKz)
requires plug-in "org.eclipse.gef (3.2.0)", or compatible.
WTP Web Page Editor (1.1.0.v200709202235-3-29oA55P855A) requires
Java Persistence API Tools (1.1.0.v200709170000-772AgCYQCCz-D_LoCCEH)
requires feature "org.eclipse.datatools.connectivity.feature".
WST Common UI (2.1.0.v200709192200-7C6EIaE9RvTVninpsnWz0WgQZgle)
requires plug-in "org.eclipse.draw2d (3.2.0)", or compatible.
Eclipse XML Editors and Tools
(2.1.0.v200709192200-7A3EIPCnbckz0itrBsMmAKQjdclf) requires plug-in
At least the WTP Web Page Editor does however work correctly.
Installing both Mylyn 2.x releases over a 'naked' 3.4M2 works.
One can even copy such updates manually over the WTP 3 installation, but
while Mylyn works there too as far as I can see, adding further
components like 'Exras' fails with the same error (pointing to Web Page
Editor)
I might be able to raise this Bug (not sure, which part is the actual
reason for it, but it only manifests itself when trying to install Mylyn
so far) using a working Mylyn installation somewhere, too...
Thanks and Regards,
Werner
> The Mylyn Team
Re: Mylyn 2.1 is now available [message #32993 is a reply to message #32659] Fri, 12 October 2007 00:41 Go to previous messageGo to next message
Werner, I assume that you are using the ../e3.4 update sites.
http://www.eclipse.org/mylyn/downloads/
Please do file a bug since this is odd (Mylyn has no dependencies on
WTP) and we should investigate.
Mik
> Editor)
> Thanks and Regards,
> Werner
>> The Mylyn Team
Re: Mylyn 2.1 is now available [message #33309 is a reply to message #32993] Tue, 16 October 2007 23:44 Go to previous messageGo to next message
Something similar. The Project Explorer context focused UI also seems
to stop working with the WTP J2EE plugins installed. It works fine
with just the WST plugins only installed. I noticed this after
installing 2.1 of Mylyn and 2.0.1 of WTP.
> Mik
>> Editor)
>> Thanks and Regards,
>> Werner
>>> The Mylyn Team
Re: Mylyn 2.1 is now available [message #35260 is a reply to message #33309] Fri, 02 November 2007 22:33 Go to previous message
I couldn't reproduce this. If it is still happening please file a Mylyn
bug so that we can diagnose further.
Mik
Re: Mylyn 2.1 is now available [message #582784 is a reply to message #31684] Sun, 30 September 2007 07:15 Go to previous message
Cheers
/Eike
> The Mylyn Team
Re: Mylyn 2.1 is now available [message #582804 is a reply to message #31758] Sun, 30 September 2007 07:18 Go to previous message
editor).
> Cheers
> /Eike
Re: Mylyn 2.1 is now available [message #582818 is a reply to message #31758] Mon, 01 October 2007 13:36 Go to previous message
component on that.
Mik
Re: Mylyn 2.1 is now available [message #582963 is a reply to message #31684] Tue, 02 October 2007 03:38 Go to previous message
Hi Mik,
Maarten
> The Mylyn Team
Re: Mylyn 2.1 is now available [message #583062 is a reply to message #32137] Tue, 02 October 2007 19:15 Go to previous message
following:
Mik
> Hi Mik,
Re: Mylyn 2.1 is now available [message #583210 is a reply to message #31684] Sun, 07 October 2007 19:39 Go to previous message
Editor)
Thanks and Regards,
Werner
> The Mylyn Team
Re: Mylyn 2.1 is now available [message #583381 is a reply to message #32659] Fri, 12 October 2007 00:41 Go to previous message
Mik
> Editor)
> Thanks and Regards,
> Werner
>> The Mylyn Team
Re: Mylyn 2.1 is now available [message #583504 is a reply to message #32993] Tue, 16 October 2007 23:44 Go to previous message
> Mik
>> Editor)
>> Thanks and Regards,
>> Werner
>>> The Mylyn Team
Re: Mylyn 2.1 is now available [message #584327 is a reply to message #33309] Fri, 02 November 2007 22:33 Go to previous message
Mik
Previous Topic:Anyone using JIRA 3.10?
Next Topic:Mylyn: Where did "Activity Report" go??
Current Time: Sat Jul 19 08:38:31 EDT 2025
Powered by FUDForum. Page generated in 0.33054 seconds
