Home » Eclipse Projects » Eclipse Platform » Problems exporting plug-in project in Eclipse 3.4M3
Problems exporting plug-in project in Eclipse 3.4M3 [message #323212] Fri, 14 December 2007 07:32 Go to next message
Hi!
I've discovered a potential bug in eclipse 3.4M3 (Build id:
I20071101-2000) related with paths with white spaces while exporting a
plugin project. I was trying to export my project (right click over
project -> export -> Plug-in Development -> Deployable plugins and
fragments) and always got the same error:
Problems during export
Buildfile: C:\victor\Mis documentos\workspace
test\.metadata\.plugins\org.eclipse.pde.core\temp\org.eclips e.pde.container.feature\build.xml
does not exist
does not exist
does not exist
does not exist
Then I sort of figured out it could be related with long paths. I
created a new workspace at C:\workspace and a sample plug-in, and it
worked fine. But tried again to find out the source of the problem with
a workspace at "C:\my test" and it failed again with the same error. So
the problem was not long paths itself, but rather white spaces in the path.
Any commentaries, opinions?
Re: Problems exporting plug-in project in Eclipse 3.4M3 [message #323218 is a reply to message #323212] Fri, 14 December 2007 10:37 Go to previous messageGo to next message
There was a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=210464
It has been fixed, try 3.3M4 (which is due any time now), or an Integration
build newer than 20071121.
-Andrew
Víctor Roldán Betancort wrote:
> Hi!
> does not exist
> does not exist
> does not exist
> does not exist
Re: Problems exporting plug-in project in Eclipse 3.4M3 [message #323220 is a reply to message #323218] Fri, 14 December 2007 11:00 Go to previous message
Thank you Andrew!
I will work with my no-white-space-path workaround in the meanwhile :D
Cheers!
> Integration build newer than 20071121.
> -Andrew
>> Hi!
>> does not exist
>> does not exist
>> does not exist
>> does not exist
>> with a workspace at "C:\my test" and it failed again with the same
>> error. So the problem was not long paths itself, but rather white
>> spaces in the path.
Previous Topic:Error instantiating builder: org.eclipse.jet.builder.
Next Topic:Where do i find the 'Show heap status' ContributionItem ?
Current Time: Thu Nov 06 03:08:27 EST 2025
Powered by FUDForum. Page generated in 0.03832 seconds
