Home » Archived » EPF » Image Maps in EPF
Image Maps in EPF [message #31988] Wed, 02 May 2007 09:05 Go to next message
Originally posted by: ihandojo.njm.com
Folks,
How do you/what tool do you use to add image maps on images that you embed
into EPF (to create areas on images with hyperlinks)?
I can create an image and overlay an image map using other popular HTML
editing tools and import the <map> tag in, but how can I easily associate
each hotspot area with links within EPF itself, e.g., link to a Role.
Thanks in advance.
AH
Re: Image Maps in EPF [message #32130 is a reply to message #31988] Mon, 07 May 2007 03:41 Go to previous messageGo to next message
When you draw the image map hotspots in your html editor and the tool
prompts you for the target URL, just type a "dummy" string that reminds you
later which method or process element you want to link to. Once, you
finished the map copy the html. Go to the EPFC form and switch the field's
rich text editor into the HTML tab. Paste the html. Go back to the rich text
tab and start dragging into the editor below the image all the elements that
your map shall link to. Switch back to html and paste the string of the new
links href values into the respective href references in the image map above
replacing your "dummy" strings.
Note, that the href format has changed in EPF Composer 1.2. If you migrate
you need to manually fix the hrefs for the image maps. All other links that
contain a class and guid attribute will be automatically updated by EPF
Composer.
Peter.
"Alex Hunt" <ihandojo@njm.com> wrote in message
news:ee6dd644f4fc02b5cd54aca52567805f$1@www.eclipse.org...
> Folks,
> Thanks in advance.
> AH
Re: Image Maps in EPF [message #32309 is a reply to message #32130] Mon, 07 May 2007 19:30 Go to previous messageGo to next message
What Peter explained is what we did for some OpenUP graphics that have image
maps (e.g. the round table on front page).
To fix the problem related to difference in formats mentioned, in case you
use EPF Composer (previous than 1.2, and then upgrade to 1.2) you want to
remove the GUIDs from those hyperlinks in the image map, as the tool today
(as available in M2) does not migrate those links correctly. Future builds
are expected to fix that. After removing the GUIDs, just open the library in
1.2.
Ricardo Balduino.
"Peter Haumer" <phaumer@us.ibm.com> wrote in message
news:f1ml7t$at8$1@build.eclipse.org...
> you later which method or process element you want to link to. Once, you
> text tab and start dragging into the editor below the image all the
> elements that your map shall link to. Switch back to html and paste the
> string of the new links href values into the respective href references in
> the image map above replacing your "dummy" strings.
> that contain a class and guid attribute will be automatically updated by
> EPF Composer.
> Peter.
>> Folks,
>> embed into EPF (to create areas on images with hyperlinks)?
>> Thanks in advance.
>> AH
Re: Image Maps in EPF [message #32448 is a reply to message #32309] Tue, 08 May 2007 13:39 Go to previous message
Peter,
Ricardo,
Takes several steps to do it, but it works.
Thanks for the tips.
AH
> 1.2.
> Ricardo Balduino.
>> EPF Composer.
>> Peter.
>>> Folks,
>>> Thanks in advance.
>>> AH
Re: Image Maps in EPF [message #578119 is a reply to message #31988] Mon, 07 May 2007 03:41 Go to previous message
Composer.
Peter.
> Folks,
> Thanks in advance.
> AH
Re: Image Maps in EPF [message #578210 is a reply to message #32130] Mon, 07 May 2007 19:30 Go to previous message
1.2.
Ricardo Balduino.
> EPF Composer.
> Peter.
>> Folks,
>> Thanks in advance.
>> AH
Re: Image Maps in EPF [message #578317 is a reply to message #32309] Tue, 08 May 2007 13:39 Go to previous message
Peter,
Ricardo,
AH
> 1.2.
> Ricardo Balduino.
>> EPF Composer.
>> Peter.
>>> Folks,
>>> Thanks in advance.
>>> AH
Previous Topic:license
Next Topic:Printable version of a EPF composer manual
Current Time: Sat Jul 19 00:38:15 EDT 2025
Powered by FUDForum. Page generated in 0.06863 seconds
