Home » Eclipse Projects » Eclipse Platform » Drag and drop file from Windows into RCP application
Drag and drop file from Windows into RCP application [message #322934] |
Mon, 03 December 2007 10:09  |
I have an RCP application and I need to be able to drag a file from the Windows Explorer and drop it
into the Project View in my application to open the project.
I have looked at the Eclipse drag and drop article-
http://www.eclipse.org/articles/Article-Workbench-DND/drag_d rop.html
and have tried adding DropSupport to the TreeViewer in my Project View
int ops = DND.DROP_COPY | DND.DROP_DEFAULT;
Transfer[] transfers = new Transfer[] { FileTransfer.getInstance()};
treeViewer.addDropSupport(ops, transfers, new FileViewerDropAdapter(treeViewer));
However I am getting the below error -
org.eclipse.swt.SWTError: Cannot initialize Drop
at org.eclipse.swt.dnd.DND.error(DND.java:247)
at org.eclipse.swt.dnd.DND.error(DND.java:208)
at org.eclipse.swt.dnd.DropTarget.<init>(DropTarget.java:130)
After debugging through the application, it is failing on this line -
if (control.getData(DROPTARGETID) != null) {
DND.error(DND.ERROR_CANNOT_INIT_DROP);
I'm guessing this means that it has a problem with the fact that there is already a DROPTARGETID set
in the treeViewer, which is the case since there is Drag and drop implemented for this view already
for copying/moving elements/selections of a project within the viewer.
Does this mean I can only call addDropSupport once for my TreeViewer? I'd like to keep the logic for
dealing with FileTransfers and LocalSelectionTransfers separate if possible, but it looks like I
would have to implement this logic in the same ViewerDropAdapter for both?
Re: Drag and drop file from Windows into RCP application [message #322952 is a reply to message #322934] |
Mon, 03 December 2007 14:33   |
Many thanks for your help,
I am now trying to handle both SelectionTransfers and FileTransfers in the same DropAdapter-
Transfer[] transfers = new Transfer[] { LocalSelectionTransfer.getTransfer(),
treeViewer.addDropSupport(operations, transfers, new TreeViewerDropAdapter(treeViewer));
However I am still having a problem with dropping a file from Windows Explorer into the View. I want
to be able to validate the file being dropped in some way, and disallow the drop (e.g. if the file
doesn't have the correct extension). I thought I could do the validation by testing the event data
in the dropAccept method, or in validateDrop method, but the event data is null at this point. How
can I validate the file? I do have access to the data containing the file path string from within
the performDrop method, but by then it's too late as I want to disallow the drop before this?
Or is there an easier way to accomplish what I am trying to do? I basically just want to drop a file
from Windows Explorer into the viewer. It is not important which object or target I am dropping
onto, I don't need to drop it into an existing item in the treeViewer, I just need to open the file
as a new project and add it to the view.
Conor
Conor O'Mahony wrote:
> Windows Explorer and drop it into the Project View in my application to
> open the project.
> is already a DROPTARGETID set in the treeViewer, which is the case since
> there is Drag and drop implemented for this view already for
> I'd like to keep the logic for dealing with FileTransfers and
> LocalSelectionTransfers separate if possible, but it looks like I would
Re: Drag and drop file from Windows into RCP application [message #322966 is a reply to message #322952] |
Mon, 03 December 2007 17:10   |
I don't think you need DND.DROP_DEFAULT in your code.
The event.data is not available until the drop occurs. I believe you can
still validate the data in the performDrop method and return false to
disallow the drop.
Duong
same DropAdapter-
drop before this?
> Regards,
> Conor
>> Hi,
>> open the project.
Re: Drag and drop file from Windows into RCP application [message #322984 is a reply to message #322966] |
Tue, 04 December 2007 05:07   |
How can I validate the data in performDrop if the event.data is not available until the drop occurs?
Is there any other way to access the data?
Thanks for your help.
Conor
> disallow the drop.
> Duong
>> the
> same DropAdapter-
>> disallow the
>> validation by
>> data is
>> disallow the
> drop before this?
>> basically
>> object or
>> Regards,
>> Conor
>>> Hi,
>>> the Windows Explorer and drop it into the Project View in my
>>> there is already a DROPTARGETID set in the treeViewer, which is the
>>> both?
Current Time: Sat Jul 26 20:30:00 EDT 2025
Powered by FUDForum. Page generated in 0.08081 seconds
