Home » Eclipse Projects » Eclipse Platform » Programmatically Arrange Editors/Editor Stacks?
Programmatically Arrange Editors/Editor Stacks? [message #322790] Wed, 28 November 2007 21:23 Go to next message
Originally posted by: sddavis.cs.ubc.ca
I'm wondering if it's possible to programmatically (i.e. from within a
plugin) control the position of editors in Eclipse. I would like to be
able to open an editor and have it automatically appear in a new editor
stack in certain circumstances, rather than the usual behavior of joining
the current stack and covering up the currently active editor. I can't
find anything about this in the documentation or newsgroups.
Sam
Re: Programmatically Arrange Editors/Editor Stacks? [message #322813 is a reply to message #322790] Thu, 29 November 2007 08:50 Go to previous messageGo to next message
There should be something in the newsgroups, since this comes up
occasionally.
There is no API to do this, since its support can be presentation
dependent. However, we do have tests that programmatically drag editors
around, check out org.eclipse.ui.tests.session.Bug95357Test from
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Programmatically Arrange Editors/Editor Stacks? [message #322826 is a reply to message #322813] Thu, 29 November 2007 14:20 Go to previous messageGo to next message
Thanks much. Here's the URL, in case anyone else is looking for it:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ui.test s/Eclipse%20UI%20Tests/org/eclipse/ui/tests/session/Bug95357 Test.java?view=markup
Re: Programmatically Arrange Editors/Editor Stacks? [message #1194672 is a reply to message #322826] Mon, 18 November 2013 11:35 Go to previous message
now found at http://git.eclipse.org/c/platform/eclipse.platform.ui.git/tree/tests/org.eclipse.ui.tests/Eclipse%20UI%20Tests/org/eclipse/ui/tests/session/Bug95357Test.java
Previous Topic:Eclipse Code Template
Next Topic:Remote System Explorer Operation freezes editor
Current Time: Sat Jul 26 09:00:31 EDT 2025
Powered by FUDForum. Page generated in 0.05797 seconds
