Home » Eclipse Projects » Eclipse Platform » Use an XML Template when creating a New XML File
Use an XML Template when creating a New XML File [message #322475] Mon, 19 November 2007 13:30 Go to next message
Would really appreciate some help here in case I'm way off track.
What I am trying to do is define an XML template and when I create a new
file, that this template gets used in the creation.
I have my org.eclipse.ui.editors.templates extension and this seems fine
and shows up in the WST XML Template store.
What I am trying to figure out now is how this should get used when I
create the file from my New File Wizard.
I can query and get the template, etc but I'm a bit confused then as to
how to go about doing the replace of some of the TemplateVariables, well
mainly if I was heading in the right direction, etc..
Thanks in advance.
Ronan
Re: Use an XML Template when creating a New XML File [message #322509 is a reply to message #322475] Tue, 20 November 2007 03:22 Go to previous messageGo to next message
Ronan Mulvaney wrote:
> new file, that this template gets used in the creation.
> fine and shows up in the WST XML Template store.
Can't speak for XML and have no clue which wizard you're using but
normally the templates contributed via the mentioned extension are
editor templates used when typing and not code templates used for code
generation.
Dani
> to how to go about doing the replace of some of the TemplateVariables,
> well mainly if I was heading in the right direction, etc..
> Thanks in advance.
> Ronan
Re: Use an XML Template when creating a New XML File [message #322515 is a reply to message #322509] Tue, 20 November 2007 04:12 Go to previous messageGo to next message
Hi Dani,
The Wizard I'm using is just my own creation/extension to the New File
option to allow for the creation of the file type that I am handling.
I wasn't aware that they were only code templates, I was hoping to
re-use this Template Store to allow developers of my artifact the
ability to customize the initial file creation similar to the "New Java
Files" template in the JDT.
Ronan
>> Hi,
> generation.
> Dani
>> Thanks in advance.
>> Ronan
Re: Use an XML Template when creating a New XML File [message #322593 is a reply to message #322515] Wed, 21 November 2007 04:16 Go to previous message
> Hi Dani,
I guess we should first define the terms ;-)
There are two kinds of JDT templates: the ones used when typing (see
Java > Editor > Templates) and which can be contributed via the
extension point and those that are used when JDT generates code (see
Java > Code Style > Code Templates). Both use the TemplateStore
technology. Now, since you write your own stuff you could use the
extension point to contribute the templates but then, other plug-ins
could theoretically contribute their own code generation tempalates
which would then appear on your preference page (you will have to
provide a Code Templates preference page where users can edit your
default templates. I would therefore suggest to follow the same pattern
as JDT does: use the template store technology but provide your own set
of default templates directly.
For a start take a look at:
org.eclipse.jdt.internal.ui.JavaPlugin.getCodeTemplateStore( )
/org.eclipse.jdt.ui/templates/default-codetemplates.xml
HTH
Dani
> I was hoping to re-use this Template Store to allow developers of my
> artifact the ability to customize the initial file creation similar to
> the "New Java Files" template in the JDT.
> Ronan
>>> Hi,
>>> I create the file from my New File Wizard.
>> code generation.
>> Dani
>>> TemplateVariables, well mainly if I was heading in the right
>>> direction, etc..
>>> Thanks in advance.
>>> Ronan
Previous Topic:About the performance of the Table(TableViewer)
Next Topic:Skipping builder 'com.ibm.sse.model.structuredbuilder'
Current Time: Tue Jul 22 13:48:41 EDT 2025
Powered by FUDForum. Page generated in 0.23606 seconds
