Home » Eclipse Projects » Eclipse Platform » Where is my JFrame? (was Strange behavior when trying to debug my application within eclipse)
Where is my JFrame? (was Strange behavior when trying to debug my application within eclipse) [message #322457] Mon, 19 November 2007 07:38 Go to next message
Originally posted by: yaronrein.hotmail.com
I was able to isolate the problem.to the following program, it runs well
from the command line but fail to show the frame when running within Eclipse
Why does System.in.read(buffer); prevent the frame creation within Eclipse?
Thanks in advance
/Yaron
import java.io.IOException;
import javax.swing.JFrame;
public class WhereIsMyJFrame
public static void main(String[] args)
new WhereIsMyJFrame();
private WhereIsMyJFrame()
Thread thread = new Thread()
public void run()
System.out.println("run");
WhereIsMyJFrame.loop();
System.out.println("starting the thread");
thread.start();
System.out.println("creating the main window");
JFrame frame = new JFrame("WhereIsMyJFrame");
System.out.println("main window created");
frame.setVisible(true);
private static void loop()
try
byte buffer[] = { 0 };
do
while ((char) buffer[0] != 'x');
catch (IOException ioexception)
ioexception.printStackTrace();
Re: Where is my JFrame? (was Strange behavior when trying to debug my application within eclipse) [message #322459 is a reply to message #322457] Mon, 19 November 2007 08:22 Go to previous messageGo to next message
Maybe because the streams in Eclipse are redirected to the ConsoleView?
Tom
Yaron Reinharts schrieb:
> Thanks in advance
> /Yaron
> public void run()
> thread.start();
> try
> do
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Where is my JFrame? (was Strange behavior when trying to debug my application within eclipse) [message #322465 is a reply to message #322459] Mon, 19 November 2007 11:28 Go to previous messageGo to next message
Thanks but I don't see how it can prevents the creation of a JFrame
/Yaron
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:fhs2mh$5r5$1@build.eclipse.org...
> Tom
>> Hi,
>> Eclipse
>> Eclipse?
>> Thanks in advance
>> /Yaron
>> public void run()
>> thread.start();
>> try
>> do
Re: Where is my JFrame? (was Strange behavior when trying to debug my application within eclipse) [message #322467 is a reply to message #322465] Mon, 19 November 2007 11:42 Go to previous messageGo to next message
--------------060706090601070409050807
Yaron,
I don't really know how eclipse handles calls to System.out and
System.in, but I guess both of them are redirected to the console view.
This is no more than a wild guess, but since you're calling thread.start
(which in turns will take the consoleView over with a call to
System.in.read()) before creating and displaying your window, I think
the call to System.out.println("main window created") will wait for the
consoleView to be released before continuing execution.
Laurent Goubet
Obeo
Yaron Reinharts a
Re: Where is my JFrame? (was Strange behavior when trying to debug my application within eclipse) [message #322499 is a reply to message #322467] Tue, 20 November 2007 01:50 Go to previous messageGo to next message
This makes sense, and I can understand why the "main window created" is not
diaplayed, however, it doesn't explain where is the JFrame and why I can see
the JFrame only when running outside Eclipse
Any idea?
/Yaron
"laurent Goubet" <laurent.goubet@obeo.fr> wrote in message
news:fhse8b$cb6$1@build.eclipse.org...
> Yaron,
> Cheers,
> Laurent Goubet
> Obeo
> Yaron Reinharts a
Re: Where is my JFrame? (was Strange behavior when trying to debug my application within eclipse) [message #322513 is a reply to message #322499] Tue, 20 November 2007 03:49 Go to previous messageGo to next message
Originally posted by: akarypid.yahoo.gr
If you debug your application, you'll see that if you interrupt the main
thread you'll see it's within:
WDesktopProperties.init() line: not available [native method]
whereas the other thread is
FileInputStream.readBytes(byte[], int, int) line: not available
[native method]
My guess is that the Swing library somehow accesses the console in
WDesktopProperties.init() causing a deadlock. I'd use an object to wait
for the frame to become visible before proceeding with console access:
public void run() {
synchronized (sync) {
try {
sync.wait();
} catch (InterruptedException e) {
return;
and
private WhereIsMyJFrame() {
sync.notify();
Also, I'd guess that you could reproduce this thing outside of Eclipse
if you ran your program from the command line and redirected your
standard input and output.
Re: Where is my JFrame? (was Strange behavior when trying to debug my application within eclipse) [message #322520 is a reply to message #322513] Tue, 20 November 2007 05:13 Go to previous messageGo to next message
Thank you Alexandros
I don't see this thread in the debug window
I see other threads, there are all seems to be running (including one which
is called AWT-Shutdown)
I'm using Eclipse Version 3.3.1
Anyway, I found a workaround for my problem (skipping the console reading)
However, I'm still curious to understand what happened and to know if I
should do something about it (bug report)
/Yaron
"Alexandros Karypidis" <akarypid@yahoo.gr> wrote in message
news:47429F85.3040509@yahoo.gr...
> FileInputStream.readBytes(byte[], int, int) line: not available [native
> method]
> public void run() {
> try {
> sync.wait();
> return;
> and
> sync.notify();
> Also, I'd guess that you could reproduce this thing outside of Eclipse if
> you ran your program from the command line and redirected your standard
> input and output.
Re: Where is my JFrame? (was Strange behavior when trying to debug my application within eclipse) [message #322527 is a reply to message #322520] Tue, 20 November 2007 07:13 Go to previous messageGo to next message
Yes, this is correct. You will see all threads there as "running", even
though the thread may just be waiting in vain for something to occur.
There is an "interrupt" button which will change the thread's state to
susspended and show you where the thread instruction pointer is at,
along with a stack trace of how it got there.
In order to see meaningful names, call "setName()" on your threads to
give them human-readable descriptions. Then you can know which thread is
what.
In any case if you _require_ console input, I'm pretty sure you can have
it and still work around this (as described in my previous post) by
having the thread's run() method wait for the JFrame constructor to
return and then access the console.
> Thanks
> /Yaron
>> method]
>> public void run() {
>> try {
>> sync.wait();
>> return;
>> and
>> sync.notify();
>> input and output.
Re: Where is my JFrame? (was Strange behavior when trying to debug my application within eclipse) [message #322725 is a reply to message #322527] Tue, 27 November 2007 02:44 Go to previous message
Thakns again, it was very helpful
/Yaron
news:4742CF72.30801@yahoo.gr...
>> which
> susspended and show you where the thread instruction pointer is at, along
> In order to see meaningful names, call "setName()" on your threads to give
> them human-readable descriptions. Then you can know which thread is what.
>> reading)
> it and still work around this (as described in my previous post) by having
> the thread's run() method wait for the JFrame constructor to return and
>> Thanks
>> /Yaron
>>> method]
>>> public void run() {
>>> try {
>>> sync.wait();
>>> return;
>>> and
>>> sync.notify();
Previous Topic:Problem creating POJO using Castor data binding framework in Eclipse plugin
Next Topic:How to access all projects at runtime
Current Time: Mon Nov 03 20:32:45 EST 2025
Powered by FUDForum. Page generated in 0.08883 seconds
