| Web Services Explorer [message #32102] |
Mon, 26 July 2004 21:03  |
I was wondering why the Web Services Explorer was implemented as an
application in Tomcat instead of a regular Eclipse view?
Also I have Preferences > Server > Installed Runtimes pointing to Tomcat
v5.0, but there is a separate option under Preferences > Web Services >
Server and Runtime that doesn't list Tomcat v5.0 as an option. This is
blocking my attempt to use the wizard to create a web service.
| Re: Web Services Explorer [message #37178 is a reply to message #35928] |
Thu, 05 August 2004 18:20  |
Originally posted by: jkrause.w4toolkit.com
Arthur Ryman wrote:
> Ed Burnette wrote:
>> Arthur,
>> My initial impression is that this is something I think should be
>> revisited
>> as soon as time allows. The Web Services Explorer webapp interface is
>> very
>> nice as far as it goes but it's not as usable and interactive as a rich
>> client app would be. For example, it has frames that kind of look like
>> views, but you can't rearrange them or tear them off. The webapp takes
>> longer to start and it's not as responsive as a rich client app.
>> Colors are
>> not the same as the rest of Eclipse. It ties up the editor area (as
>> opposed
>> to being spread over editors and views). You can't drag and drop objects
>> between it and the rest of Eclipse. It doesn't tie in with Eclipse
>> help. You
>> can't have a "Web Services Explorer" perspective that lets you browse and
>> filter using the full power of the Eclipse workbench (the best you can
>> do is
>> maximize the editor and work within the webapp).
>> Using SWT shouldn't it be possible to render everything that the
>> webapp can
>> render inside regular workbench parts? If you can think of something
>> that is
>> not possible or is more difficult then let's enumerate that and see if we
>> can get better support for those things. For example, maybe the Forms UI
>> could add some feature that would make it easier.
>> I haven't looked at the code yet for the Web Services Explorer webapp
>> but is
>> it organized so it could have another presentation put on top of it
>> like a
>> SWT-based one, without too much trouble?
> Ed,
> As I mentioned, we do have a cut down version based on SWT but didn't
> contribute it. However, I think that to recreate all the function in the
> Web Services Explorer as an SWT app would result in a large amount of
> code and effort. We can add this to the list of to do's and will have to
> prioritize this wrt to the other work items.
> The Requirements Committee is starting up the week. I suggest you send
> Jochen a note outling the requirement.
> -- Arthur
Ed,
We are monitoring this newsgroup for requirements, so there is no need
to send an extra mail.
Jochen
FUDForum. Page generated in 0.03761 seconds
